Chipster
    8
Everything posted by Chipster
  1. Any new thoughts about 2.0 ownership? Are there any issues showing up recently? I seem to recall that a few early owners of 2015's were having issues with the pressurized air supply hose becoming blown off due to poor clamping issues. I am not certain if this was a wide spread issue or not?
  2. I drove the 2.0 Eco-4 powered Edge yesterday and was impressed with its performance. It did seem to be a bit "buzzy" when compared to the 3.5 but nothing too bad. I wondered if anyone who owns the the 2.0 has tried reg. gas in it just to judge the performance difference? I understand that the output is reduced to 220 hp +- when using reg. gas. I am now conflicted as to which powerplant I should select. I lean towards the 3.5 only because it has a proven track record, but the 2.0 Eco seem to handle the Edge's size pretty well. What factors went into your engine selection?
  3. How exactly does it work? After engine is killed... Foot on brake @ light then just apply pressure to the gas pedal to start it? How long must your stop be before the engine is stopped?
  4. WingNut: Can you list out the needed part numbers for the Q tower system you purchased? By the way, did you buy the optional locks for it? I am thinking they might be a worthwhile investment.
  5. Anyone now have this feature? Like it?
  6. My first car purchase while in the Air Force. 1969 SS396, 350hp, posi rear, rock crusher tranny with special low first gear. I wish I had it now, but those Rat motors loved oil and gasoline. No comparison to anything built today, but not a ECM, ECU, or BCM in sight! I wonder how that was possible?
  7. Folks I know this is a tough problem for those affected, but this is not the thread to talk about the leak. My intent with this thread is to see how effective the "fix" is. The thread to report your leak problem is here: http://www.fordedgeforum.com/topic/18110-water-leak-help/ Thanks.
  8. Are there any more update reports on leaker's, post "leak repair"? Hopefully "the fix" worked. Did it for your's?
  9. ak put up here: http://www.fordedgeforum.com/topic/19022-2016-ford-edge-order-guide/
  10. Black is such a demanding color. Looks great, but it sure takes a lot of effort to keep it that way.
  11. https://media.ford.com/content/fordmedia/fna/us/en/news/2015/09/15/ford-adaptive-steering-system-launching-on-2016-ford-edge-will-change-how-the-world-turns.html
  12. It would appear that we are days away from the order bank opening, so this begs the question... What are you going to order? Please be specific as to model, trim level, drive line, options, exterior color, wheels, etc. etc. Edited with special request: If you happen to order your Edge with the roof rails and buy the optional Ford crossbar kit (P/N 7T4Z7855100-BA please send me a site message I have a few questions about this option combination. I want to carry a canoe on it but am not sure this combination will give a canoe the needed clearance of the shark fin antenna.
  13. ak; A few questions; What do they do with those J1 vehicles after the inspections? Are these the same "early builds" that you have referred to in your last sentence about "early builds"? What is the run rate during the J1 phase, and how does this compare with normalized production run rates after the any bugs are sorted out? Thanks
  14. I hear you Jack! It's hard to be an old analog dog in the presence of digital whipper snappers. Just kidding of course. I am still trying to figure out how to convert my CD's to MP3 files so I can load them on a thumb drive, but that's a topic for another thread and day. I only hope Ford doesn't kill the CD player in the 2016's!
  15. Help me out on this: There was once a concern about having to replace all of the tires on an AWD vehicle if one of them were damaged past the point of a repair and there would be (not sure of the actual number) say more than 3/16" in dia. between the new tire and the old ones. I seem to remember reading that even slight differences in tire diameter causes the car's computer and drive-train to do things that would harm the drive line. Is this still true today? If this is true, that would be a big financial hit if it were to happen.
  16. Please add pictures of your Edge to your reviews if you have not. Thanks!
  17. I sure hate seeing this! If you are sure that there was not a window closure issue as the cause, run it by your dealer to have it checked out and keep us posted. Good luck!
  18. I bet that it (like in other Ford vehicles) is a Throttle Body and re-flash issue. My wife's 2010 Fusion had a TSB issued for the throttle body replacement and re-flash. Before the TB was replaced the vehicle showed the exact same symptoms of stalling in traffic and scaring the heck out of the driver. After the fix the problem went away. Jack; I am not quite as old as you, but my uses for the Edge will include hauling my canoe to the local river, light around the house hauling and other such duties. I do fully expect, and hope that this will be my last truck like purchase. I got 20 good years out of my Blazer 4 X 4 and hope to get the same service life out of the Edge. This is why I am leaning towards the 3.5.
  19. As it stands right now I am favoring the 3.5. I'll do a couple more test drives to see if that changes my mind. I've got a little roadster to kick out the jams in so I don't need the performance that the turbo 6 offers.
  20. I am still trying to figure out which engine I should order for my 2016 and I found this video helpful. Maybe you will too... https://www.youtube.com/watch?v=_U4OLdMdDYU
