garycrist Posted June 20, 2024 Report Share Posted June 20, 2024 Yes @Starcr182! It is hard to find the post but, a guy just went through the hoops and Ford did him a deal. Keep searching this site as the post isn't but about a week old. GL P.S. You have to jump through some hoops. 1 Quote Link to comment Share on other sites More sharing options...
CHorsley Posted July 16, 2024 Report Share Posted July 16, 2024 I'm having the same issue with my 2018 Ford Edge. Mine was the 4th cylinder. I just don't have the money for a new engine that can costs up to $10,000 when I'm still upside down on the car as it is. 1 Quote Link to comment Share on other sites More sharing options...
Shiping Posted July 19, 2024 Report Share Posted July 19, 2024 My Car is 2016 Ford Edge SEL AWD, Mileage 80701 found coolant intrusion into cylinder , need REPLACING LONG BLOCK WITH TURBO, WATER PUMP, VACUUM PUMP, BELTS and MISC GASKETS AND FLUIDS get quote from dealer, about $10,000? is this quote reasonable? Any help would be appreciated. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted July 19, 2024 Report Share Posted July 19, 2024 1 hour ago, Shiping said: My Car is 2016 Ford Edge SEL AWD, Mileage 80701 found coolant intrusion into cylinder , need REPLACING LONG BLOCK WITH TURBO, WATER PUMP, VACUUM PUMP, BELTS and MISC GASKETS AND FLUIDS get quote from dealer, about $10,000? is this quote reasonable? Any help would be appreciated. I wouldn't say it is reasonable, but it is probably close to what a dealership gets for the work. The long block is $2,600, not sure why the turbo is included, but the long block doesn't include the accessories, and I would replace the pumps, not the turbo unless something else happened to it. It shows 15 hours of labor, so $3000 if $200 an hour, so not sure where that other $4000 goes. This shows the parts required to do it, a lot of nuts and bolts and gaskets, but $4000 worth? https://static.nhtsa.gov/odi/tsbs/2019/MC-10169807-0001.pdf Quote Link to comment Share on other sites More sharing options...
Starcr182 Posted July 19, 2024 Report Share Posted July 19, 2024 1 hour ago, Shiping said: My Car is 2016 Ford Edge SEL AWD, Mileage 80701 found coolant intrusion into cylinder , need REPLACING LONG BLOCK WITH TURBO, WATER PUMP, VACUUM PUMP, BELTS and MISC GASKETS AND FLUIDS get quote from dealer, about $10,000? is this quote reasonable? Any help would be appreciated. We need a little bit more information. Why is the turbo requiring to be replaced? What codes are getting thrown in the vehicle? How long have you been driving it after the codes have popped up? I swallowed this very large pill about two weeks ago with 77,000 miles did not have anything to do with the turbo they will charge you for an AC system discharge and recharge, and an alignment on top of the long block replacement labor just due to the nature of the task. Quote Link to comment Share on other sites More sharing options...
Shiping Posted July 22, 2024 Report Share Posted July 22, 2024 On 7/19/2024 at 5:46 PM, dabangsta said: I wouldn't say it is reasonable, but it is probably close to what a dealership gets for the work. The long block is $2,600, not sure why the turbo is included, but the long block doesn't include the accessories, and I would replace the pumps, not the turbo unless something else happened to it. It shows 15 hours of labor, so $3000 if $200 an hour, so not sure where that other $4000 goes. This shows the parts required to do it, a lot of nuts and bolts and gaskets, but $4000 worth? https://static.nhtsa.gov/odi/tsbs/2019/MC-10169807-0001.pdf Thank you for information. I'll ask the question to dealer. Really appreciate the help. Quote Link to comment Share on other sites More sharing options...
