Special_K
    51
Everything posted by Special_K
  1. we run B6 / H&R combo with addco rear swaybar for autocross and have zero issues giving c5 vettes a way to go. Idk what to tell you what happened in your case.
  2. you could do this in the rear but the front is impossible as the perches wouldnt line up
  3. These characteristics are that of a very off alignment and or bad shocks. would start with alignment first. We use the H&R springs on track days and love them
  4. Yea you read that right, 570whp edge! new platform record! we ran out of fueling at 5500ish rpm (redline is 6450) and it pulled boost (25psi to 23psi). Waiting on a new hpfp pump and injectors and we should easily see 600whp!
  5. i know its been awhile since i have logged on, but keep up the amazing work @Xtra!!!!
  6. I really wanna know if i can enable this on a Sport....who is gonna be the Guinea pig
  7. Hey OP! SO short answer..... an aftermarket fmic will help primarily with charge temps and will help with keeping lower charge temps and thus more timing maintaining power and lowering quarter mile times (unknown amount). But stock FMIC temps on a 0-130 MPH pull would start at 75F and end at a steamy 218F with 6 degrees of timing pull. Ambient was 69F (ha). Same day installed an ultimate performance intercooler did a 0-130 pull. Started at 81F ending at 147F, And 0 timing pull. Ambient was 78F. So yes it helps Long answer: To keep production costs down, oftentimes the OEM intercooler is fairly small. It will typically get the job done, but as soon as you start increasing boost pressure or adding bolt-on modifications, the OEM intercooler can hold you back. Adding a larger intercooler without any tuning will not really add any power. The charge air temperature will be lower resulting in denser air, but the larger intercooler can add a slight amount of drag which can somewhat negate any power gains. The real magic of installing an aftermarket turbo intercooler is the ability to run a more aggressive tune without running into detonation. A larger intercooler is also less susceptible to heat soaking, which means you can stay out on the drag strip or race track longer without losing power. Do Intercoolers Add Horsepower? To put it simply: no, a turbo intercooler will not really add any horsepower to your car. It does, however, give you much more wiggle room for a more aggressive tune without the risk of harming your engine. It should be noted, however, that too large of an intercooler can actually do more harm than good. If you have an extremely massive intercooler, you will cause more turbocharger lag and more drag inside the whole system. FAQs: Will a Bigger Intercooler Increase Power? – Without proper tuning, an intercooler by itself won’t increase power by any substantial amount, because your OEM ECU tune may not increase boost or ignite timing when it sees safer charge air temperatures. What Does an Intercooler Do? – The job of your intercooler is simple – cool the hot compressed air coming from your turbocharger before it enters your engine. Will it Decrease Boost Pressure? – Depending on your application, the size of the turbocharger, and the size of the intercooler, it’s possible to see decreased boost pressure after installing an aftermarket intercooler. Do I Need a Tune? – Technically, no you don’t need an aftermarket tune with an aftermarket intercooler for the majority of applications, however, we highly recommend installing an ECU tune or piggyback system to capitalize on your lower charge air temperatures. Luckily you will almost never run into this problem as spatial constraints will force you to run an intercooler that typically isn’t too much larger than the factory unit.
  8. Please refer to the ultimate aftermarket parts list on here, plenty of aftermarket parts and support to solve all of the cons you have listed....only object is money ?
  9. That color and white are hands down my favorite colors on the ST edge. Best of luck on the new ride my man!
  10. All comments regarding parts have been added to the list as of 3/29/2021.
  11. Added good find, added there are many threads on this, please keep this for parts only AFE seems to be preferred since its a dry element. I have yet to try green filter tho.
  12. i would steer clear of LMS like the plague, been down your road, im going to say that you will dyno about 470~485awhp with supporting mods on E. best of luck
  13. Hello and good day ford enthusiasts! I have been working specially with Stephen Dunn (owner and operator of AKD built performance incorporated). He has reached out to support one of our own in support of providing a superior ITCC rear coupling for your all wheel drive differential and a Torsen limited slip differential. I (AKA Colin Bert on Facebook) have post pictures of these too gain support and providing these new products to the market place. They are currently working on a new billet coupler case that will in compass the new clutches and mechanical cam assembly for your electro-magnetic viscous coupler. Viscous coupler has 65% increase in friction surface area, friction material will be a Molybdenum blend material with 600% over stock torque holding!!!! Additionally ADK has designed a new Torsen rear limited slip differential that will work with Fusion, MKZ, MKX, Taurus SHO, Edge Sport, Explorer and MKX However we believe there to be Many more vehicles with the same compatibility within Ford and Lincoln. And believe it or not, some Chevys. We wanted to debut these parts here so you could see them however not currently for sale but will be tested with Special_K & SNMJim (Colin and his dad) on his edge sport. Follow him on IG @fastest_edge For product testing. Here are some pictures for your viewing.
  14. welcome, any pics of the edge?
  15. Updated again: Added Level 10 transmissions and BDR braking solutions
  16. If you're looking for folks that have ALL the Information and how to's, SnmJim and myself are your one stop shops ? We have done everything there is todo with this car and platform and hold the record for the fastest edge ? enjoy the car man and reach out if you need anything
  17. Congrats on the car man, if you wanna make it faster let us know, plenty of folk in here that can help!
  18. thanks man! 11's next year for sure!
  19. New platform record, 12.14@117.10. #worldrecord Plenty of room left in the 60ft, and still figuring out how to get the most out of the 3.0. 11s next year! 3.0 and us are in development still. The swap was in June, trans redone July and we got the car back in late October...... we have only been developing for 2 months with 4 track days. Our track days started at 13s Next was 12.6s Then 12.3s Then 12.1s Just need more development and testing. Our new record was put down with a slower 60' due to spinning more and the rear viscous coupler not being able to keep up (3 later). Also, came across the line in limp mode along with the throttle body only opening ~58%. This 3.0 is kicking and screaming the whole way, but as we smooth things out she is power hungry! Thanks to our all our sponsors, but special shout-out to Adam Staszak with ZFG Racing, Uwe with Xtreme-DI, and Pat with Level10 Transmissions for making a 6F55 that can finally hold the power!!! It wouldn't be possible without ya! If you wanna follow our build check out our instagram @fastest_edge cant wait till next year!!! received_751757195426181.mp4
  20. Hey you guys cant talk about me and not invite me to the chat!!!!
  21. WHY ARE WE YELLING SO MUCH!?!?!? okay got that out of the way, meth is great on most ecoboost platforms. afterrunning it on the edge we found out it starves cylinder 1&4 and floods 3&6. do not recommend if you like your motor ?
  22. Cant wait to see what everyone says about these things!
