SteveO2019 Posted July 31 Report Share Posted July 31 Greetngs all, I have a 2019 ST, app 70,000 miles. This is my 3rd Edge, first 2 were Titaniums and both were totaled by idiot drivers. This one is by far the favorite, started making a odd knocking sound in rifght rear only when taking off and in right turn, does not do it id left turn. Anyone else experience this? Guess it will go to shop next week. 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted August 2 Report Share Posted August 2 Sounds like something loose in the suspension. Could have a loose / failed rear shock, which would make it simple to fix. Have you looked around the area to see if you can see anything out of place; ie: loose inner fender well, shock not properly bolted in place, etc. You can only see so much with the wheel / tire installed. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 13 Report Share Posted August 13 This is a highly documented pattern failure on 2019+ Ford AWD. It's probably a failing Active Torque Coupling Unit on the Rear Differential. Starting with the 2919 edges, Ford changed the AWD disconnect system that frequently suffers from internal clutch pack chatter or mechanical failure. When you take off or turn right the vehicle weight transfers and forces the rear differential to send torque to the left rear wheel while slipping the inner right wheel, which triggers a distinct clunking, knocking, or thumping sound from that rear area. No recalls on the coupler, but a recall on the rdu. 21S02 (Rear Drive Unit Lubricant Level.) Applies to certain Edges regarding a low lubricant fill level in the rear drive unit. If the fluid was below the minimum level, the axle was supposed to be replaced free of charge. You should check if your specific VIN was ever flagged for this, as running low on fluid from the factory causes the exact premature failure and clunking you are experiencing. There's TSB 21-2389 for Rear Actuator Noise. Check for recalls by getting your VIN and go to the NHTSA Recall Lookup Tool. https://share.google/NTvPbYbGnMtqpp5ND (Good reason to have an extended warranty.) Quote Link to comment Share on other sites More sharing options...
garycrist Posted August 14 Report Share Posted August 14 I've wondered about running 75-140 with some friction modifiers. (like in a 8.8 LSD) It should quiet down the chatter some by making the fluid slippier. In looking at the failures so far. One thing is the bearing failures due to overworked thin fluids. Then as you stated above clutch failure. All of this for fuel economy? Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted August 14 Report Share Posted August 14 In which vehicle? The 2022 is not designed to use that weight gear oil Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 15 Report Share Posted August 15 Found this on YouTube. 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted August 15 Report Share Posted August 15 That's an excellent video. And the whole process only takes 16 minutes! 😃 Quote Link to comment Share on other sites More sharing options...
bruker Posted Friday at 07:17 PM Report Share Posted Friday at 07:17 PM I have a 2020 Edge and it's starting to make the rumbling sound when making a slow right turn. I crawled under and noticed the front of the rear diff is a little damp with oil. Is that also indicative that the Active Torque Coupling Unit is starting to fail? The video above is for I think he said a 2013 is the process the same for the 2020? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Friday at 07:44 PM Report Share Posted Friday at 07:44 PM Did you have the software update that resolves issues with the rear diff making rumble noises? I had some of that on left & right turns, randomly, and that solved that issue. Can you see where the leak is coming from? - Is it from the connection to the rear diff? - Is it coming from on top of the rear diff? There is typically a breather hole on top of the rear diff to allow for expansion of air in the rear diff as the oil heats up and expands. Remember the rear diff is not completely full. - Did you drive through something that makes it look like the rear diff is leaking? The above procedure does work on a 2020 but I suggest you make sure where the leak is actually coming from before you tear into this project. Quote Link to comment Share on other sites More sharing options...
bruker Posted Friday at 08:41 PM Report Share Posted Friday at 08:41 PM Here's a pic I just took from the driver's side. The area circled is where there's a light coating of fluid. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Friday at 09:58 PM Report Share Posted Friday at 09:58 PM Honestly, that could be almost anything. Car undersides pick up all kinds of dirt & grease from the roadway all the time. Do you park the car in the same place, the same way everytime? Are there any wet spots on the pavement directly under where the RDU sits? What happens when you place your finger on that area shown in the picture? All I'm saying is don't jump to conclusions just because you watched that video. Quote Link to comment Share on other sites More sharing options...
