Mistro399 Posted May 8, 2025 Report Share Posted May 8, 2025 (edited) Hello. New to the forum so hopefully I’m doing this correctly. Bought a used 2016 Edge Sport 2.7l with 106k miles. Great maintenance history, it’s a Canadian version now in WA state. Had it pre-inspected by mechanic and only issue found was oil pan had a small gasket leak. Mechanic replaced with Dorman OE aluminum pan. When on the freeway at 70mph I can accelerate hard and every time at 82 mph and around 5,600 rpm it cuts out suddenly, then a few seconds later the “Low Engine Oil Pressure” warning flashes for one second and then everything runs normal. No engine light, no code, and no code to clear in the system after the warning. I don’t know if it did this prior as we took it straight in to get fixed. Oil looks perfect, mechanic states oil looked perfect when he inspected pan, inlet tube, and so forth. Ford states it is not “limp mode” and it is not a speed or rpm limiter setting issue as that would give warnings and shut down cylinders. I see 3 Admin keys in the system but no mykey. My mechanic had it hooked up to diagnostics computer and drove it for 1/2 an hour and made it repeat the issue every time. He replaced oil pressure sending unit. No change. My mechanic states Ford should wipe out admin keys, and start fresh with factory ECM/Transmission settings. Ford said that won’t do anything. Oil pressure maxes out at about 40 psi under hard acceleration, and mechanic states it looks to be working great so he doesn’t think it is an oil pump issue. Mechanic states he has used these oil pans on dozens of edges and never had an issue. He is stumped. Any thoughts? Edited May 8, 2025 by 1004ron 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted May 8, 2025 Report Share Posted May 8, 2025 42 minutes ago, Mistro399 said: Hello. New to the forum so hopefully I’m doing this correctly. Bought a used 2016 Edge Sport 2.7l with 106k miles. Great maintenance history, it’s a Canadian version now in WA state. Had it pre-inspected by mechanic and only issue found was oil pan had a small gasket leak. Mechanic replaced with Dorman OE aluminum pan. When on the freeway at 70mph I can accelerate hard and every time at 82 mph and around 5,600 rpm it cuts out suddenly, then a few seconds later the “Low Engine Oil Pressure” warning flashes for one second and then everything runs normal. No engine light, no code, and no code to clear in the system after the warning. I don’t know if it did this prior as we took it straight in to get fixed. Oil looks perfect, mechanic states oil looked perfect when he inspected pan, inlet tube, and so forth. Ford states it is not “limp mode” and it is not a speed or rpm limiter setting issue as that would give warnings and shut down cylinders. I see 3 Admin keys in the system but no mykey. My mechanic had it hooked up to diagnostics computer and drove it for 1/2 an hour and made it repeat the issue every time. He replaced oil pressure sending unit. No change. My mechanic states Ford should wipe out admin keys, and start fresh with factory ECM/Transmission settings. Ford said that won’t do anything. Oil pressure maxes out at about 40 psi under hard acceleration, and mechanic states it looks to be working great so he doesn’t think it is an oil pump issue. Mechanic states he has used these oil pans on dozens of edges and never had an issue. He is stumped. Any thoughts? Welcome. If the engine cuts out it's expected that the low oil pressure light comes ON. I think you should find a more qualified mechanic or consider a good Ford dealership. They changed the low oil pressure switch, but maybe they should have looked at the oil pressure regulating valve? I recommend using Forscan to scan for codes. Post some detail on the OE oil pan. Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 8, 2025 Report Share Posted May 8, 2025 2 hours ago, Mistro399 said: Oil pressure maxes out at about 40 psi under hard acceleration Shouldn't it go higher? I remember at idle it it should around 20 something and it can reach 70 something on load. Edit: found a screenshot I made here before. 1 Quote Link to comment Share on other sites More sharing options...
Mistro399 Posted May 8, 2025 Author Report Share Posted May 8, 2025 1 hour ago, omar302 said: Shouldn't it go higher? I remember at idle it it should around 20 something and it can reach 70 something on load. Edit: found a screenshot I made here before. I thought the same thing? I thought 50-65 was normal and 70 should be fine at high rpm’s. Guess I’ll call a different dealership. Thanks! Quote Link to comment Share on other sites More sharing options...
Cossie Posted Friday at 03:37 PM Report Share Posted Friday at 03:37 PM I’m having exactly the same problem. I replaced the OEM oil pan with an aluminum one, and the issue cropped up on the highway at 170 km/h—or at around 145 km/h in "S" mode. In city and country driving, the car runs perfectly normally—just as zippy and agile as ever. It just doesn't like high speeds anymore. I’ve ordered an oil pressure sensor and a new oil filter. If that doesn't work, would I have to switch back to the plastic pan? Edge 170kmh.mp4 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Monday at 03:40 PM Report Share Posted Monday at 03:40 PM Mistro399: Did you ever solve this problem? To both Mistro399 and Cossie: You didn't state under what conditions the engine shut off has occurred. Were you driving in a straight line or taking corners when this issue rises? I have no idea what specific aluminum pan you are both referring to but it sounds like a possible oil starvation issue. Not knowing the specific internal design of the aluminum pan vs the OEM pan leaves a big unknown. Just because something will fit does not necessarily make it a good choice. Quote Link to comment Share on other sites More sharing options...
omar302 Posted Monday at 06:19 PM Report Share Posted Monday at 06:19 PM 2 hours ago, Samurai Edge said: Not knowing the specific internal design of the aluminum pan vs the OEM pan leaves a big unknown. Just because something will fit does not necessarily make it a good choice. +1 Also, as the design changed between 2015-2017 compared to newer models, does it have the correct check valve for the PCV. Quote Link to comment Share on other sites More sharing options...
