john5678 Posted April 30 Report Share Posted April 30 Bought a 2015 Ford Edge SEL 3.5L a couple months ago. A few days after buying it, I drove about 50 miles and got an “AWD Disabled” message. I clicked okay, but it came back, then the wrench light showed up and it started to smell like propane. I pulled over, let it cool, and drove home. After that, the message would come back after about 10 minutes of interstate driving, until it eventually started making noise after a week or so. I contacted the lot I bought it from and they seemed willing to help. A scan showed P183D (PTU over temp). We both figured it was the PTU, but decided to try changing the fluid first. That helped for about 2 days of driving, then the AWD message came back. Took it back, and they said the PTU was likely damaged, I agreed. I asked for a replacement with a warranty, but they ended up installing a used PTU with no warranty. First interstate drive with that unit, AWD Disabled came on after about 20 minutes. A couple days later, it was down to about 10 minutes again. Even after clearing codes, P183D keeps returning, especially after interstate driving. Note there's also a U3003-16 low voltage in the traction control, but I don't know if it's related. Now I’m getting a rubbing/grinding type noise, no smell. It sounds like it’s mostly coming from the rear this time, with occasional different noise from the front. The issue seems to show up more at higher speeds on the interstate, and that's when it threw the last code. My own mechanic checked the differential lube and said it seemed fine... thinks the replacement PTU might have been a bad unit. The lot owner is somewhat working with me, but I told him in my opinion either the replacement PTU is bad, or something is causing them to fail. When I got home, I did some tight turns in a parking lot, and it behaves like a 4x4 on dry pavement, it grabs/binds when turning at low speeds. The dash power distribution screen shows all 4 wheels engaged up to around 50 mph. I disabled traction control... I couldn't tell a difference. I connected FORScan and logged what I could (attached), but I couldn’t find wheel speed PIDs, maybe my hardware. From what I can see, it looks like the rear is being engaged more than it should be, even at higher speed. So my questions/theory: The replacement PTU could just be a dud on its way out Or, something like the RDU/rear drivetrain is causing the system to stay engaged, which is overheating and killing PTUs Has anyone seen a bad RDU or rear driveline issue cause repeated PTU failures like this? I’m hesitant to put another PTU in it, especially a new one, until I’m sure there isn’t an underlying issue that will just destroy it again. For reference: All 4 tires are the same size, brand, and wear No visible PTU leaks on this unit like the last one No burnt smell like the first unit Replacement PTU supposedly had fresh fluid At this point it almost feels more like a rear driveline or AWD control issue than just a PTU, but I’m not sure. Any advice or similar experiences would be appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 30 Report Share Posted April 30 (edited) Welcome. With a used PTU installed clouds the diagnostics. I suggest you electrically disconnect the RDU coupler and test drive it like that. Quote I disabled traction control... I couldn't tell a difference. What method did you use? I can get onto the interstate and depending on how hard I accelerate the power to the rear will stay on up to around 60mph. Edited April 30 by 1004ron 1 Quote Link to comment Share on other sites More sharing options...
john5678 Posted April 30 Author Report Share Posted April 30 (edited) I disabled traction control through dash settings. I may try your suggestion on unplugging the connector if I can access it. Edited April 30 by john5678 Quote Link to comment Share on other sites More sharing options...
omar302 Posted April 30 Report Share Posted April 30 2 hours ago, john5678 said: When I got home, I did some tight turns in a parking lot, and it behaves like a 4x4 on dry pavement, it grabs/binds when turning at low speeds. The dash power distribution screen shows all 4 wheels engaged up to around 50 mph. I disabled traction control... I couldn't tell a difference. This probably indicates a bad (Active Torque Coupling (ATC) solenoid. This is the front part of the RDU and controls how much the rear axle connects with the front. 3 Quote Link to comment Share on other sites More sharing options...
john5678 Posted April 30 Author Report Share Posted April 30 2 hours ago, omar302 said: This probably indicates a bad (Active Torque Coupling (ATC) solenoid. This is the front part of the RDU and controls how much the rear axle connects with the front. Yeah, I unplugged it, threw an error on the dash, but didn't change anything as far as driving. Wheels acted like trying to grab on pavement when turning... as if it's in a 4WD in 4WD. Quote Link to comment Share on other sites More sharing options...
john5678 Posted April 30 Author Report Share Posted April 30 4 hours ago, john5678 said: I disabled traction control through dash settings. I may try your suggestion on unplugging the connector if I can access it. Pulled the plug, made no difference other than throwing an AWD malfunction error. Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 1 Report Share Posted May 1 7 hours ago, john5678 said: Yeah, I unplugged it, threw an error on the dash, but didn't change anything as far as driving. Wheels acted like trying to grab on pavement when turning... as if it's in a 4WD in 4WD. FYI, in case you didn't already know, the ATC is sold separately, in case the differential is good and you don't want to replace the whole assembly. 2 Quote Link to comment Share on other sites More sharing options...
john5678 Posted May 6 Author Report Share Posted May 6 So the dealer’s mechanic says the entire rear differential/rear end needs to be replaced, and believes it likely contributed to the original PTU failure, and may have also damaged the replacement PTU that was installed afterward. Because the vehicle has had issues almost immediately after purchase, the dealer has offered to swap us into a different vehicle, and we’re probably going to take that route. I still think the Edge is a nice vehicle when everything is working correctly, especially for highway driving and general daily comfort. But after everything we’ve experienced, I don’t think it’s the best fit for our situation. We live on a steep, rough gravel driveway in the mountains, and if we’re already seeing drivetrain issues mainly from normal pavement driving, I just don’t feel confident about how it’ll hold up long term for our environment and needs. At this point, we’re probably better off moving to something simpler and more rugged, even if that means giving up some of the comfort and luxury-style features the Edge offered. 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted May 6 Report Share Posted May 6 All well and good that the dealership is willing to swap you into a different vehicle. Just remember not to blame the vehicle itself. Always the problem when buying a used vehicle is you never really know how the vehicle was treated prior to your purchase. Hopefully you get the right vehicle for your needs with zero problems. Good Luck. 1 Quote Link to comment Share on other sites More sharing options...
