2019 Ford Edge ST (cooled) PTU fluid replacement with pictures
boostededge
Not lot of detailed info on this; only a handful of threads here.
The procedure was pretty simple but has gotchas and other things I didn't really care for. For example the torque on the PTU fill plug, you'll never get 33 ft/lbs on that. I stopped turning before I got to 28 ft/lb and noticed the plug was deeper than when I first took it out and stopped. There's also no way, as mentioned in another thread here, that you can completely remove the PTU cooler without removing the crossmember there. You can however, pull the cooler out far enough to drain the fluid. Make sure not to screw up the o-ring on the cooler though, or you will be dropping the crossmember. Those of you with just a plug here and no cooler don't have to worry about this as your plug comes right out.
Here's the fill plug and PTU cooler with the stud/nut showing. When I opened the fill plug not even a dribble of fluid came out.
I had to use a combo of 1/4" 8mm socket and 8mm flex head closed end ratchet on the nuts. Or you can drop the exhaust.
I kept the 1-piece stud/nut and just reused them.
The PTU cooler pops out easily, or as much as it can before hitting the subframe. The coolers metal rod elements extend the length of PTU basically.
Here she is draining. You can see the o-ring - do not mess it up.
Brake cleaner will be your exhausts best friend.
I'd say I spilled an ounce or more other than what's in the container but I tried to measure what came out of it.
In the sun. Didn't look too bad I thought for ~35k miles but idk.
Reinstalled PTU cooler and cleaned everything up. Inserted the stud/nuts and torqued to 97 in/lb
Here's what I use to fill up transmissions and differentials. Just a regular water vacuum pump you can get on Amazon for $10. Easy peasy no mess no pumping just press a button.
I put as much oil as it would take until it started streaming out. Then I spun the tires several times by hand and waited a few more minutes before pumping more fluid in.
When the stream stopped and turned into a drip I put the fill plug back on with some thread sealant. Like I said above I don't like how Ford says 33 ft/lbs on the fill plug - that's not happening at least on mine.
All cleaned up and done. I'll check the level again in 100 miles or so. The fill plug is inserted further than it was from the factory at 28ft/lbs. Be careful with aluminum.
And that's pretty much it. It should take about an hour if you have access to a lift. As with everyone else, I have no idea why Ford couldn't put a drain plug other than to purposely let PTU's eat themselves after the warranty period.
Edited by boostededge
  • Like 5
  • Thanks 3
Exactly the way I would do it. You did a great job on the pictures too. Thank you!
I would bet the fiber gasket stays in its place if you pop the cooler straight out, or you wouldn't be able to re install the cooler as it would block the passage.
Ford was hoping no one would come up with an easy solution so they could sell a new ptu when they explode right out of warranty!
My thought and hope as well. When I reinserted the cooler it "felt" good and "clicked/plopped" into place. A feeling I would get if an o-ring connection was seated. At least that's what I tell myself :)
Not to get off track here, but did you notice the electric motor in line to one of the cooing hoses attached to the cooler?
 I was more curious about it and one day I climbed under the car right after I shut it off.  I heard the electric motor running, circulating coolant through the PTU.
Hot coolant is circulated through the PTU after shutting down. I don't have any info at what point the electric motor turns on and off and what temperature, but if the Hot coolant is used to cool the PTU, that thing must get pretty darn hot!  Interesting...
  • 2 months later...
I have a 22 ST.  Is the procedure the same, or is it a different PTU now?  Also, I noticed in the original post and comments it is mentioned that the stud/nuts were tightened to 97 in/lb torque.  Do you mean 97 ft/lbs instead?  I've never heard of in/lbs.
Ok, I got under the car and found the cooler and fill plug.  Looks the same as the photos posted originally by boostededge.  I only have ramps, so it definitely would be tight to get in there, but looks like it could be done.  With ramps I wouldn't be able to turn the tires and squeeze more fluid in either.
Also, just wondering if a failure happens by chance after I did this if Ford could tell it has been tampered with/changed and since it wasn't done at the dealer they might not cover it under my Ford ESP extended warranty?  They might say I did something wrong.
Edited by Davidoo
  • 2 months later...
  • 3 months later...
@boostededge - are your photos still available or the links are dead? I can't see the photos. Could you consider updating your post? I have 2022 ST and I'd love to check PTU on mine this summer. Time for full fluid service in my ST:) Thanks!
They still show for me.
https://i.ibb.co/nqz2chYt/PXL-20250410-182114947.jpg
https://i.ibb.co/V0WGVyJP/PXL-20250410-192117856.jpg
https://i.ibb.co/qYxTJ5t9/PXL-20250410-192239964.jpg
https://i.ibb.co/603hHsSw/PXL-20250410-192305765.jpg
https://i.ibb.co/k6WB0c95/PXL-20250410-193054966-MP.jpg
https://i.ibb.co/mVyqJ0hB/PXL-20250410-200603818.jpg
https://i.ibb.co/DHJDLQj3/PXL-20250410-204657626.jpg
https://i.ibb.co/847d6NLW/PXL-20250410-193705384.jpg
  • Sad 1
Please don't flame me but I was wondering if I could just take the fill plug out and fill it with new fluid to the fill plug level instead of draining the fluid that is already in there.  That is what I was thinking about to avoid dealing with an error where the fiber gasket comes off or the oring gets damaged.  I have a 22 ST but I had a 2016 Edge Sport before I gave that to my daughter and it now has 140,000 miles in it.  I didn't change the fluid until 120,000 miles(done at local shop).  The fluid in that still looked OK but was dark.
Of course you can BUT . . ..
Adding new fluid to " top off " the old fluid does extend the use of the old fluid to some amount, but does not equal actually replacing the old fluid with fresh fluid
What do you do when the fluid level of the PTU is FULL and you can't add any new gear oil?
Unless you have evidence that the PTU is leaking, there is no need to add fluid.
If the PTU fluid has been in there at least 20K miles, then you need to change it out completely.  Forget the fact the manual says the PTU fluid is good for 30K miles.  Go with that if you wish but at 20K miles, mine was a dirty, dark brown fluid.  You have to remember that the PTU is sandwiched between the transmission, engine and exhaust systems.  That is a pretty hostile environment, adding to the fact the amount of PTU fluid is small.
And, there is no need to pull the PTU to drain the old fluid.  You can literally use a vacuum unit designed for fluid removal to vacuum ( suck ) all the PTU fluid out and then pump all new fluid into the PTU for the refill.  That is what I did and it works easily with zero mess.
Edited by Samurai Edge
  • Like 5
