gjkrisa Posted August 22 Report Share Posted August 22 i may have been thinking of horizontal wrong i thought that was up and down not left right. Quote Link to comment Share on other sites More sharing options...
gjkrisa Posted August 22 Report Share Posted August 22 i think its a wire today it says the alignment is 0.00 i did push one side off the post then checked the pid for alignment and it was 0 then was like lets see if it changes if i place it back and it did not without driving the vehicle. should i place this info in a different thread? Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 22 Report Share Posted August 22 On 8/20/2026 at 6:07 AM, gjkrisa said: can any one help me figure out how to update the vin? top photo is new working c-cm from a mkx. second smaller photo is my oem c-cm module. my vin is 2FMTK4AP3FBC40639 5LMTJ3DH5HUL21198 this is the mkx vin I have re-read your post and noticed that the VIN you posted for the vehicle if the new CCM is actually a Lincoln MKC, not MKX. The MKC is totally different, maybe the CCM is not compatible regardless of loaded software and calibration. 1 Quote Link to comment Share on other sites More sharing options...
gjkrisa Posted August 22 Report Share Posted August 22 might be right as i can not find where it said the one i bought was the upgraded part. here is oem next to used mkc. they seem very close so i believe i had the right info. Quote Link to comment Share on other sites More sharing options...
gjkrisa Posted August 22 Report Share Posted August 22 ok searched EJ7T-9G768-AF on ford.com says only works for mkc i do think this is reason. Quote Link to comment Share on other sites More sharing options...
gjkrisa Posted August 31 Report Share Posted August 31 yeap i have had similar removing forward collision not work warning. put in a code that may work said it didn’t but did. and then my adaptive cruise started working till july 4th said i had to adjust horizontal alignment. not sure if it was the code or just started to work. of course i reset everything as i couldn’t figure out how to get the alignment right as when i moved it up or down it didnt change but found i need to work on left right when i get the time to remove the bumper. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 7 hours ago Report Share Posted 7 hours ago (edited) On 10/16/2017 at 5:34 PM, ben senise said: I posted the forscan mods that worked, above. now for the ones that didn't work on my '16 Edge Ti 3.5. Timeouts for Heated Steering Wheel This is another one that would be nice to have so i don't have to manually turn off the heated steering wheel. HSWM 714-01-01 Xxxx xxxx xxxx HSWM is Heated Steering Wheel Module. Replace the X with one of the following: 1=Timeout disabled, 8=5 mins, 9=10 mins, A=12 mins, B=15 mins, C=18 mins, D=20 mins, E=25 mins, F=30 mins i got this for the F150 forum and it was marked as not confirmed and that it is possibly an F150 only module. I changed X from 0 to 9 and it didn't work so I reverted to 0. I intend to do more research on these mods that didn't work but in the mean time, if anyone knows what i did wrong, i'm all ears. I installed a new rear OEM camera and in the struggle to get the lines back on the screen I reset everything back to factory, now working to restore all the custom settings such as battery size/type, double honk, front turn signals not doubling up as marker lights, ........ I would enjoy the heated wheel auto turn off - I always have Waze running which means going back to Ford Sync and then touching the small steering heating icon while driving. Of course I want to retain the auto heating when remote starting in winter. Did you or anyone else confirm this auto turn off works? Edited 7 hours ago by 1004ron 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted 2 hours ago Report Share Posted 2 hours ago 5 hours ago, 1004ron said: in the struggle to get the lines back on the screen Don’t forget that the dynamic guidelines will not work right away. You must go for a short drive and rotate the steering wheel in all directions, then the dynamic guidelines will automatically calibrate itself and begin working. Quote Link to comment Share on other sites More sharing options...
1004ron Posted 2 hours ago Report Share Posted 2 hours ago Just now, Wubster100 said: Don’t forget that the dynamic guidelines will not work right away. You must go for a short drive and rotate the steering wheel in all directions, then the dynamic guidelines will automatically calibrate itself and begin working. In my case the dynamic guidelines worked immediately. Quote Link to comment Share on other sites More sharing options...