Cossie Posted 7 hours ago Report Share Posted 7 hours ago Hello Samurai Edge, I’ve been getting this error message on my Sport (2.7L, 108k) ever since I installed the aluminum oil pan. The vehicle doesn't shut off; it just briefly throttles the speed and continues driving normally, though it won't go faster than 170 km/h. My car has had its speed limiter removed; previously, it was capped at 211 km/h -2018 Import to Germany. After the unlock in 2019, I did a test run up to 244 km/h—which was fast enough for me. I first noticed the issue during an overtaking maneuver that I couldn't complete because the car slowed me down. Up to 170 km/h, the car drives completely normally. In Sport mode (S), the error kicks in earlier (at 145 km/h) than in Drive mode (D). The plastic oil pan was replaced, and I suspect the issue lies with the intake pipe in the center of the pan. The plastic version has a wider oil inlet there, whereas the aluminum pan has very little clearance milled out around the pickup pipe. I don't know for sure if that's the reason, though. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 6 hours ago Report Share Posted 6 hours ago This looks like your oil pan: https://ford.oempartsonline.com/oem-parts/ford-oil-pan-ft4z6675d What I am not seeing / finding is an oil pan pick-up anywhere I look. That could be the problem right there. The oil pick-up, being smaller on the aluminum pan sounds like the culprit. A smaller than designed oil pick-up could create an oil starvation issue, but that's my thought. When you look at the oil pick-up area on the OEM pan, it looks like that white " plastic cover " creates a larger area for the oil to gather for pick-up into the motor. The aluminum pan has no such area but pick up directly from the open pan area. A typical oil pick-up has section at the end of the pick-up tube that sits bathed in the oil to suck in the oil in the pan. I think the OEM white " plastic cover " is that section I described above which is clearly missing from the aluminum pan. Presuming you didn't change anything else, looks like you know your issue. Quote Link to comment Share on other sites More sharing options...
omar302 Posted 6 hours ago Report Share Posted 6 hours ago 17 minutes ago, Samurai Edge said: That could be the problem right there. The oil pick-up, being smaller on the aluminum pan sounds like the culprit. A smaller than designed oil pick-up could create an oil starvation issue, but that's my thought. +1 I am not able to see what it picks up. The hole seems closed off and as if it can't suck any oil!! Also, as there is an oil pressure sensor, the engine output is probably being cut when pressure is dropping. And on S being earlier is probably because it doesn't upshift to 6th and engine speed is staying at a higher RPM longer compared to D where it would upshift to 6th. 1 Quote Link to comment Share on other sites More sharing options...
Cossie Posted 6 hours ago Report Share Posted 6 hours ago Thanks for your Answer, That’s what I suspect, too. The design of the intake pipe cover allows more engine oil to accumulate, ensuring it gets drawn in. In the aluminum pan, there is likely too much turbulence at speed, which hinders the intake process. So, I’ll probably have to buy a plastic pan—if I can still find one. My search has revealed that none of the spare parts suppliers in the USA ship to Germany. Quote Link to comment Share on other sites More sharing options...
Cossie Posted 6 hours ago Report Share Posted 6 hours ago Omar302, "The opening appears to be sealed" – no, it is a wide gap, roughly 1 cm high and 6–7 cm wide, allowing the oil to flow in. This means the oil at the bottom is shielded from the flow occurring above the intake pipe. The higher engine speed in S mode makes sense, as more oil is being pumped, meaning there is insufficient oil available at the bottom for a brief period. And, as Samurai Edge also suspects, the missing cover in the aluminum sump is likely the cause of the issue. 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted 5 hours ago Report Share Posted 5 hours ago @Cossie you could attempt to make a similar "baffle" from aluminum replication the white plastic one seen on the original pan. Also, what about running with a slightly higher oil level, like an additional 500ml? Are you using the original dipstick? Quote Link to comment Share on other sites More sharing options...
1004ron Posted 5 hours ago Report Share Posted 5 hours ago 44 minutes ago, Cossie said: So, I’ll probably have to buy a plastic pan—if I can still find one. My search has revealed that none of the spare parts suppliers in the USA ship to Germany. You could use a drop shipping company. Buy from US ship to Germany | Free US Address 2 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 4 hours ago Report Share Posted 4 hours ago 31 minutes ago, 1004ron said: You could use a drop shipping company. Buy from US ship to Germany | Free US Address I was wondering if there was something like that. Good idea! 💡 Quote Link to comment Share on other sites More sharing options...
