Blk22Edge Posted May 8, 2023 Report Share Posted May 8, 2023 I have a 2022 Ford Edge SEL. My model didn't come with paddle shifters and I want to add them. I've done a couple of custom mods to it. I added an adapter to my recirculation valve, a cold air intake and some exhaust modifications. I'd love to have paddle shifters so I can take full advantage of my mods. I hooked my scan tool (Snap-On Solus Edge) to it and it shows the "select shift" inputs in the TCM. I can get a used wheel with the paddle shifters. Is there a consensus on if it would work? Or would there be some additional programming I'd need to have done to it? 2 Quote Link to comment Share on other sites More sharing options...
PrinzII Posted May 8, 2023 Report Share Posted May 8, 2023 I am wondering if anything has to be done to the PCM. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted May 8, 2023 Report Share Posted May 8, 2023 IF the wiring for the paddles is already there it most likely will work but no guarantee. This worked on the first selectshift equipped vehicle - the 2000 Lincoln LS. 1 Quote Link to comment Share on other sites More sharing options...
Blk22Edge Posted May 9, 2023 Author Report Share Posted May 9, 2023 Looks like there's only one way to find out. I'll have to get a wheel with paddles on it and install it. Update to come soon! 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted May 9, 2023 Report Share Posted May 9, 2023 It might be useful to see if Forscan shows a Select-Shift enable/disable function for your Edge, versus needing to manually program the PCM As-Built entries -- perhaps after comparing your non-Select-Shift Edge's PCM As-Built data to a comparably equipped Select-Shift Edge's PCM As-built data. Wiring diagrams, connector details & locations, a few component removal and installation procedures for you to contemplate... Document download links> Clockspring - 8F35 Trans With Adaptive Steering - Connector C218E Details - 2022 Edge.pdf Clockspring - 8F35 Trans Without Adaptive Steering - Connector C218A Details - 2022 Edge.pdf Clockspring - 8F35 Trans Without Adaptive Steering - Connector C218A Location - 2022 Edge.pdf Clockspring - 8F35 Trans Without Adaptive Steering - Connector C218B Details - 2022 Edge.pdf Clockspring - 8F35 Trans Without Adaptive Steering - Connector C218G Details - 2022 Edge.pdf Clockspring - Removal and Installation - 2022 Edge Workshop Manual.pdf Clockspring + Other Steering Wheel Connectors Locations - 2022 Edge.pdf Upshift Paddle Switch - Connector C2428 Details - 2022 Edge.pdf Downshift Paddle Switch - Connector C2429 Details - 2022 Edge.pdf Paddle Shift - With Adaptive Steering - Wiring Diagram - 2022 Edge Workshop Manual.pdf Paddle Shift - Without Adaptive Steering - Wiring Diagram - 2022 Edge Workshop Manual.pdf Powertrain Control Module (PCM) - Connector 1381B Details - 2022 Edge.pdf Powertrain Control Module (PCM) - Connector 1381B Location, Rear RH Side Engine Compartment - 2022 Edge.pdf Powertrain Control Module (PCM) - Removal and Installation - 2022 Edge Workshop Manual.pdf Powertrain Control Module (PCM) to Internal Transmission Controls - Wiring Diagram 1 - 2022 Edge.pdf Powertrain Control Module (PCM) to Internal Transmission Controls - Wiring Diagram 2 - 2022 Edge.pdf Powertrain Control Module (PCM) to Internal Transmission Controls - Wiring Diagram 3 - 2022 Edge.pdf Powertrain Control Module (PCM) to Steering Wheel Transmission Controls - Inline Connector C238 Details - 2022 Edge.pdf Powertrain Control Module (PCM) to Steering Wheel Transmission Controls - Inline Connector C238 Location - 2022 Edge.pdf Powertrain Control Module (PCM) to Steering Wheel Transmission Controls - Wiring Diagram - 2022 Edge.pdf STEERING COLUMN CONTROL MODULE (SCCM) - 8F35 Trans Without Adaptive Steering - Connector C226 Details - 2022 Edge.pdf STEERING COLUMN CONTROL MODULE (SCCM) - 8F35 Trans Without Adaptive Steering - Connector C226 Location - 2022 Edge.pdf Steering Column Control Module (SCCM) - Removal and Installation - 2022 Edge Workshop Manual.pdf Good luck! 2 Quote Link to comment Share on other sites More sharing options...
Blk22Edge Posted November 15, 2023 Author Report Share Posted November 15, 2023 It took me a while, but I finally added the paddle shifters. I bought a used wheel off ebay for $100 and made sure it had the shifters. Some of the buttons were different and the wheel itself wasn't the nicest. So, I decided to swap the components I needed to my factory wheel, the shifters, rear trim piece and the wiring harness. After getting everything swapped over and re-installed, I hoped for the best but expected the worst. (Warning lights, it not working, etc...) but everything works perfect! A while back I checked the transmission parameters with a scanner and it said "select shift up input high" "select shift down input high" this had me hoping the ecu was able to see a manual shift command if I added the paddles. I'm very happy it all works! 4 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted November 15, 2023 Report Share Posted November 15, 2023 That is an awesome mod! I have a FWD 2019 so it also doesn't have the paddle shifters. They are very handy when towing (I haven't installed a tow hitch yet either), I used them a lot on my 2017 Escape. 2 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted December 19, 2023 Report Share Posted December 19, 2023 On 11/15/2023 at 10:01 AM, Blk22Edge said: It took me a while, but I finally added the paddle shifters. I bought a used wheel off ebay for $100 and made sure it had the shifters. Some of the buttons were different and the wheel itself wasn't the nicest. So, I decided to swap the components I needed to my factory wheel, the shifters, rear trim piece and the wiring harness. After getting everything swapped over and re-installed, I hoped for the best but expected the worst. (Warning lights, it not working, etc...) but everything works perfect! A while back I checked the transmission parameters with a scanner and it said "select shift up input high" "select shift down input high" this had me hoping the ecu was able to see a manual shift command if I added the paddles. I'm very happy it all works! So in looking for a steering wheel used, I can't find one that has adaptive cruise and paddle shifters. But it seems like I only need the rear trim piece, the electronic switches and harness. That all will bolt up to my existing 2019 wheel and the trim piece has the cut outs for them? The more I drive it in the mountains the more I miss manual shift ability. Did you take any pictures of the work you did? Did the wiring to the switches need to be inserted into a connector did the harness for them snap into an unused spot? Quote Link to comment Share on other sites More sharing options...
