DBEDGE23 Posted June 17, 2025 Report Share Posted June 17, 2025 Thanks. I tightened the oil pan bolts a little and that did wonders for blow by/ oil seeping out. 1 Quote Link to comment Share on other sites More sharing options...
Doorpro Posted June 19, 2025 Report Share Posted June 19, 2025 UPDATE! I finally found a great Ford Dealership not far from home "Ford of Long Beach" who not only told me the whole story of the horribly installed oil pans on 2015 - 2017 Ford Edge Sport with the 2.7L Ecoboost motor and how Ford had tried for years to fix the problem. They had gone through many changes of the oil pan but still used RTV to seal it to the motor which never worked and of course this is a one time use oil pan and I had read of owners on their third and fourth pan change at over $1100 each time. Anyway, they now have a fix in a new pan and gasket which not only did they sell me but gave me the discounted cost so I paid $300 for both parts and not $440 which made me very happy. The part numbers should anyone be interested in fixing this annoying problem are... Oil Pan. FT4Z6675-D Gasket. FL3Z6710-B I hope that this helps. I'm now off to the Auto shop to get the work done and get my wife off my back. If you're in Southern California, Ford of Long Beach is the best. Thanks to all, Regards, Doug. Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 20, 2025 Report Share Posted June 20, 2025 14 hours ago, Doorpro said: UPDATE! I finally found a great Ford Dealership not far from home "Ford of Long Beach" who not only told me the whole story of the horribly installed oil pans on 2015 - 2017 Ford Edge Sport with the 2.7L Ecoboost motor and how Ford had tried for years to fix the problem. They had gone through many changes of the oil pan but still used RTV to seal it to the motor which never worked and of course this is a one time use oil pan and I had read of owners on their third and fourth pan change at over $1100 each time. Anyway, they now have a fix in a new pan and gasket which not only did they sell me but gave me the discounted cost so I paid $300 for both parts and not $440 which made me very happy. The part numbers should anyone be interested in fixing this annoying problem are... Oil Pan. FT4Z6675-D Gasket. FL3Z6710-B Yep. This fix is as per TSB 24-2345. You can read the details in this post. Quote Link to comment Share on other sites More sharing options...
DBEDGE23 Posted July 7, 2025 Report Share Posted July 7, 2025 Thanks Haz and excuse the slow reply. Went under and I tightened all the bolts. They were just slightly loose. No leaks anymore. Quote Link to comment Share on other sites More sharing options...
Meg Posted August 1, 2025 Report Share Posted August 1, 2025 (edited) If we replaced oil pan with part number FT4Z6675D but neglected to do valve covers as referenced in the TSB could that cause the car to start smoking intermittently? My parents have a 2017 Continental with the 2.7 turbo. It has seen meticulous maintenance from them with no issues other than the terrible oil pan leak. In December my husband replaced the oil pan with an aluminum pan purchased on eBay and the OEM gasket. It's an aluminum pan part number FT4Z6675D. A week later they drove 1500 miles to Texas. On the trip my elderly dad thought the engine sounded noisy. He stopped and checked the oil and it wasn’t showing on the stick. He added oil and said it quieted down. He then began checking it and saying it was reading low about every time they fueled up so he was adding more oil. We went to visit them and my husband replaced the PCV valve, looked for leaks, put ats205 in it. Since returning home the car developed intermittent smoking issue. Husband then replaced left side turbo since it seemed to smoke more on that side. Smoke cleared up for about 3 weeks. Car then started smoking again. Another shop checked and says oil (my dad had added again) when car is first started oil reads low and then after an hour reads over full. Their hypothesis is worn valve guides or heads. Car runs great, sometimes smokes, sometimes doesn’t. Brian is wondering if this pan could be causing drain back issues. (Missing or covered passageways?) He did NOT replace valve covers as is referenced in the TSB posted earlier in this thread by @Haz. Could that be contributing? Hoping to get some insight. Have you run into anything like this? We are happy to pay you for consult. Your content has been hugely helpful to him in the past. Thanks for time! Megan Edited August 1, 2025 by Meg Quote Link to comment Share on other sites More sharing options...
