Everything posted by Special_K
of course!
Hey @Cerberus, @snmjim asked me to kick in and help answer some of your questions here. Please see above for my input in red :-).
We will be listing as soon as we get the verbiage done :-)
Just Direct injection
ST Suspension Components on 2017 Edge Sport?
Special_K replied to clegg78's topic in Brakes, Chassis & Suspension
only 480 bucks..... just say it was a unforeseen "repair" cost -
bilstein shocks and rear sway then -
Ah yes, you got the Special_K treatment -
I would like to mention here real quick if you got the model with summer tires, flat spots is a real thing and doesnt clear up until tires reach about 85~90f and about 25miles. If its getting worse along with your other uncommon issues take that crap back and tell them it unacceptable.
if you want sporty fun. do H&R springs on Bilstein b6 shocks with addco rear sway. will handle like a car! -
Ford Edge Temp sensor, HELP!!
Special_K replied to Jackm's topic in Interior, A.C., Heat, Interior Trim
A/C has an ambient temperature limit (thinks its cold outside). replace the ambient temp sensor -
seems about right, the edge is a complicated platform to tune that can render subpar results if you arent 100% familiar
Under hood temps and hood heat extractor install
Special_K replied to poontanghooligan's topic in 2.7L EcoBoost
BOOOOOO as us engineers would say .... YOU FOGEY. Nah i kid, cost analysis makes sense for the expected risk. but i will say this......should have done the ST, its a BEAST -
PBD is okay with fusions and edges. Recommended tuners for these are ZFG, Tuned by James, and Unleashed.
ZFG will be hands down one of the best options for the edge with larger than stock turbos. Datalogging is part of the tuning process and is needed in order to adjust the over 2000tables the car references in daily driving. if you have fowled plugs its due to fueling issues which after about 5-10 revisions should be dealt with. Plugs cost no more than 75~90 bucks with shipping, who is charging you 350.00 to change them? National speed is our dyno sponsor and is a fantastic place to get tuned even though they have limited knowledge on the ecoboost 14G371 ECM logic. Its a very complex and not straight forward logic to tune and will usually render low numbers if the user/tuner is not familiar. if changing plugs makes that much a difference most likely the gap and heat range was previously incorrect. In order to judge these numbers we do need to know a comprehensive list of engine mods and parts added. these seem low with aftermarket turbos on 93. you should have seen 450+. Larger compressor turbos can and will cause pressure increase and flow increase causing the computer to add more fuel. This is not an uncommon side affect, and one that can be hard to manage with the fomoco 14G371 logic
this is a loaded section and i am going to try and deal with this whole thing individually
seems like you have positive confirmation as to the problem along with a viable solution. GO FORTH AND PAVE THE WAY! -
the addco bar will work on ALL 15+ edges
welcome and enjoy the new to you ride!!!!
If you need help with the sport let me know! Its super easy to make it fast!
awd disabled can also be triggered from the following: coupler over heat, ptu overheat, transmission 245F+. im willing to be the transmission is tripping the sensors before anything else is. we had the issue towing up long grades. The edge isnt mean for real towing like that sadly. but two additional trans coolers and the trans couldn't be happier and havent had the warning since -
maybe i dont count..... 100K and 500+ wheel hp later. still going strong
Yea thats all they had available for right now and we wanted a benchmark just to see where we are before we figure the fuel out, so we disconnected the driveshaft. Once we figure out the rear coupler we will be hitting up the track for sure! Thanks man! most of the engine parts are in the sig, this whole build is done on stock internals and the point of it is to the capabilities of the platform without cracking open the engine. even though ford says the 3.0 is aluminum it is not. side by side the 2.7 and 3.0 have the same CGI section of the block and the 3.0 is ever so slightly lighter due to being bored im assuming. The 3.0 is a straight drop in and only need the oil pump parameters changed since its different from the 2.7.
Damn, looks like a +35 would have been perfect!
Dont know yet, XD-i may want to trade. if not we will let you know!
