Platinum White
Everything posted by Platinum White
I asked a question about brake bias some time back. The answer to the best of my recollection is that with rear brakes engaging first minimizes nose dive. On my 2009 Edge that had 150K (traded) had minimum nose dive. I replaced brake pads only once.
Aftermarket tachometer&boost gauge for ST
Platinum White replied to eddie368's topic in Ford Edge & MKX Member Builds
A scan gage can be set to boost, RPM and 2 other parameters at the same time. -
I just installed LED front amber signal lights. Nice and BRIGHT now.
I replaced my puddle lights with LED lights. Much brighter.
I found this after I did one just like this one except I used a manual switch.
Good luck getting the lug nut loose on a roadside with the provided tire tool. I strain using a 24 inch breaker bar.
I have a Ford 2017 Ford Edge Titanium. Page 332 of the owners manual has a torque value of 162 lb.ft. for the lug nuts. WHYIs the torque so High when the torque for an F-150 is 100 lb.ft.? To keep the wheels on is not an acceptable answer.
Page 332 of 2017 Ford Edge Titanium owners manual has a torque value of 162 lb.ft. for the lug nuts. This seems to be very high for a lug nut. I haven't tried to remove one with the tool provided with the spare tire. What is the reason for this torque other than to keep the wheels on?
Where is access to the in line fuel filter? I have had the rear bench seat out and nothing there looked like an access point.
Another marvelous thing produced by designers/engineers who NEAVER work on a vehicle.
I took my catch can off of my 2009 3.5 Edge before trading for a 2017 Titanium 2.0. Could you please provide some pictures and narrative on installing a CC on a 2.0. Thanks in advance.
What does the switch inhibit "checked" inhibit?
2013 Ford Edge SEL Eco Boost Mod Ideas
Platinum White replied to Tyler Bailey's topic in EcoBoost Mod & Tech
what is meth??? -
I found out that an AMSOIL EaO 26 oil filter will fit the engine and it will add almost a quart of oil to the system. Pre fill the filter prior to installation. If you intend to use an EaO 26 filter get the filter cap wrench which will make installation and removal real easy. The filter has been on for about 1000 miles.....NO LEAKS
- 15 replies
- ecoboost 2.0l
- fuel additives
What are the symptoms of a throttle body Acting up?
I'll find out in a week or so. I need an address. How can I contact you? I also have a Lockable hitch pin and a drop ball mount with a 2" ball for $30. Shipping via UPS will be a little <less than $80.
I don't think I can cover the shipping for $50. i'll check with UPS for shipping $$.
I have a Valley hitch that I had on a 2009 Edge for sale for $50 + shipping.
What are the normal parameters for: Oil pressure What is the set pressure for the oil pump relief valve Coolant temperature At what temperature does the cabin heater provide heat
I have a Valley hitch that was on my 2009 Edge. I removed prior to trading in. Was used about 3 or 4 times in 8 years. Specs; 4000 LBS. Max trailer weight 400 LBS. Max tongue weight Fits 2007-2009 Edge or Lincoln MKX I have the original mounting hardware and instructions. Asking $50 + Shipping If local to DFW I'll give directions.
Has anyone found a Sill Plate Cover that fits a 2015 - 2018 Edge?
2.0 ecoboost..how is working in the new Edge?
Platinum White replied to garrett62's topic in 2.0L EcoBoost
I had a Catch can on my 09 edge, removed it when I traded it. I'm trying to figure out how & ware to install it on my 2017 2.0EB. Pictures or other info would be a great help. -
My Scan Gage has a vacuum(-)/boost(+) capability. Works great Plugs into the OBD.