garycrist Posted Friday at 10:05 PM Report Share Posted Friday at 10:05 PM Are you sure it is not from the drain plug? Clean it off with some Brakleen and monitor. Quote Link to comment Share on other sites More sharing options...
bruker Posted Friday at 10:14 PM Report Share Posted Friday at 10:14 PM Yep, park in the same place every night. No spots or drips on the floor. When I wipe it with my finger it's wet but doesn't really have much of a smell. The drain and fill plugs are tight and no evidence of leaking. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted Friday at 11:39 PM Report Share Posted Friday at 11:39 PM It wouldn't be from the drain plug since that's in a different area of the RDU. If you are not seeing any spots on the floor, I wouldn't be too concerned right now. I would just keep an eye out for any leaks in the future. Get that software upgrade done and see if that makes the problem go away. Quote Link to comment Share on other sites More sharing options...
bruker Posted yesterday at 06:21 PM Report Share Posted yesterday at 06:21 PM I'm not the original owner and there are no open recalls for my Edge. Does that mean the software update's probably been done already? Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted yesterday at 07:00 PM Report Share Posted yesterday at 07:00 PM (edited) The software update is not a recall. It is a TSB ( Technical Service Bulletin ). You do not get notices on TSBs. The dealership does not normally check for TSBs unless, maybe, a symptom you have coincides with the issue / symptom you are currently having. My dealership at the time fought with me and refused to perform the TSBs. In other words, you are basically on your own to check for TSBs, determine if you are affected by any one or more TSBs, and then get them resolved. Software updates are easy. You can do them from your display. You do not have to leave your car turned on. As long as you have Wi-Fi available, once initiated the update will run on its own. Allegedly these software updates are supposed to update themselves automatically, but apparently they don't. I found a number of recurring TSBs that needed to be attended to. There were two (2) that kept repeating themselves over and over, with different TSB numbers. Go Figure. Those two (2) TSBs were 1. A Display Update and 2. An update to resolve the RDU clunking. Once installed, they worked perfectly. The updates actually took over 8 hours to complete while the car sat overnight. Edited yesterday at 07:01 PM by Samurai Edge Quote Link to comment Share on other sites More sharing options...
bruker Posted yesterday at 07:40 PM Report Share Posted yesterday at 07:40 PM I had no idea you could do the updates from the display. I just went and checked, and it said the updates are current as of today's date 8-22-26. When I touch the Scan for Updates button I get the spinning circles. How long should I have to wait to see what updates might come up? It is connected to WIFI. Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted yesterday at 07:49 PM Report Share Posted yesterday at 07:49 PM I had no idea either. I thought it had to be done by the dealership. I did this a year ago but, IIRC, I tried it a couple of times because it looked like it was doing nothing, just spinning its wheel. Eventually I just let it ride for a while before it started working. Remember that how long it takes is partially determined by your WiFi connection and network traffic. I believe I finally did an internet search to find the correct way to do the update install and that is how I got it to work. Quote Link to comment Share on other sites More sharing options...
bruker Posted yesterday at 08:37 PM Report Share Posted yesterday at 08:37 PM So does it sound like It's up to date based on the message for today's date? Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 22 hours ago Report Share Posted 22 hours ago If it was me, and it told me it was up to date, but I was getting the sound from what I thought was the RDU, and my research shows TSBs for the issue, and the dealership refuses to perform the TSB updates, and actually doesn't care if I had needed TSBs updated or not, I would do what I did, which was perform a proper update. But, that's me. Knowing I have some type of issue, and knowing that to ensure I had all the proper software updates I should do an update, I would do the update. I wouldn't care if the system told me the system was up to date. 1 Quote Link to comment Share on other sites More sharing options...
bruker Posted 19 hours ago Report Share Posted 19 hours ago I really appreciate your help. How do I do a proper update if my display says I have current updates? Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 6 hours ago Report Share Posted 6 hours ago 20 hours ago, Samurai Edge said: I believe I finally did an internet search to find the correct way to do the update install and that is how I got it to work. It is literally this simple: how to perform a software update on a 2020 Ford Edge If it still says you are up-to-date after following the procedure as stated, then it is. I just didn't trust what the system was telling me and I was right. It may be different for you. Quote Link to comment Share on other sites More sharing options...
