William Parks Posted December 6 Report Share Posted December 6 (edited) Radio keeps switching from satellite to fm and I can not activate satellite radioš¤Ā it's a 2010 SEL with original radio.Just got it and I have done no work to the radio to cause any problemsĀ Edited Monday at 12:55 PM by William Parks Quote Link to comment Share on other sites More sharing options...
edjunior Posted Monday at 01:42 AM Report Share Posted Monday at 01:42 AM I may or may not be able to provide any help for you, but no one can unless you provide a bit more information.Ā Year, trim, is this a new to you car, have you done any work on it that may have affected the radio, etc.Ā Welcome to the forum. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted Monday at 01:57 AM Report Share Posted Monday at 01:57 AM 13 minutes ago, edjunior said: I may or may not be able to provide any help for you, but no one can unless you provide a bit more information.Ā Year, trim, is this a new to you car, have you done any work on it that may have affected the radio, etc.Ā Welcome to the forum. @William ParksĀ please add that to your profile signature -Ā https://www.fordedgeforum.com/settings/signature/ Quote Link to comment Share on other sites More sharing options...
William Parks Posted Monday at 12:39 PM Author Report Share Posted Monday at 12:39 PM 2010 SEL Edge original radio Quote Link to comment Share on other sites More sharing options...
Blk22Edge Posted Monday at 01:23 PM Report Share Posted Monday at 01:23 PM On 12/6/2025 at 3:10 PM, William Parks said: Radio keeps switching from satellite to fm and I can not activate satellite radioš¤Ā it's a 2010 SEL with original radio.Just got it and I have done no work to the radio to cause any problemsĀ When you say switching, do you mean when you select Satellite, it immediately goes back to FM? Or does it switch between the two on its own? Also, does it switch back to FM if you select AM or another source? Quote Link to comment Share on other sites More sharing options...
William Parks Posted Monday at 01:44 PM Author Report Share Posted Monday at 01:44 PM (edited) When I set it to satellite a couple seconds later it switches to fm Ā all by itself,only does this when set to satelliteĀ Edited Monday at 01:48 PM by William Parks Quote Link to comment Share on other sites More sharing options...
Blk22Edge Posted Monday at 02:58 PM Report Share Posted Monday at 02:58 PM (edited) 1 hour ago, William Parks said: When I set it to satellite a couple seconds later it switches to fm Ā all by itself,only does this when set to satelliteĀ Those couple seconds before it switches to FM, does it play the preview channel or is there no sound at all? There may be an issue internally with the radio or the Satellite antenna. I'd lean towards an issue internally with the radio though. You may have to swap it out with either a new aftermarket head unit or a used factory head unit. Edited Monday at 03:08 PM by Blk22Edge Quote Link to comment Share on other sites More sharing options...
William Parks Posted Monday at 06:17 PM Author Report Share Posted Monday at 06:17 PM When 3 hours ago, Blk22Edge said: Those couple seconds before it switches to FM, does it play the preview channel or is there no sound at all? There may be an issue internally with the radio or the Satellite antenna. I'd lean towards an issue internally with the radio though. You may have to swap it out with either a new aftermarket head unit or a used factory head unit. I set it to satellite a couple seconds later it switches to fm all by itself No no preview or sound Quote Link to comment Share on other sites More sharing options...
garycrist Posted Monday at 06:58 PM Report Share Posted Monday at 06:58 PM Have you done a factory rest yet ? Soft is Power and seek up buttons simultaneouslyĀ for 5 secondsĀ (>>I seek up button) Or, do a master resetĀ from general settingsĀ of the radio menu. Ā Quote Link to comment Share on other sites More sharing options...
William Parks Posted Monday at 07:51 PM Author Report Share Posted Monday at 07:51 PM I tried a soft reset volume and seek up but nothing happened, I held the buttons a good 15 seconds.I thank you for your time in respondingĀ Quote Link to comment Share on other sites More sharing options...
dabangsta Posted Monday at 08:46 PM Report Share Posted Monday at 08:46 PM While there are 3 possible configurations for your SEL (standard 6 disc with 4 speakers, SYNC added, or navigation premium sound with 9 speakers), SYNC can require a hard reset, which is done either by removing the fuse (#3 under the dash), the radio (fuse 28), I haven't had a vehicle with stand alone satellite module (fuse #13), or pulling the negative battery cable. Ā I don't know how accessible the fuse panel in yours is, but in my 2012 Fusion, it is easier to pull the battery cable (for ~20 seconds, and turning on the headlights to be sure to discharge power, often if I don't do that, it will not reset, and I can tell because I don't lose time or radio presets). Ā If it has never worked, as suggested, a master reset would also be a good idea. Get rid of the previous owners phones (if it has SYNC/Navigation), do you have a Sirius/XM account? Are you expecting it to work, or hope it has lifetime, or the previous owner left their account active? Quote Link to comment Share on other sites More sharing options...
William Parks Posted Monday at 09:38 PM Author Report Share Posted Monday at 09:38 PM Well to simplify things I just purchased a new radio it needs upgrading anyway the old one. Is dinasourĀ Quote Link to comment Share on other sites More sharing options...
