Sunnyorlando
    2
Everything posted by Sunnyorlando
  1. Thanks for the feedback. I updated the pics with a bit better one where the tips can be seen better.
  2. Having just hit the 100k mile mark on my 2017 Sport, I am working through some recommended maintenance items. First - Spark plugs - while at the dealer for separate small issue with a wheel bearing, I inquired about some of these items. The spark plugs where quoted at $549, which includes 2.5 hrs labor + the 6 plugs. I also called two other major shops and they all landed on the same number of hours, but a slightly different rate. Still spark plugs would have been close to the $500 mark. Second - transmission flush quoted at $249. Third - Brake fluid flush $225 Fourth - serpentine belt $260 Of these items I figured let's look at the ones that I may be able to do. First on the list was spark plugs. I looked up and ordered what the book called for which are the Motorcraft SP594. As recommended in nother forums I stuck with the OEM rather than messing with changing something. After looking at some videos which were not easy to find for the edge sport 2.7 l, I figured I could do this having worked on many cars and motorcycles over the years. To keep the story short, while the book calls while the book calls for an experienced ASE mechanic to do this in 2.5 hrs. I'm sure that an experienced mechanic does this in under 1 hour since it only took me just under 2hrs ( with interruptions) - while I had to study everything that had to be done and had a small issue I had to resolve with a plastic connection, I'm just a hobbyist mechanic and have never worked on this engine. If I had to do this job again, I am sure I can do it in well less than an hour and a half - imagine an experienced mechanic. I know that they have to make money, but this is a huge gap in what it takes an experienced mechanic to do and charge book hours, versus somebody who's never done it before. So basically if somebody that has some mechanical experience is willing to tackle this, it's definitely very doable in 2 hrs or less with just some slight patience. Attached is a picture of what my spark plugs look like at 103k miles. And I say 103k because I assume that they were not changed since I didn't see anything specific in the car maintenance background to indicate they were done any earlier. I've owned the vehicle since 60k miles. I'll be taking the vehicle in somewhere (not the stealer) to have the two flush services done because that's definitely something I don't want to do. I'll then tackle the serpentine belt.
  3. I just posted this update in another headlight thread. May not work with 2016, but sure does with at least the '17 and on with HID. BTW - good quality LED bulbs have come a long ways, and with the newer ones having the LEDs positions line up with the respective halogen elements, they do work pretty good to align with the reflectors.
  4. As posted early on, I was not happy with the HID headlight illumination in my Edge Sport with HIDs. I wondered why Ford had not made use of the already provided high beam position and instead applied only a DRL function. It would have been so simple for them to keep it as a high beam and DRL. So - This is a follow up to my previous post regarding how to make use of the existing H15 and HB bulb position as a high beam. After some initial looking into it, I dropped the project due to time constraints, and I am now following up on it. I was finally able to dig into this and complete the project and it works - Awesome! Anyone who is not happy with the factory illumination from the HIDs headlights and the restricted DRLs now has a solution. And it is an awesome result and I am very happy with it. The H15 LED must be a good quality one that has the LEDs lined up in the correct positions to match up to the H15 elements. And many of the newer LEDs now are doing this, so there are choices. Do no use just any H15 LED - this is critical to make proper use of the reflector in the headlight to the light disperses properly I can see things now ! Attached is a document with detailed instructions on how to do this, and it is quite simple. I hope this helps some. Cheers! 2017 Ford Edge Sport DRL-High Beam Mod 02052024.pdf
  5. 2017 Edge sport 2.7 Why would my check engine light come in when either traction control or ABS activate? When this happens, either the traction control or ABS indicator flashes as it should, then engine light comes on. This has happened 2x now. The last time I reset the light via ForScan. This time I'm going to wait to see if it cycles off. Either way, I'd like to know if there's more to this. Any feedback on this? Thanks
  6. Thanks Bofus.. Both shocks replaced by me - its a simple job as you may know, and I am quite experienced in mechanics. They are not OEM, but they are Monroe (37378) spec'd to OEM (probably makes the ford OEM as the look almost identical) for the sport model. I didn't got with FoMoCo/Motorcraft because well, at 70k mi they were done and had been for a while from what I can tell. So I thought Id try something else. Although is possible that the new shocks could be bad, having the exact same issue on the same side probably rules out the shocks. The parts reused from the old shocks are the boot and the stopper rubber at the top which looked in perfect condition. I did a visual inspection of the bushings, sway bar mounts and related wearable parts - all looked good an nothing out of place. As to a restriction/binding, yep, thats possible right? But I did not have a way to test that movement. I may have to take it in to a shop for a full inspection. I was looking to see if this was a familiar issue with this model. And I agree, it does fell like a bad shock - but what are the chances of the same issue on the same side with new ones?
  7. I have been trying to figure what is going with my rear suspension. As I travel in a straight line of around wide turns, when my rear suspension hits a small series of bumps of imperfections on the road, the rear 'dances', 'hops' or 'chatters' (thats the best desc I can think of) to the right no matter what direction the curve is. It's not noticeable when you hit just one solid bump, but when hit a series of small ones in a row, like ripples, that's you really notice it. There is no noise anywhere otherwise, the suspension sounds solid and the car runs smooth on local roads or highway speeds otherwise. Its just when hitting a series of ripples or bumps. Logic said to check shocks, so I did and I noticed the factory shocks (~70k mi) were seeping. I figured that was it... So I replaced both rear shocks. The issue did not change, it continues hopping. Any experiences with this? Thoughts...? Thanks
  8. My '17 Sport has a Sony audio system that actually sounds pretty good. Good enough to crank it up and get great sound. I like music loud when the sound quality is good - this one can handle it. Just recently I was listening some great tunes when I decided to take up up a notch... And we'll, I was at 28 already (display reading) and took it to the max which is 30. It's still sounded great and without any distortion, so I could have taken it up further and I know the amp is capable of it. However, 30 was the max. Having been in the audio industry in the past, I'm familiar enough with amps, speakers and head units to feel comfortable that this system can handle more. Being that this is all software driven, I'm thinking that this 'max' level is software limited and not an actual amp or head limitation. Anyone here messed with is setting in Forscan? I'd like to believe there's a mod somewhere to allow a higher max. Thanks!
