Fuel
Ecoboosts run off knock sensing. The tech is meant to run ultralean, and knock data helps determine maximum timing safely available under any given condition. There is no octane sensor as such, it is extrapolated from the knock data and the spark tables the PCM can reference. This is how you discover 93 is not always 93 LOL.
  • Like 3
  • 2 months later...
I've been trying to find out whether the naturally aspirated 3.5 V6 does any timing modification depending upon the type of fuel used.
The manual says that the minimum is 87 octane, and it mentions that EcoBoost engines (which I don't have) should use higher octane fuels when doing heavier work (e.g. towing), however there's not mention whether there's any benefit to using a premium fuel in the naturally aspirated engine.
If nobody knows the answer, I'll call the Ford customer service line on Monday and then report back. :)
All the best,
Andrew.
…there's not mention whether there's any benefit to using a premium fuel in the naturally aspirated engine.
i have a 2016 titanium AWD with the 3.5 V6. i get about 10% better mileage with 89 octane over 87 and even a bit better in the summer. It feels like it's got more pep but that could be influenced by knowing what's in the tank. mileage is empirical but power is subjective since i haven't had the car on a dyno. i've tried 91 octane and don't get better mileage nor do i feel more pep.
of course, your mileage may vary (pun intended!)
Thanks for sharing your experiences, Ben. I guess I can calculate whether there's a 10% difference in price between 87 and 89 octane to determine whether the uprated fuel is worth purchasing. :)
Akirby, what do you mean by "summer blend"? I've only recently returned to the United States from the United Kingdom and was unaware that there was any seasonal difference in fuels.
All the best,
Andrew.
Summer blend fuels typically get better mpg due to the additives, at least in the southern US.
same up here in canada which is why i get better economy in the summer. it might also have something to do with the engine temp at start-up but when i drive, it's usually plenty of time to get to normal operating temperatures.
All the best,
Andrew.
for me the price comes out about the same, give or take a cent or two.
i would think that most countries that have seasonal temperature differences use different blends. some place like the middle east or south-east asia that are just hot all the time might not. knowing UK weather, i would be pretty sure that they do as well.
