kruzr1
Everything posted by kruzr1
Don't know if you completed this yet. There is a YT video of a guy changing plugs on his Fusion with the 2.7 engine. He used a bungy cord to hold that tube aside to reach the back area. That is how I did mine and it worked out great, just be easy with it. My repair manual says to remove that tube also, but I couldn't find a way to reach it either. Also, I used the newest SP-594 plugs.
Looking Beyond Edge being discontinued
kruzr1 replied to enigma-2's topic in Buying, Leasing & Ordering
Mazda recently came out with the cx70. Looks very similar to the Edge in size -
I never had any recalls etc for the TCM on my 2019 ST. There were a few TSBs for software updates. The only recall I had was for the adaptive headlights.
Locked out with both keys inside
kruzr1 replied to 1004ron's topic in Alarms, Keyless Entry, Locks & Remote Start
So I just tried to lock my keys in the car and it would not. I put my key fob in a cup holder and locked the door using the lock button on the door. When I closed the door it automatically unlocked the doors and the horn honked. I do have the intelligent access feature. -
I thought it wasn't possible to lock the keys in the vehicle? Unless you use the number pad on the B pillar by pressing the 7/8 9/0 combination. That actually happened to me once when I was washing an Escape. What are the chances of pressing those buttons while washing the car! Wasn't too funny at the time, but now... lol -
Did you return the lever to the normal position, high beams off? I have used the flash to pass feature to disable/enable the auto high beams once.
Same here on my 2019. No problems
I would stay with the OEM fluids, at least while it's under warranty. Just change them more often.
kruzr1 replied to WWWPerfA_ZN0W's topic in Accessories & Modifications
I've had this happen on my edge also but not quite as bad. I replaced the rear pads, rotors and hardware last summer. I just noticed it is happening again. Only on the rear drivers side also, sure seems kind of odd. I don't notice anything odd during braking. -
You could also use a piece of paper placed between the 2 contact areas. Adjust the stoppers until you have resistance when pulling the paper with the hood closed. I believe this method was also in a Ford SSM.
Might take a look at the sway bar links and also the strut mounts. Disregard, didn't realize you mentioned this already. Must've been half asleep.
change single note horn to dual note horn
kruzr1 replied to Dan H's topic in Accessories & Modifications
I was able to gain access by unplugging and removing the headlight assy. -
You might also need to set your opening height of the liftgate. Manually move the liftgate to the max opening height or wherever you want it. Then press and hold the open/close button until it beeps for confirmation. Hopefully this may be all it needs. I'm thinking it might've gotten confused?
The midsection heat shield on my 2019 ST probably causes some noise. Some of the mounting ears where they attach to the body are broken so it's not as solid. I have a replacement but haven't figured out how to remove the old one yet.
Glad it worked out
I live in Wisconsin and so far I have not had this happen. I'm not sure exactly where your doors are freezing. I usually apply a coating of silicone to the door seals. I also make sure the seal underneath that runs from the front to the rear doors is clean and apply silicone. Probably not something everyone does? I've been using the silicone treatment for years and never have a problem. By the way this isn't just a Ford thing. I worked at a retail parts store and would see people with all different types of vehicles have this issue.
That doesn't seem right. There should've only been approximately the difference between what you drained and what you added come out the level plug. Was your vehicle sitting level when you did the fluid level process? Did the transmission fluid temp reach normal operating temperature?
I've used weathertech before and they installed easily and were durable. Unfortunately they don't make a set for the ST model.
I. would not suggest using the old traditional thick, black coating. Instead consider using something like fluid film, crown etc as mentioned in the video below. You can do it yourself or I have heard there are quite a few business's in Canada that apply this.
Sorry but I'm a little confused on the vehicle application, if someone could clarify I would appreciate it. The TSB says 2015 - 2017 Edge would be eligible for the new oil pan. I thought later years were using the rtv sealant on the oil pan also? Unless it's referring to those years also needing the valve covers. I only have about 35,500.miles on my 2019 but so far have not noticed any oil leaks.
I have an ST also with about 35000 miles. I change my oil twice a year, once in the fall and once in the spring. Which comes out to about 3500 - 4000 miles in between. Never had an issue with oil consumption. Only use full synthetic oil. I do find it hard to get a proper reading on the dipstick sometimes, depending on how I pull it out and which side I'm looking at. I wonder if some of these oil consumption reports might be oil leaks, such as the infamous oil pan, or improper oil refill like omar302 suggested.
- 31 replies
- oil
- consumption
(and 2 more)
Weird issue with A/C Driving vs. not driving
kruzr1 replied to Foxgoku's topic in Interior, A.C., Heat, Interior Trim
I'm definitely not an expert on a/c systems, but isn't 275 a bit high for the high side reading. Did you check/replace the valves in the low and high side ports? -
Remote Start Stopped working
kruzr1 replied to Rob4652's topic in Alarms, Keyless Entry, Locks & Remote Start
Perhaps the battery monitoring system needs to be reset since you had the main battery replaced.
