frmichaud
Ford Edge Titanium 2016 Remote start
Since the first day I have problems with everything related to external temperature sensor and I have 3 questions
If is is freezing and you remote start your Edge
Does the heating system goes on automaticly?
Does the heating of the driver seat goes onautomaticly?
Does the heating of the steering wheel goes on automaticly?
In my Edge the heater goes ON BUT NOT the steering wheel and driver seat heaters
In my wife Dodge caravan the heating goes on, the driver seat heater goes on and the steering wheel heater goes on
Thanks for your help
Share this post
Link to post
You should be able to adjust this in the settings menu on the left side. Go into Settings, Vehicle, Remote Start. There are settings there for climate control, seats and steering wheel.
Share this post
Link to post
The automatic settings are explained in the owner's manual, page 131.
《Automatic Settings
In hot weather, the system is set to 72°F (22°C). The cooled seats are set to high (if available, and selected to AUTO in the information display). In moderate weather, the system either heats or cools (based on previous settings). The rear defroster, heated mirrors and heated seats do not automatically turn on. In cold weather, the system is set to 72°F (22°C). The heated seats are set to high (if available, and selected to AUTO in the information display). The rear defroster and heated mirrors automatically turn on.》
The manual settings are explained on page 130.
Share this post
Link to post
Thanks very much, I found an english PDF of the manual and it is clear, I received the Edge with a french manual, very very poor translation
Francois
Share this post
Link to post
What do you do if the Climate Control and Seats options are grayed out and you can't adjust them? I thought I read somewhere in here that the dealer could make some adjustments? Thanks.
Share this post
Link to post
I went to Remote start and found
Climate control
Seat or Seat and Whel
Duration
I can only acces to Duration, Climate control and seat are grey and I have no acces
How can I have acces to Climate control and seat
Thanks
Francois
Share this post
Link to post
Climate control
Duration
Thanks
Francois
Sounds like a dealer visit is in order. The HVAC system or FCIM may need a calibration (firmware) update.
Edited by jmr061
Share this post
Link to post
An update of the Firmware of the Edge save the problem now I can select Climate control Auto or OFF, Auto is using the external temperature to set it ON or OFF same for the seats and the steering wheel
Problem SOLVED
  • Like 3
Share this post
Link to post
Trip to dealership - 40 minutes
Update software to fix issue - 45 minutes
Time spent looking at 2018 Explorers - 60 minutes
Trip home - 40 minutes
Not a bad morning.
Share this post
Link to post
You are commenting as a guest. If you have an account, please sign in.
