Backup camera working intermittently - No Guide Lines
Give it a try
ВСМ
LINsel RVC               726-34-01   xx**   xxxx    xxxx,   ** - 19            0119 0101 00
Slave Exists RVC     726-39-02   xxxx    x*xx   xxxx,   * - 1
APIM
7D0-01-01: x*х*-xxxx-xxxx Change                      8В2А 0103 16
7D0-02-01    5253 1004 E4
IPBM
Linsel RVC   7B1-01-01         xxxx  xx**  xxxx              00
@Iroga
I tried that and either I made a mistake or it just didn't work on my Edge.
Now, I'm in a bit of a panic mode because I have error codes that I have no idea on how to clear - yes, I'm a Forscan novice.
Half way through I had to renew my extended license - $20 for another year.
I have my As Built file but cant figure out how to restore my whole system using it, or just restore the
Quote
The Ford U0155 error code means the vehicle modules have lost communication with the Instrument Panel Cluster (IPC) control module. When you see this code pop up after making changes in FORScan, it typically happens because a module is out of sync, configuration data (As-Built data) was written incorrectly, or the network had a reset glitch during the programming sequence.
This is what I suspect has happened but struggling to find the steps to recover from it.
If you haven't already figured it out, use the "load all" button and then scroll to the downloaded ABD file.
This would restore the values for the selected module only from the selected file and loads on the screen. Then click "Write all" to actually write the values to the module.
If the code is still present, maybe a battery disconnect will help.
Another thing to consider, check if there is a setting in the display for the camera guidelines. I know some Ford models have the setting.