Shiping Posted July 22, 2024 Report Share Posted July 22, 2024 On 7/19/2024 at 6:17 PM, Starcr182 said: We need a little bit more information. Why is the turbo requiring to be replaced? What codes are getting thrown in the vehicle? How long have you been driving it after the codes have popped up? I swallowed this very large pill about two weeks ago with 77,000 miles did not have anything to do with the turbo they will charge you for an AC system discharge and recharge, and an alignment on top of the long block replacement labor just due to the nature of the task. Thank you very much for the reply. I'll ask for more information. 1 Quote Link to comment Share on other sites More sharing options...
Glenn Morris Posted August 21, 2024 Report Share Posted August 21, 2024 Just paid $8200 for the correct upgraded block due to coolant intrusion. what's more pathetic of Ford is they replaced this defective block in Feb 2022 due to damage from the defective flex plate that cracked with the same defective block, instead of the upgraded one. Even though there were to TSB"S saying to replace etc ? Last Ford I ever own! no wonder their sales sucks, their vehicles suck. Quote Link to comment Share on other sites More sharing options...
HomeLander Posted August 29, 2024 Report Share Posted August 29, 2024 Mechanic here. My wife’s car is a 2017 Lincoln MKC that we bought early in 2020 just before all of this information came out about how terrible the 2.0 design with the grooved cylinder walls and head gaskets were. 71k miles - no extended warranty- still has a car payment. Now we have a po301 code. Cylinder one misfire and it slowly losing coolant. I took out all 4 coil packs and plugs. Checked each cylinder with a borescope. Cylinder one appeared very dirty compared to the others - however no sign of coolant in the cylinder and the plug looked identical to the others. I moved the plug and coil pack from 1 to 2 in hopes that the misfire was a coil pack. The misfire came back the next morning on a cold start and unfortunately is still on cylinder one. What I believe id happening is that while the engine is at operating temp - the head gasket is sealing properly - then as the engine cools of when its shut down - the gasket shrinks and shifts which causes it to leak coolant into the cylinder. Then on startup it misfires momentarily as the coolant is burned off. While the car is running at operating temp it is fine again. Of course this will become much worse at anytime now as the gasket fails farther. So as a mechanic - I will tell everyone that I know - do not under any circumstance buy a ford product. They will not stand behind their cars and refuse to issue a recall to help their customers. After warranty runs out you will be on the hook for a new engine - in our case at 71k miles. I told my wife that this car would be a safe reliable and dependable car - now we will be stuck with a paperweight that still has a payment. Quote Link to comment Share on other sites More sharing options...
nacdj Posted September 22, 2024 Report Share Posted September 22, 2024 I bought Edge 2018 SE, 145k miles from a private user. Foolishly, did not take it to a mechanic for thorough inspection. CEL came in 3 days, P0036, 0302, 0302, 0316 with coolant leaking in to the engine. Local mechanic suggested to replaced the engine. As a last resort, I asked the mechanic to pour the head gasket sealer (BlueDevil). Next day, the car would not start at all. As per the Mechanic; the engine has been sieged. Finally, bought a used engine (2020, Fusion with 57k miles) for $2500.00 & paid the mechanic $1350 to replace the engine & O2 sensor. It has been fixed now, drove the car for 1k mile; so far no issues. 1 Quote Link to comment Share on other sites More sharing options...
nate2985 Posted November 7, 2024 Report Share Posted November 7, 2024 112,000 miles on current 2017 ford edge. Am told that coolant is leaking into the cylinders, and that it is a casting issue. The Ford dealership that inspected the car said that the only true fix would be replacing the engine entirely. Any idea what the average cost of doing that with labor could be? 1 Quote Link to comment Share on other sites More sharing options...
Ford2016 Posted November 9, 2024 Report Share Posted November 9, 2024 You're lucky you made it that far. There's a FB group with 20K+ with this same issue usually around 65K miles. I got quoted $9k this spring. 1 Quote Link to comment Share on other sites More sharing options...
garycrist Posted November 9, 2024 Report Share Posted November 9, 2024 Sometimes...... Quote Link to comment Share on other sites More sharing options...
