flymore Posted Tuesday at 09:45 PM Report Share Posted Tuesday at 09:45 PM I asked Google when I should change the coolant in my 2018 Ford 3.5l. Google AI said every two years. Tested the coolant using the multimeter method described in this video, after 2 years it still reads ok. Should I get my coolant changed? Thanks Quote Link to comment Share on other sites More sharing options...
1004ron Posted Tuesday at 11:25 PM Report Share Posted Tuesday at 11:25 PM Not sure if its different on your model/year but if its the 3.5L with internal coolant pump then search the forum for the coolant change recommendations - later M/Y's may have addressed the issue?. Quote Link to comment Share on other sites More sharing options...
fishx65 Posted Wednesday at 01:26 AM Report Share Posted Wednesday at 01:26 AM I've always just done a radiator drain and refill every 3rd oil change. Motorcraft yellow concentrate is pretty cheap and the 3.5's internal water pump bearing issue always frightened me. My 2011 SEL 3.5 just hit 160,000 with no issues. Quote Link to comment Share on other sites More sharing options...
flymore Posted 10 hours ago Author Report Share Posted 10 hours ago Yes, mine is a 2018 3.5L with the internal water pump. Yea, I changed from orange to yellow coolant 2 years ago and am considering changing it again. Thanks Quote Link to comment Share on other sites More sharing options...
