Check pads without removing wheels?
tji
Most of the time, there is no need to remove the caliper if you just want to see how much brake pad is remaining. The wheel will have to come off though. Calipers have an opening or "window" which allows you to see the pads and the edge of the rotor. This will give you a good idea of how much pad is remaining. You can even measure them to see exactly how much is left.
