Dar Posted March 16, 2023 Report Share Posted March 16, 2023 Hello I have a 2013 Ford edge limited and my passenger side headlight has stopped working high beam and low beam if I move the wiring around it sounds like something clicking in the housing but I cannot get the headlight to work?? Quote Link to comment Share on other sites More sharing options...
dabangsta Posted March 16, 2023 Report Share Posted March 16, 2023 Does it have Halogen or HID headlights? I think if you have push button start and power lift gate you have HID. Have you tried removing the cover from behind the bulb and seeing if it is still plugged in and in the socket? There is only 1 bulb for low and high. Quote Link to comment Share on other sites More sharing options...
Dar Posted March 16, 2023 Author Report Share Posted March 16, 2023 Yes I have replaced the bulb made sure my socket is clean but I checked for power in my socket and I'm not getting my test light to light up at the socket but I was told there is separate fuses for the driver side and passenger side headlights so I'm going to check into that when I get home tonight Quote Link to comment Share on other sites More sharing options...
dabangsta Posted March 16, 2023 Report Share Posted March 16, 2023 2 fuses under the dash for control (F16 is the passenger side, F17 is drivers side), high beam is F39Â (but that will only control the gate for low to high, not the actual bulb). Â HID has 2 under the hood, F78 passenger side, F57 drivers side). Quote Link to comment Share on other sites More sharing options...
Dar Posted March 16, 2023 Author Report Share Posted March 16, 2023 Okay thank you I will give them a try Quote Link to comment Share on other sites More sharing options...
Dar Posted March 17, 2023 Author Report Share Posted March 17, 2023 So I replaced the fuses and still nothing Quote Link to comment Share on other sites More sharing options...
pedro2u Posted March 17, 2023 Report Share Posted March 17, 2023 could be your ballast.... Unless I over compilated the repair, I had to pull off the nose/front bumper so that I could get to the ballasts and swap them from side to side..... and it followed the ballast to the other side. A pain to pull the bumper, but I think that might be your next step  1 Quote Link to comment Share on other sites More sharing options...
Dar Posted March 17, 2023 Author Report Share Posted March 17, 2023 Where exactly is the headlight ballast located on this Ford edge Quote Link to comment Share on other sites More sharing options...
dabangsta Posted March 17, 2023 Report Share Posted March 17, 2023 (edited) Have you verified which type of headlight you have, halogen (9012 halogen bulb) or HID (D3S HID bulb)? Â A D3S HIDÂ bulb has a big aluminum box on the back of it, the 9012 Halogen is a simple bulb on a 90 degree base. If you already purchased one, cost difference of $10 or $50. Â Halogen was standard on the 2013 Limited, HID was an option, included in both groups 301a and 302a and optional on 300a. Edited March 17, 2023 by dabangsta Quote Link to comment Share on other sites More sharing options...
Dar Posted March 17, 2023 Author Report Share Posted March 17, 2023 (edited) It is a halogen 9012.... And I do have power to the socket but I've tried three different new bulbs and cannot get the bulbs to light up I got a newtest light and I do have power into the socket but it's not lighting the bulbs up Edited March 17, 2023 by Dar Quote Link to comment Share on other sites More sharing options...
dabangsta Posted March 17, 2023 Report Share Posted March 17, 2023 Which socket are you checking? The one to the back of the headlight housing, or the one inside the headlight housing that the bulb plugs into? Â My 2012 Fusion tried to burn itself down with a short in the internal to the housing wiring. The socket to the bulb was burnt crispy and the wiring was cracked and missing much of the insulation. If you have power then check the ground. Quote Link to comment Share on other sites More sharing options...
Dar Posted March 17, 2023 Author Report Share Posted March 17, 2023 I am checking the socket that the bulb plugs into Quote Link to comment Share on other sites More sharing options...
Dar Posted March 18, 2023 Author Report Share Posted March 18, 2023 I bypassed the bad plug because no one has one but have power at fuse box but not in the wire Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted March 18, 2023 Report Share Posted March 18, 2023 high and low beams work through the use of shutters inside the headlight. you can compare to driver side to see if both are working correctly. Â clicking is when you try to switch back and forth between hi and low beams? or regardless? Â usually not a wiring issue but certainly could be a plug issue OR bcm issue. Quote Link to comment Share on other sites More sharing options...
Dar Posted March 18, 2023 Author Report Share Posted March 18, 2023 How do I go about resetting the bcm? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 3, 2023 Report Share Posted April 3, 2023 There was a guy in the f150 forum that had a simular situation. He tracked the problem to the connector on the back of of the fuse panel. It had worked itself lose. He pushed it back on and his passenger headlight started working again.  The best way to track this is to start at the fuse. Check for test light working by ground lead on frame, pos lead on each side of fuse top (the little metal parts on top of the fuse are for troubleshooting purposes). If you get light on each side of fuse, fuse good.  Then switch the drivers and passengers relays. If problem switched to drivers side, you have a bad relay. If same, check wiring connectio at fuse panel. (Look under pass headlight fuse for wire.)  If good, continue tracking wire into harness and down harness for rodent damage. Basically looking to find exactly where the power stops.  Good luck. 1 Quote Link to comment Share on other sites More sharing options...
