bruker Posted yesterday at 04:28 PM Report Share Posted yesterday at 04:28 PM What's the correct rear diff fluid for a 2020 Edge and where did you get it from? Thanks Quote Link to comment Share on other sites More sharing options...
1004ron Posted yesterday at 05:17 PM Report Share Posted yesterday at 05:17 PM Looks like the owner's manual calls for: Rear Axle Variant Quantity All. 28.1 ± 1.0 fl oz (830 ± 30 ml) Materials Name Specification Motorcraft® Disconnect Rear Drive Unit Fluid XY-75W-QL - MOTORCRAFT XY75WQL Gear Oil | Shop Now at RockAuto 1 Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 4 hours ago Report Share Posted 4 hours ago The Owner's Manual? That's a funny place to look. 😉 That particular option is ridiculously / outrageously expensive. This is what I use : Redline MT-LV 70W/75W ( Full Synthetic ) Quote Link to comment Share on other sites More sharing options...
omar302 Posted 1 hour ago Report Share Posted 1 hour ago 2 hours ago, Samurai Edge said: The Owner's Manual? That's a funny place to look. 😉 That particular option is ridiculously / outrageously expensive. This is what I use : Redline MT-LV 70W/75W ( Full Synthetic ) The Motorcraft oil is specifically made(formulated) for the Ford "Disconnect Rear Drive Unit". Hence assume it is not a general gear oil like other makes. The Motorcraft specs (link) states: Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is specifically formulated for Ford disconnect rear drive units with a low offset hypoid gear Developed with a lower viscosity to improve axle efficiency and fuel economy Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is formulated with synthetic base stocks, friction modifiers, antiwear and extreme pressure additives to provide gear protection and smooth clutch operation Use only in Ford Disconnect Rear Drive Units DO NOT use in conventional high-offset hypoid gear axles where SAE 75W-85, 75W-90, 80W-90 or 75W-140 is recommended Quote Link to comment Share on other sites More sharing options...
Samurai Edge Posted 17 minutes ago Report Share Posted 17 minutes ago 59 minutes ago, omar302 said: The Motorcraft oil is specifically made(formulated) for the Ford "Disconnect Rear Drive Unit". Hence assume it is not a general gear oil like other makes. The Motorcraft specs (link) states: Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is specifically formulated for Ford disconnect rear drive units with a low offset hypoid gear Developed with a lower viscosity to improve axle efficiency and fuel economy Motorcraft® SAE 75W Disconnect Rear Drive Unit Fluid is formulated with synthetic base stocks, friction modifiers, antiwear and extreme pressure additives to provide gear protection and smooth clutch operation Use only in Ford Disconnect Rear Drive Units DO NOT use in conventional high-offset hypoid gear axles where SAE 75W-85, 75W-90, 80W-90 or 75W-140 is recommended Good repeat of the manufacturer's position. It really means nothing. As long as someone uses an oil, gear oil, etc., that, at a minimum, meets the standards of the specified oil, gear oil, etc., then said oil performs the same, at a minimum, of the specified oil. Redline MT-LV 70W/75W ( Full Synthetic ) meets that specification. https://www.redlineoil.com/mt-lv-70w75w Quote Link to comment Share on other sites More sharing options...