garycrist Posted August 1, 2025 Report Share Posted August 1, 2025 Do you have a catch can on your engine? (aftermarket part) Also it takes a little time for the oil level to stabilize for an accurate oil level reading. I have seen "junk" like extra sealant, clog the oil return path and cause the PCV to SUCK oil! (Dodge 2.2L 4cyl. the smoke cleared mosquitos for miles.) BTW the silicone gobs came from it's an over use on the oil pan and valve cover gaskets. Start with something like a https://www.jlosc.com/ then go from there. Check the level in the catch can after each smoke event, to determine where to go from there. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 2, 2025 Report Share Posted August 2, 2025 10 hours ago, Meg said: If we replaced oil pan with part number FT4Z6675D but neglected to do valve covers as referenced in the TSB could that cause the car to start smoking intermittently? My parents have a 2017 Continental with the 2.7 turbo. It has seen meticulous maintenance from them with no issues other than the terrible oil pan leak. In December my husband replaced the oil pan with an aluminum pan purchased on eBay and the OEM gasket. It's an aluminum pan part number FT4Z6675D. A week later they drove 1500 miles to Texas. On the trip my elderly dad thought the engine sounded noisy. He stopped and checked the oil and it wasn’t showing on the stick. He added oil and said it quieted down. He then began checking it and saying it was reading low about every time they fueled up so he was adding more oil. We went to visit them and my husband replaced the PCV valve, looked for leaks, put ats205 in it. Since returning home the car developed intermittent smoking issue. Husband then replaced left side turbo since it seemed to smoke more on that side. Smoke cleared up for about 3 weeks. Car then started smoking again. Another shop checked and says oil (my dad had added again) when car is first started oil reads low and then after an hour reads over full. Their hypothesis is worn valve guides or heads. Car runs great, sometimes smokes, sometimes doesn’t. Brian is wondering if this pan could be causing drain back issues. (Missing or covered passageways?) He did NOT replace valve covers as is referenced in the TSB posted earlier in this thread by @Haz. Could that be contributing? Hoping to get some insight. Have you run into anything like this? We are happy to pay you for consult. Your content has been hugely helpful to him in the past. Thanks for time! Megan There is no Aluminum OEM oil pan for these engines. So the replacement is aftermarket and you have to know exactly which it is. If it was designed similarly to 2018-2020 model years, then yes, the valve covers should have been replaced. Ford did have the below warning (see the TSB in this post😞 CAUTION: Do not use the oil pan with press-in-place gasket on 2015-2017 model year vehicles as this oil pan is not equipped with a positive crankcase ventilation (PCV) check valve. Installation of this oil pan on a 2015-2017 model year vehicle will result in oil consumption which may result in engine damage. 2 Quote Link to comment Share on other sites More sharing options...
Meg Posted August 2, 2025 Report Share Posted August 2, 2025 18 hours ago, omar302 said: There is no Aluminum OEM oil pan for these engines. So the replacement is aftermarket and you have to know exactly which it is. If it was designed similarly to 2018-2020 model years, then yes, the valve covers should have been replaced. Ford did have the below warning (see the TSB in this post😞 CAUTION: Do not use the oil pan with press-in-place gasket on 2015-2017 model year vehicles as this oil pan is not equipped with a positive crankcase ventilation (PCV) check valve. Installation of this oil pan on a 2015-2017 model year vehicle will result in oil consumption which may result in engine damage. Oh that is bad news for us! He is currently replacing the valve covers. No catch can. The seal is OEM, part number FL3Z 6710B. It won't let me post a link a link to the exact oil pan he installed in December, which was off of eBay from Tom Auto Parts. I am going to try and attach the photos of it instead. It lists the following part numbers: FT4Z-6675-A,FT4Z-6675-B,FT4Z-6675-C,FT4E-6675-DB so most likely no check valve and he shouldn't have installed the gasket. Hopefully no engine damage has occurred. Needless to say he is pretty discouraged and regretting the aftermarket purchase. At this point would we be best off to purchase another OEM pan, or reinstall the aftermarket pan without the gasket? He can hardly wait to get started 😢 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 3, 2025 Report Share Posted August 3, 2025 23 hours ago, Meg said: It lists the following part numbers: FT4Z-6675-A,FT4Z-6675-B,FT4Z-6675-C,FT4E-6675-DB so most likely no check valve and he shouldn't have installed the gasket. Hopefully no engine damage has occurred. Needless to say he is pretty discouraged and regretting the aftermarket purchase. At this point would we be best off to purchase another OEM pan, or reinstall the aftermarket pan without the gasket? He can hardly wait to get started 😢 These part numbers seem to indicate replacement for the original pan that was designed for the correct model years with RTV silicone sealant, meaning should be with the check valve. But since it is aftermarket, there are no guarantees. Also, not clear which gasket was used, or whether is affects the check valves operations. If you're asking for a recommendation, it would seem that an OEM pan and gasket from the latest TSB 24-2345 should be the best option. Alternatively, maybe try to contact the aluminum pan's manufacturer for advise. Maybe it would work fine with the correct gasket, or perhaps your issue is not related to the pan. 2 Quote Link to comment Share on other sites More sharing options...
omar302 Posted December 31, 2025 Report Share Posted December 31, 2025 Found on the Fusion Sport forums an updated TSB 25-2395 (attached) for the oil pan leak for 2015-2017 Ford Edge Sport (2.7). TSB 25-2395 supercedes TSB 24-2345, it seems they changed the image to clearly show a gasket, and the procedure now states carrier gasket instead of pressed in gasket, which makes sense as the new gasket is like an aluminum plate with a rubber gasket bonded/attached to it. The oil pan's mating surface is flat. The part numbers all seem to be identical between both TSBs. TSB 25-2395 - Oil Pan.pdf 1 Quote Link to comment Share on other sites More sharing options...
brake.turn.gas Posted February 5 Report Share Posted February 5 Does anyone have a price from the dealer to do the pan replacement. Of the few dealerships near me, none of them have responded to my request for a quote. Quote Link to comment Share on other sites More sharing options...
