Shimmy, shake, jiggle, when >50 mph and accelarating
1004ron
My 2017 Sport is very well maintained with 107K miles on the clock.
It runs very smooth but has a slight drive-line gear whine when above 50 mph and still sending power to the rear, but I can live with that.
More concerning is when on the interstate cruising at speeds above +- 50 mph and accelerate fairly hard, I can feel a shimmy shake which feels like an out of balance wheel, but subsides as soon as I let off the accelerator.
Next weekend I'll be doing a lube service including the PTU, and wanted to hear from you folks what I should inspect to identify the cause of the shimmy shake.
I'll also get the wheels balanced, but doubting that this is what I'm feeling.
My wife's BMW X5 has two of these hydraulic engine mounts, and I have replaced one of them - it leaked oil and was compressed.
The Edge Sport has only one of them on the right side and mine looks compressed/collapsed - see below photo - hows this compare to yours?
If I get off work early enough tomorrow I'll get it up on four jack stands and inspect everything underneath - I always inspect the drive-shaft rubber boots when I do oil changes and they're all in good condition with no lubricant leakage.
@1004ron
I looked at mine and it looks like yours. I cannot determine if it's compressed or not. The rubber "flap" circled in the screenshot below is not compressed and can be moved. It seems like it is there to prevent metal to metal contact on high engine movements or vibrations.
Also there is no oil leaking and no vibrations.  I only have a clunk during throttle tip in after coasting, but I don't think it is from the mounts.
Thanks omar302
That rubber flap on mine is also not compressed, and no oil leaks to be seen - I'm guessing the mount is still good.
Today I got it on four jack stands and checked everything out on the underside, drive shafts, all engine and transmission mounts, prop-shaft as best I could see and feel.
I did an engine oil change and PTU change while I had it elevated - only been 3K miles since I last changed both.
First pulled the PTU fill plug and nothing dripped - was concerned that trans fluid was leaking by the seals, but that's a non-issue now.
The only thing done different was I rotated the wheels - all four tire wear is even, fronts same wear as rears.
I then took it on the interstate and could not invoke the shimmy again, so I'm suspecting one of the wheels that was on the front needs balancing - will be going back to Discount Tires for all four balancing.
I haven't done any further research on the gear whine.
Just last week I changed the PTU fluid and the magnetic plug was clear and the oil looked good.
Sometimes the AWD keeps power to the rear at speeds greater than +- 50 mph and that's when its more prominent.
I back off the throttle and when the power goes to the front wheels only it seems quieter.
Got the wheels balanced at Discount Tires, and as expected they tried hard to use the opportunity to sell me a set of new tires - I declined and went with the free balancing.
They reported minor balance weight changes.
Haven't had the shimmy shake, but if it happens again I'll do more searching.
  • 7 months later...
It seems to be just a little worse - at the onset I've tried a lower gear but no change - it can get pretty severe and directly proportional to the torque applied when in the speed range (55 to 65 mph).
If I'm steady at around 60 mph and accelerate the shake will start - can actually see the hood shake left to right.
After noticing the wear on the inboard edge of the two front tires (see below linked thread) I'm suspecting its tie rods, so this weekend I'll get my wife to assist in jostling the steering wheel while I try to asses which tie rod it is (inner, outer, left, right)
I will change both sides but if it's the outer I'll do both outers, unless I find a rubber boot was the root cause I'll rethink the need to do both sides.
Now, I'm leaning towards going with Motorcraft unless someone can recommend anything better.
In about 15K miles I'll be installing new tires and need this resolved by then.
Today I got it on four ramps and with the engine running had my wife shuffle the steering wheel while I felt every joint and connection and couldn't find a thing.
I got one of our GoPro cameras from work thinking that I'd mount it and record the shake but couldn't find a location to mount it.
I'm not keen to start throwing parts at it so I'll wait until I get a set of new tires and then take it for alignment, which should be in about 5 to 10K miles (2 to 3 months).
Last year I was experiencing a vibration in the steering wheel. The shop I've been going to put it on a lift and put it in gear. As we looked from the rear of the vehicle there was at least one tire that was not running true. You could see the tread moving left and right and it wasn't the wheel. Those were Pirelli  tires, I now have continental tires on and problem solved.
  • 4 months later...
From what you describe I'm guessing yours was evident at specific speeds - mine is only there at a specifc speed range (55 - 65 mph) AND accelerating - light throttle just cruising at any speed has zero vobration.
Tomorrow (11/1/25) around noon I'll have new tires on but don't expect any change to this issue.
On Saturday afternoon or Sunday I'll get in up on four jack-stands, and front wheels off, then scrutinize all potential areas such as the lower control arm buses - if its that I get the complete  lower control arms.
Should I stick with Motorcraft or are Moog and Mevotech acceptable?
https://www.rockauto.com/en/catalog/ford,2017,edge,2.7l+v6+turbocharged,3434543,suspension,control+arm,10401
This video describes what I'm experiencing.
Quote
You feel a shaking or vibration while you drive, but not during quick movements like quick acceleration or turning. This vibration comes through the floor or seat while you gently accelerate.
Recently occasionally when I back out my garage then turn the wheel full lock to the right to move down my driveway I've heard and felt a soft knock on the left front.
I have all my wrenching life avoiding the use of the "Parts Cannon", but that's about to change.
I suspected the left lower control arm bushes or ball joint so a couple of days ago I took a closer look at them, also used a pry bar to see if I could invoke some movement, but none - the inspection method used is flawed in that the control arm is in a taught position with the suspension fully extended.
I've ordered a new Fomoco control arm for $213 delivered, that might arrive in time for installation this weekend or it'll be the next weekend.
