    273
  1. Don't know if unplugging the battery depowers the SRS, but at least on the 2007, the pad is removable according to the manual. Remove the 3 cushion thermal electric device (TED)-to-cushion frame screws.Remove the cushion TED-to-climate control seat cushion adapter screw and remove the TED.
  2. You have an '07 right? What trim level, what size wheels do you have on there? There was a recent discussion about this, where weight of packed snow in the wheels can cause them to become unbalanced, as you surmised.
  3. If the toothbrush cannot be trusted, wrap a nice microfiber cloth around it. That is sure not to damage the TB plate. When I last looked at the TB a couple of months ago, I saw a light golden color on it, but no heavy oiling or crusting. Left it alone at that point.
  4. Aha! TSB Number: 12-6-2 Vehicles: 2009-11 Ford Edge and Mercury MKX Condition: Corrosion on the lip of 22-inch wheels and whiskers/vents on the tire’s bead seat may cause the TPMS to illuminate. Solution: Disassemble the rim and tire and clean the rim flange and tire bead with a Scotch-Brite pad.
  5. Let's see what happens over time. After I cleaned the MAF, it felt better, but the feeling didn't last very long, so maybe the PCM is doing a "minor" relearn as it adjusts to the improved MAF input.
  6. So much attention has been focused on the PTU/trans that little discussion has been made on the driveshaft/RDU. Hopefully it is an easily resolveable issue with bushings on the driveshaft or fluid replacement on the RDU. Don't know if any programming is involved directly to control the RDU.
  7. Haven't seen any for the 11+ MY's. You could make your own as a DIY Project, haven't seen anyone do it for the Edge yet.
  8. Except for the fuel injectors. They tick like crazy, and not just on the Edge!
  9. Levittown has it for $197 + S/H. So yeah, maybe they just did a cleaning on the TB? Or replaced the PCV valve?
  10. Ha! Wanted to cross-check what this dealer did
  11. Welcome to the community, and congrats on your Edge! No question about wanting to see pics Where are they already??? The Subaru and Lexus products are nice too! Interested in what mods you come up with, quite a few mod ideas on this forum to glean from, even more always welcome
  12. Very interesting. No self-healing, Terminator-type properties for that glass!
  13. What oil are you using in your Edge, 2011edgese? If it's the recommended 5w-20, you might try going to 0w-20 (better viscosity at lower temps, tho normally should NOT be needed) and see if the problem goes away even in colder weather. Still a lubrication problem IMHO.
  14. Used to be on the window sticker that you looked up online, but that info is no longer on there. ETIS is the only reliable source I know of, other than a dealer of course. https://www.etis.ford.com/vehicleRegSelector.do Do you have Java enabled on your Note 2? From your browser, enter the advanced menu settings to check. Otherwise you will likely need a Java emulator installed.
  15. This link was posted before, I believe: https://www.etis.ford.com/ Click on Vehicle, then enter the VIN number in the box provided.
  16. Stuck between snowstorms and thunderstorms. Had to go through the carwash twice today to get the muck & salt off the Edge. Still a bit dirty, but so much better! Now on to tomorrow's thunderstorms ... Grrrrrrrr! Weathertech mats have been a lifesaver. Too many automatic carwashes still closed for business.
  17. No touching the maf sensor wires. Too fragile, as you rightly said. If you choose to use one gently, you have to test voltages with a wire piercing probe afterwards to confirm continuity. A process you can try, if you are ready to buy a replacement MAF: https://www.louv.tv/cars/m5/MAF/
  18. A few incidents relating to broken back glass have been written up on this forum. No known reason why this problem exists. I personally suspect lamination/tint combined with defrost cycles, but that is pure conjecture.
  19. Spic 'n span interior! Congrats on the 300K mark!
  20. There might be rust on the wheels that needs to be properly sanded off before the tires are remounted. Either that, or the wheels should be replaced, maybe a smaller wheel to prevent recurrence? Hopefully you will get free Tire Care warranty or something similar to keep these costs from hitting your wallet. I assume the TSB performed so far is 11-5-16, as referred to in post #4 in this thread? http://www.fordedgeforum.com/topic/9124-pirelli-wheels-bead-leak-issue/?do=findComment&comment=73475
  21. Welcome to the community, and congrats on your Edge, Jose! Plenty of good info on here, plenty of opportunity to learn & share
  22. Did you get an ODO error of some sort (an actual error code, I know you said the mileage blanked out)? This has been found to be fixed in the past with replacement of the TSS/OSS sensors.
