Paddle Shifter add on
I have a 2022 Ford Edge SEL. My model didn't come with paddle shifters and I want to add them. I've done a couple of custom mods to it. I added an adapter to my recirculation valve, a cold air intake and some exhaust modifications. I'd love to have paddle shifters so I can take full advantage of my mods. I hooked my scan tool (Snap-On Solus Edge) to it and it shows the "select shift" inputs in the TCM. I can get a used wheel with the paddle shifters. Is there a consensus on if it would work? Or would there be some additional programming I'd need to have done to it?
It might be useful to see if Forscan shows a Select-Shift enable/disable function for your Edge, versus needing to manually program the PCM As-Built entries -- perhaps after comparing your non-Select-Shift Edge's PCM As-Built data to a comparably equipped Select-Shift Edge's PCM As-built data.
Wiring diagrams, connector details & locations, a few component removal and installation procedures for you to contemplate...
Document download links>
Clockspring - 8F35 Trans With Adaptive Steering - Connector C218E Details - 2022 Edge.pdf
Clockspring - 8F35 Trans Without Adaptive Steering - Connector C218A Details - 2022 Edge.pdf
Clockspring - 8F35 Trans Without Adaptive Steering - Connector C218A Location - 2022 Edge.pdf
Clockspring - 8F35 Trans Without Adaptive Steering - Connector C218B Details - 2022 Edge.pdf
Clockspring - 8F35 Trans Without Adaptive Steering - Connector C218G Details - 2022 Edge.pdf
Clockspring - Removal and Installation - 2022 Edge Workshop Manual.pdf
Clockspring + Other Steering Wheel Connectors Locations - 2022 Edge.pdf
Upshift Paddle Switch - Connector C2428 Details - 2022 Edge.pdf
Downshift Paddle Switch - Connector C2429 Details - 2022 Edge.pdf
Paddle Shift - With Adaptive Steering - Wiring Diagram - 2022 Edge Workshop Manual.pdf
Paddle Shift - Without Adaptive Steering - Wiring Diagram - 2022 Edge Workshop Manual.pdf
Powertrain Control Module (PCM) - Connector 1381B Details - 2022 Edge.pdf
Powertrain Control Module (PCM) - Connector 1381B Location, Rear RH Side Engine Compartment - 2022 Edge.pdf
Powertrain Control Module (PCM) - Removal and Installation - 2022 Edge Workshop Manual.pdf
Powertrain Control Module (PCM) to Internal Transmission Controls - Wiring Diagram 1 - 2022 Edge.pdf
Powertrain Control Module (PCM) to Internal Transmission Controls - Wiring Diagram 2 - 2022 Edge.pdf
Powertrain Control Module (PCM) to Internal Transmission Controls - Wiring Diagram 3 - 2022 Edge.pdf
Powertrain Control Module (PCM) to Steering Wheel Transmission Controls - Inline Connector C238 Details - 2022 Edge.pdf
Powertrain Control Module (PCM) to Steering Wheel Transmission Controls - Inline Connector C238 Location - 2022 Edge.pdf
Powertrain Control Module (PCM) to Steering Wheel Transmission Controls - Wiring Diagram - 2022 Edge.pdf
STEERING COLUMN CONTROL MODULE (SCCM) - 8F35 Trans Without Adaptive Steering - Connector C226 Details - 2022 Edge.pdf
STEERING COLUMN CONTROL MODULE (SCCM) - 8F35 Trans Without Adaptive Steering - Connector C226 Location - 2022 Edge.pdf
Steering Column Control Module (SCCM) - Removal and Installation - 2022 Edge Workshop Manual.pdf
Good luck!
  • 6 months later...
It took me a while, but I finally added the paddle shifters. I bought a used wheel off ebay for $100 and made sure it had the shifters. Some of the buttons were different and the wheel itself wasn't the nicest. So, I decided to swap the components I needed to my factory wheel, the shifters, rear trim piece and the wiring harness. After getting everything swapped over and re-installed, I hoped for the best but expected the worst. (Warning lights, it not working, etc...) but everything works perfect!