Brandon123 Posted January 4, 2024 Report Share Posted January 4, 2024 (edited) I have a 2013 ford edge sel that doesn't have paddle shifters and I want paddle shifters but I can't find any kits online, or find any info if it is possible so I was wondering if it is possible and if so where I can get the kit. Edited January 4, 2024 by Brandon123 Add info Quote Link to comment Share on other sites More sharing options...
dabangsta Posted January 4, 2024 Report Share Posted January 4, 2024 Which engine? The 3.5 has Select Shift on the shifter knob (the 2.0 has grade assist I think instead). I think it is harder to find since only the Sport got paddle shifters for that year/range (for the OP and mine AWD vehicles got it, 2015-2018 it was standard). 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted January 4, 2024 Report Share Posted January 4, 2024 Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Brandon123 Posted January 4, 2024 Report Share Posted January 4, 2024 14 hours ago, dabangsta said: Which engine? The 3.5 has Select Shift on the shifter knob (the 2.0 has grade assist I think instead). I think it is harder to find since only the Sport got paddle shifters for that year/range (for the OP and mine AWD vehicles got it, 2015-2018 it was standard). It is a 285.0-hp, 3.5-liter, V6 Cylinder Engine Quote Link to comment Share on other sites More sharing options...
19Edge Posted September 1, 2024 Report Share Posted September 1, 2024 @Blk22Edge just to confirm all you had to do was plug and play a wheel with paddles and all other modules picked them up, or did you have to change setting in the TCM, PCM, ICP? Did you use FORScan to make the changes? 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted September 1, 2024 Report Share Posted September 1, 2024 If you are going to replace your steering wheel, then you might as well look for one that is heated too. 1 Quote Link to comment Share on other sites More sharing options...
Blk22Edge Posted September 4, 2024 Author Report Share Posted September 4, 2024 On 12/19/2023 at 9:37 AM, dabangsta said: So in looking for a steering wheel used, I can't find one that has adaptive cruise and paddle shifters. But it seems like I only need the rear trim piece, the electronic switches and harness. That all will bolt up to my existing 2019 wheel and the trim piece has the cut outs for them? The more I drive it in the mountains the more I miss manual shift ability. Did you take any pictures of the work you did? Did the wiring to the switches need to be inserted into a connector did the harness for them snap into an unused spot? Sorry, I haven’t been on in a while! But I didn’t take any pictures unfortunately. My wheel was all set to have the paddles installed. After getting the wheel off the car it was as easy as: Remove rear cover, remove original wire harness, install paddle shifters (all mounting holes are already in the wheel) install wire harness (this one has 4 connectors 1 for each shifter, 1 to the clock spring and 1 to other buttons) and finally install new rear cover (it has cutouts for the paddles) after I put everything back in the car, the paddles worked flawless. No drilling, no soldering, no cutting or splicing. It was literally 100% plug and play. This was easier than installing my dash cam! 3 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted September 11, 2024 Report Share Posted September 11, 2024 I am considering adding the paddles, and I might as well try heated steering wheel too. Just need to find the parts at the right price. Quote Link to comment Share on other sites More sharing options...
ArkansasEdge Posted January 3 Report Share Posted January 3 On 11/15/2023 at 11:01 AM, Blk22Edge said: It took me a while, but I finally added the paddle shifters. I bought a used wheel off ebay for $100 and made sure it had the shifters. Some of the buttons were different and the wheel itself wasn't the nicest. So, I decided to swap the components I needed to my factory wheel, the shifters, rear trim piece and the wiring harness. After getting everything swapped over and re-installed, I hoped for the best but expected the worst. (Warning lights, it not working, etc...) but everything works perfect! A while back I checked the transmission parameters with a scanner and it said "select shift up input high" "select shift down input high" this had me hoping the ecu was able to see a manual shift command if I added the paddles. I'm very happy it all works! Thank you for this information! Just purchased a ‘22 Titanium Elite and wished it had paddle shifters. After reading your post and seeing we have the same vehicle, took the plunge and ordered a steering wheel off eBay. 2 Quote Link to comment Share on other sites More sharing options...
ArkansasEdge Posted January 12 Report Share Posted January 12 Did the install today. Thanks again for the information! 3 Quote Link to comment Share on other sites More sharing options...
22CarbGrayElite Posted 9 hours ago Report Share Posted 9 hours ago For anyone that did this by buying the switches, the wire harness and the rear cover for the steering wheel, how do the paddles bolt to the wheel? I didn’t get screws for them but I don’t know if they are needed. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted 4 hours ago Report Share Posted 4 hours ago I think most get a used steering wheel, and depending on the wheel, just pull off the switches, back cover, and wiring and put them on their existing wheel, if the one they get is in worse shape than theirs, or doesn't have the right cruise switches. While the switches are available my themselves new or used, I don't think the rear cover is, many steering wheels I see for sale used on eBay they remove the paddle shifters, many have the rear cover with the holes but no paddle/switches. 1 Quote Link to comment Share on other sites More sharing options...