  9. Thank you! This is good information that one hopes to never use. I have in the past with another vehicle and it I found it in the owner's manual, though I have not seen it in this Edge's manual - I may have missed it, or maybe Ford doesn't think it will even be needed - thought they did include the hex hole.
  10. I can also confirm as well that it is available - I just enabled it on my '17 Egde. I am wondering though how to set the actual position desired into memory, because otherwise it just tilts down all the way and I have to adjust it back up - defeating the feature.
  11. The dual filament issue is a non-issue because the DRL goes off when the lights come on. So that leaves the high beams operating on the one filament when the high beams are on, and those housings were originally designed for high beams. As to the power, using a relay you get the power from a good source which can be from several places - that's not a prob The trigger for the relay is a very low draw and it can be done from any source in the headlight that activates when the high beam is selected, like from the HID high beam flapper thing. Frankly, I have built many circuits for electronics and I have never had an issue doing so. I definitely need better headlights than those HIDs, and this might be the solution.
  12. Yes, that is correct. I'd think there's a way to get power to it from the existing wiring. Else - barring that I think can make a simple circuit using a relay to power the hi-beam when the HID triggers the eyelid/flipper that opens the HID for the pseudo hi-beam. There's enough room in the casing to have a small relay just sitting in there. I think that adding that would improve the overall illumination on the road between the two.
  13. The part about the fast flashing to let someone know that a bulb is out is something I'm familiar with. But since no bulbs are out I was wondering what could have caused us to start. And no, I have not installed any LED turn signals. I did not change anything related to turn signals or illumination other than changing the number of flashes, at least that I recall. I will go back and look at the suggestions you're talking about the hyper flash and bulb out indication. As to the DRL and high beam, yes it has an H15 in it and there are three wires going through the connector to the bulb. Are you suggesting that the high beam wire on the other end is not connected to anything? You'd think that Ford would have wanted to save .005 cents for not running that wire there if it's not going to be used, imagine what that would save and weight on the vehicle..? Thanks
  14. Thanks for that explanation - I'm taking it at the type of ODB device is somewhat of a personal choice/opinion apparently, because also I've seen 'don't use an ELM'.
  15. @vegawhat kind of 'programming' are you referring to? The mods listed here with Forscan? Are you saying not to use Forscan with an ODBLink? I bought the ODBLink MX+ as recommended here. Thanks
  16. After the modifications that I did today, I've come across something odd. First - So far the mods made above are working as expected. Then - the turn signals / lane change blinkers. While they actually work as intended, meaning the number of flashes increased to four instead of the default 3, I am now getting a rapid flashing on the indicator in the dashboard, but only there. The actual indicators outside of the car are blinking at the correct rate. Sometimes the first couple of blinks will be at the correct speed, but then it changes to a fast blink, again only on the indicator in the dashboard. The outside flashes correctly. I don't believe that the other changes I did would have an impact on this issue - but you never know. Any suggestions on this are appreciated. Thanks!
  17. I kind of figured it may have been a beta version, but when I didn't see it on the site then I wasn't sure. Often beta versions are offered to be downloaded. After the search box, don't know whatwas happening. So I uninstalled.and reinstalled and now it's there. I've successfully tweet some of the settings on some basic things only while I familiarize myself with a tool. Things that have worked for my '17 Edge sport that are from my original list are: > Rear wiper swipe when in reverse if front wipers are on. > Lane change flashing turn signal from three to four flashes > Side mirrors tilt on reverse > Roll up windows with remote > Emergency horn from remote control from one click to two clicks. This was annoying because I already accidentally turned it on with one click several times. So I'm glad I was able to change that one. That's all I've played with for now. Now that I understand more about the tool I'll be working on trying to get some other features set up and see how that goes. Q - anyone know if the halogen high beams can be activated to complement the hid high beam? Currently the halogen high beam is used for DRL only. I'm wondering if it can be activated so it comes on with high beams because the hid high beams are not really all that good at all by themselves. Thank you all.
  18. @omar302 how is it that you screenshot shows v2.4.3 but the Forscan site is on 2.3. I don't see the search box in 2.3.49 (current v as of 11/18/22)
  19. Well thanks... Ive searched quite a bit and had not come across this site. I've asked about availability.
  20. Ok, I have my ODBII MX3 ordered. Please clarify above - 'peep' which first post? I went to the first post on this thread but nothing matching what your comment. I found it - first post at the Forscan site - duh! Thanks!
  21. The R3 color is Burgundy Velvet Met Tint CC. I'd prefer to wait and hopefully find one rather than try an odd color red. And its the handle, not just the keyhole cover.
  22. I see - thanks for the clarification on that. I'm looking for a front L in R3 color. I've found all other doors, but not driver.
  23. I'm looking for this as well. I looked at 'snmjim' posts but it appears to be about parts, not the procedure. I don't mind digging in, but I'd prefer to know what I'm getting into first. Is there a more detailed explanation or video on changing these spark plugs on a '17 Edge 2.7? I have found many videos on line, but none (yet) on this particular engine and model. Thanks