Dulce Posted November 10, 2024 Report Share Posted November 10, 2024 (edited) I own a 2016 Ford edge SE with 200k + and i used K-seal in two separate occasions (few months apart) and it has resolved the issue for me. best of luck Edited November 10, 2024 by Dulce Quote Link to comment Share on other sites More sharing options...
Got 2 Posted March 28 Report Share Posted March 28 Second post for me. (First was a reply ) 2020 2.0 Eco. I finally understand the block/coolant issue that has plagued the ecoboost for some time. Huge thanx to Fordtechmakuloco! As he points out so well, the block was improved by dropping the coolant "slit" between cylinders and going to a port/tube. That was "during" the 2020 model year. Sooooo...I have just updated from my 2012 3.7 workhorse (really miss it )to a 2020 2.0 Eco. How do I find out if I have the flawed or fixed block? VIN tells me it is an Oakville build production sequence A51877 Thanx Much for any good news, or at least to be prepared for bad news... Dave Wilson 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted March 28 Report Share Posted March 28 3 hours ago, Got 2 said: Second post for me. (First was a reply ) 2020 2.0 Eco. I finally understand the block/coolant issue that has plagued the ecoboost for some time. Huge thanx to Fordtechmakuloco! As he points out so well, the block was improved by dropping the coolant "slit" between cylinders and going to a port/tube. That was "during" the 2020 model year. The Edge got a new engine configuration with a new block in MY 2019 (other vehicles got a revised block mid year 2019). The new 2.0 it got has things like an EGR cooler (which was problematic first couple of years, with a leak and TSB), and the block no longer has slits to the head, as you mention, but a round port. Quote Link to comment Share on other sites More sharing options...
detoothaker Posted March 31 Report Share Posted March 31 So I have the common coolant intrusion issue in my 2018 ford edge 2.0 eco boost. I have a letter to send to Ford Motor company to see what they will do to fix this issue. It is not under any warranty as it just reached over 100k miles. Does anyone know who I could reach out to in order to be sure my letter and complaint goes to the right people. I live in Maine and am finding it hard to find a dealership that will check into this issue for me. Thanks in advance. 1 Quote Link to comment Share on other sites More sharing options...
Ant Posted Sunday at 07:32 PM Report Share Posted Sunday at 07:32 PM So it all started with coolant getting into cylinder 1. I called my ford dealership to see what they recommend and they said long block replacement. I asked for a quick quote for engine replacement and was around 15k. I’m sorry but the car isn’t worth that. So I decided to replace the head gasket and go from there. Now with that all done car stars idle fine but when driving it doesn’t want to get up to speed (loss of power). 1 Quote Link to comment Share on other sites More sharing options...
Ant Posted yesterday at 05:23 PM Report Share Posted yesterday at 05:23 PM Now I’m getting the P0012 code. I did buy 2 new VVT124 installed them and that when the P0012 code came on. Has anyone else have this issue. I don’t really want to just start replacing parts that aren’t needed. Quote Link to comment Share on other sites More sharing options...
1004ron Posted yesterday at 05:33 PM Report Share Posted yesterday at 05:33 PM 8 minutes ago, Ant said: Now I’m getting the P0012 code. I did buy 2 new VVT124 installed them and that when the P0012 code came on. Has anyone else have this issue. I don’t really want to just start replacing parts that aren’t needed. That's why we promote diagnostics, to avoid replacing parts that aren't needed. What prompted you to replace the VVT124's ? Quote Link to comment Share on other sites More sharing options...
Ant Posted yesterday at 05:40 PM Report Share Posted yesterday at 05:40 PM 4 minutes ago, 1004ron said: That's why we promote diagnostics, to avoid replacing parts that aren't needed. What prompted you to replace the VVT124's ? I applied voltage to them to test and they weren’t functioning so instead of taken them apart I figured buying news ones would be best. Quote Link to comment Share on other sites More sharing options...
