Wubster100
    26
  1. See the images in my previous post: https://www.fordedgeforum.com/topic/31501-transmission-flush-or-simple-drain-and-fill/?do=findComment&comment=237850 I tried what you did, to fill the transmission up through the vent hole. However, the fluid was going in extremely slowly and it even overflowed out! So I had to remove the cap piece using pliers. But I had to rotate the metal snap ring around and remove a few things that were close by. It took me a little while to get it off.
  2. Is there any connectivity status in bezel diagnostics?
  3. My 2021 SEL has a spare tire donut. Do you have the storage space under the trunk for a spare tire?
  4. The maximum screen size for SYNC 3 is 10in. So, you can’t just change the display. You would have to change the APIM (to SYNC 4) and the display. As a 2021 owner with SYNC 4, the only advantages I see are a much larger display, and wireless CarPlay / Android Auto. However, the screen size for the rear camera does not increase that much compared to the 8in SYNC 3. And wireless CarPlay / Android Audio can be achieved by using an adapter. You will loose the FCIM, so no hard climate control buttons. And I think you also lose the IPC climate control repeater (I haven’t figured out how to make it work.) Is it possible to upgrade? Yes, many owners of other Ford models have experimented with installing SYNC 4 into SYNC 3 vehicles. It is definitely possible to install and get SYNC 4 to at least power on, but it’s not guaranteed for every single feature to be operational. There is a chance that many features will not work correctly, like climate control, software updates, navigation, etc.
  5. For 2019-2024 Edge / 2019-2023 Nautilus: Use the following codes to correctly change your battery type: 2019-2020 Edge / 2019-2020 Nautilus: BCM 726-04-01 **xx-xxxx-xx 01 = H6 (BAGM-48H6-760), 02 = H7 (BAGM-94RH7-800) 2021-2024 Edge / 2021-2023 Nautilus: BCM 726-04-01 xxxx-**xx-xx 01 = H6 (BAGM-48H6-760), 02 = H7 (BAGM-94RH7-800)
  6. PRE-COLLISION ASSIST – INFORMATION MESSAGES Message: Pre-Collision Assist Not Available Sensor Blocked. Action: You have a blocked sensor due to bad weather, ice, mud or water in front of the radar sensor. You can typically clean the sensor to resolve. Message: Pre-Collision Assist Not Available. Action: A fault with the system has occurred. Have your vehicle checked as soon as possible. Your error message was most likely due to a blocked sensor in front of the camera by the windshield, or radar by the bumper. The blocked sensor error will automatically reset after a key cycle.
  7. That is correct. It is part of the battery load shedding. All proximity lock/unlock will not work except for the driver’s door.
  8. It is due to the battery SoC/health. But I don't want to replace my battery yet because the car still starts up every time.
  9. I like to use the feature when my pockets or hands are full. It’s quick and convenient to just pinch the door handle to lock the car instead of getting the key fob out.
  10. It is a feature. The electric parking brake could apply when you shift to park (P) without the brake pedal fully pressed. The electric parking brake applies when you shift to park (P) on large slopes. The electric parking brake releases with the drive away release function.
  11. What kind of scan tool did you use? What were the other intermittent codes?
  12. If the IPC is unplugged, then there should be codes from other modules for lost communication with IPC. Unless it is a bad code reader.
  13. The IPC is a canbus module, so @2015 Greygoose should try to use their scan tool to see if there is any communication.
  14. Yes it is possible. Look in the Facebook FORD UPGRADES : IPC-mods
  15. 11.62 Qts (11L) (8F35) 12.15 Qts (11.5L) (8F57) - ST The rest of the fluid will remain inside of the torque converter, transmission internal passages, and cooler lines. The owner’s manual states to change the automatic transmission fluid every 150,000 miles. However, if you operate your vehicle primarily under the following conditions, additional maintenance is required. Change the transmission fluid every 30,000 miles: Towing a trailer or using a car-top carrier, extensive idling or low-speed driving for long distances, as in heavy commercial use (such as delivery, taxi, patrol car or livery), and operating in dusty or sandy conditions (such as dusty or unpaved roads).
  16. Field Effect Transistor (FET) Protection The BCM utilizes an Field Effect Transistor (FET) protective circuit strategy for many of its outputs, for example, lamp output circuits. Output loads (current level) are monitored for excessive current (typically short circuits) and are shut down (turns off the voltage or ground provided by the module) when a fault event is detected. A Field Effect Transistor (FET) is a type of transistor that the control module software uses to control and monitor current flow on module outputs. The Field Effect Transistor (FET) protection strategy prevents module damage in the event of excessive current flow. Output loads (current level) are monitored for excessive current draw (typically short circuits). When a fault event is detected the Field Effect Transistor (FET) turns off and a short circuit DTC sets. The module resets the Field Effect Transistor (FET) protection and allows the circuit to function when the fault is corrected or the ignition state is cycled off and then back on. When the excessive circuit load occurs often enough, the module shuts down the output until a repair procedure is carried out. Each Field Effect Transistor (FET) protected circuit has three predefined levels of short circuit tolerance based on a module lifetime level of fault events based upon the durability of the Field Effect Transistor (FET). If the total tolerance level is determined to be 600 fault events, the three predefined levels would be 200, 400 and 600 fault events. When each level is reached, the DTC associated with the short circuit sets along with DTC U1000:00. These Diagnostic Trouble Codes (DTCs) can be cleared using the module on-demand self-test, then the Clear DTC operation on the scan tool (if the on-demand test shows the fault corrected). The module never resets the fault event counter to zero and continues to advance the fault event counter as short circuit fault events occur. If the number of short circuit fault events reach the third level, then Diagnostic Trouble Codes (DTCs) U1000:00 and U3000:49 set along with the associated short circuit DTC . DTC U3000:49 cannot be cleared and the module must be replaced after the repair.