A while back I checked the transmission parameters with a scanner and it said "select shift up input high" "select shift down input high" this had me hoping the ecu was able to see a manual shift command if I added the paddles.
I'm very happy it all works!
  • Thanks 4
So in looking for a steering wheel used, I can't find one that has adaptive cruise and paddle shifters. But it seems like I only need the rear trim piece, the electronic switches and harness. That all will bolt up to my existing 2019 wheel and the trim piece has the cut outs for them? The more I drive it in the mountains the more I miss manual shift ability. Did you take any pictures of the work you did? Did the wiring to the switches need to be inserted into a connector did the harness for them snap into an unused spot?
14 hours ago, dabangsta said:
Which engine? The 3.5 has Select Shift on the shifter knob (the 2.0 has grade assist I think instead). I think it is harder to find since only the Sport got paddle shifters for that year/range (for the OP and mine AWD vehicles got it, 2015-2018 it was standard).
It is a 285.0-hp, 3.5-liter, V6 Cylinder Engine
  • 7 months later...
Sorry, I haven’t been on in a while! But I didn’t take any pictures unfortunately. My wheel was all set to have the paddles installed. After getting the wheel off the car it was as easy as: Remove rear cover, remove original wire harness, install paddle shifters (all mounting holes are already in the wheel) install wire harness (this one has 4 connectors 1 for each shifter, 1 to the clock spring and 1 to other buttons) and finally install new rear cover (it has cutouts for the paddles) after I put everything back in the car, the paddles worked flawless. No drilling, no soldering, no cutting or splicing. It was literally 100% plug and play.
This was easier than installing my dash cam!
  • Like 3
  • 1 year later...
Thank you for this information! Just purchased a ‘22 Titanium Elite and wished it had paddle shifters. After reading your post and seeing we have the same vehicle, took the plunge and ordered a steering wheel off eBay.
  • 7 months later...
I think most get a used steering wheel, and depending on the wheel, just pull off the switches, back cover, and wiring and put them on their existing wheel, if the one they get is in worse shape than theirs, or doesn't have the right cruise switches.
While the switches are available my themselves new or used, I don't think the rear cover is, many steering wheels I see for sale used on eBay they remove the paddle shifters, many have the rear cover with the holes but no paddle/switches.
The screws are needed. I bought a used wheel off eBay to make the switch on mine. The switches are held in place by the screws. The wiring harness had the connectors in place and I didn’t have to swap it out. Just the back cover and the switches.
I will also say that in my ‘22, the shifts aren’t instant like in my Miata. There’s about a 3 second delay from when pulling the paddle until the transmission responds. I’ve learned how to time the shifts, but it did take adjusting to it before enjoying using the paddles.
After doing a little more digging, it looks like the screw is an M4x0.7x10mm.  I’ll just take one of the switches over to Lowe’s or Tractor Supply and test fit them.  I bought the switches and wire harness from one vendor on eBay and the rear cover from another.  I’m in it for $50 so far.  I am going to order a custom leather steering wheel wrap and do that while I have the wheel apart for the button shifters.
  • Like 3
I took one of the switches to Lowe’s and Tractor Supply and didn’t have any luck.  The M4x.70 is too big.  Moving up to an M5 makes it too big.  Gonna hit a junkyard this weekend, if they are open on Saturday, and see if they have any Edges or Fusions to pick at.  Pretty sure Ford doesn’t sell the screws separately but I am gonna stop there in the morning and see.
Stopped at the Ford dealership parts department and as suspected, the screws are not available to buy separately.  In fact, they don’t even come with new paddle shift buttons.  I checked with the mechanics at my job and they only have M4x0.7 screws.
There is a U pull it junkyard around the corner from work.  I looked online and they show four Fusions in the yard and no Edges.  Gonna go Saturday morning after work and hope I get lucky.