  17. Good idea, as you will be able to use the modern features like SYNC, BLIS, etc. You might have to do some wiring because not all of the connections will be the same.
  18. 2009 MKX: The AWD system consists of the following: PTU Rear driveshaft 4X4 control module Rear axle with coupling device 2011 MKX: The AWD system consists of the following: PTU Rear driveshaft AWD relay module Rear axle with coupling device
  19. Between the 2007 and 2011 Ford Edge and the Lincoln MKX, there were significant electronic and communications system upgrades. Both model years use a combination of High-Speed (HS-CAN) and Medium-Speed (MS-CAN) Controller Area Networks. For Gen 1.5 in 2011, a new Infotainment CAN (I-CAN) was introduced to support the more advanced multimedia features. The 2007 Edge featured a simpler setup, with modules like the Audio Control Module (ACM), Instrument Cluster (IC), HVAC, and Smart Junction Box (SJB) on the MS-CAN, and safety-critical systems such as ABS, PCM, and the Restraints Control Module (RCM) on the HS-CAN. Optional modules included the DSP, parking sensors, and satellite radio. In contrast, the 2011 Edge added far more complexity and integration, especially with the introduction of the MyFord Touch system. The I-CAN network connected new modules like the Accessory Protocol Interface Module (APIM), Front Controls Interface Module (FCIM), and Front Control/Display Interface Module (FCDIM), enabling touchscreen control, voice commands, and smartphone integration. Additionally, the MS-CAN and HS-CAN networks expanded to include more sophisticated comfort and safety systems, such as the GPS module, heated steering wheel, blind spot detection (SOD-L/R), tire pressure monitoring (TPM), adaptive cruise control, and a head-up display (HUD) in certain trims. The 2011 model also transitioned to a more advanced Body Control Module (BCM) that replaced the earlier Smart Junction Box as a central gateway. These changes show a major upgrade in vehicle electronics, transforming the Edge from a traditional SUV with basic electronic systems in 2007 into a modern, digitally connected vehicle by 2011.
  20. Anything is possible if you swap enough parts over and put enough money and time into it. It will be difficult because you are working across 2 different generations (1 and 1.5): Gen 1: 2007-2010 Edge/MKX, Gen 1.5: 2011-2014 Edge, 2011-2015 MKX, Gen 2: 2015-2018 Edge, 2016-2018 MKX, Gen 2.5: 2019-2024 Edge/Nautilus Comparing the 2007 MKX to the 2011 MKX, there are some big changes in the communications network. Both vehicles have a HS-CAN and MS-CAN. The 2011 has a new I-CAN for the infotainment. Note: * = if equipped 2007 MS-CAN: Audio control module (ACM), *Dual climate controlled seat module (DCSM), *Driver seat module (DSM), *Audio digital signal processing (DSP), *Heating ventilation air conditioning (HVAC), Instrument cluster (IC) (gateway module), *Liftgate/trunk module (LTM), *Parking aid module (PAM), *Rear entertainment module (RETM), *Satellite digital audio receiver system (SDARS), Smart junction box (SJB). 2007 HS-CAN: ABS module, *Headlamp control module (HCM), Instrument cluster (IC) (gateway module), Occupant classification system module (OCSM), PCM, Restraints control module (RCM), *Steering angle sensor module (SASM), *4X4 control module 2011 I-CAN: *Accessory Protocol Interface Module (APIM), *Audio Digital Signal Processing (DSP), Front Controls Interface Module (FCIM), *Front Control/Display Interface Module (FCDIM), Instrument Panel Cluster (IPC) (gateway module) 2011 MS-CAN: *Accessory Protocol Interface Module (APIM), Body Control Module (BCM) (gateway), *Driver Seat Module (DSM), *Dual Climate Controlled Seat Module (DCSM), *Global Positioning System Module (GPSM), *Heated Steering Wheel Module (HSWM), HVAC, Liftgate/Trunk Module (LTM), *Remote Function Actuator (RFA), *Side Obstacle Detection Control Module - Left (SOD-L), *Side Obstacle Detection Control Module - Right (SOD-R), Tire Pressure Monitor (TPM) 2011 HS-CAN: *Accessory Protocol Interface Module (APIM), ABS module, Body Control Module (BCM) (gateway), *Cruise-Control Module (C-CM), *Front Lighting Control Module (FLM), *Headlamp Control Module (HCM), *Head Up Display (HUD), Instrument Panel Cluster (IPC) (gateway module), Occupant Classification System Module (OCSM), *Parking Aid Module (PAM), PCM, Restraints Control Module (RCM), Steering Column Control Module (SCCM)
