First issue with my Edge, thank God for Powertrain warranty
Shortly after I got my Edge in May, I began to notice a thump, or jolt, when slowing down at 15 mph.  I decided to change the PTU and rear diff fluids since they needed to be done, and see if that would resolve the problem.  No dice.  Went on vacation in early June, and when I got back, I took it to my local Ford dealership to look at.  They heard the sound immediately on the test drive and stated they felt the transmission needed to come out to tear down and find the failure.  They had no loaner cars and told me they would
call me when one came available.
Fast forward a couple weeks later and I haven’t heard anything.  I call the service advisor and she tells me she hasn’t forgotten about me and that they only have two loaners available for the entirety of the dealership service department to use.  So I wait, and continue to wait, just over two months until I decided I had enough of waiting.  I decide to call another dealership that I pass by on the way to work, albeit 30 minutes away.
I call the service department and explain the situation.  SA tells me they can’t go by what another dealership says and has to do their own diagnosis on it, to which I agreed and acknowledged.  I made an appointment for a weekday early morning and the SA and his transmission tech drive it and acknowledge the thump at 15 mph.  He says they want to pull the driveshaft and drive it and see if the noise remains or disappears.  They wanted two hours of time that I really didn’t have.  We got further into the conversation and he said he was short on loaners as well.  I told him I had to leave and needed to reach back out to him when I could figure out transportation.
I called the service department back Monday afternoon and told the service advisor that I needed a loaner and that I couldn’t find a vehicle to borrow.  He told me that he just had a loaner come available and I could bring my car in Tuesday and leave it and take the rental.  YES!!!  I got a brand new 2026 F150.  More importantly, my car is finally getting looked at and fixed.
They pulled the driveshaft and drove it.  The noise remained.  Next step, pull the valve body out of the trans and inspect it and air check the clutches for proper operation.  When they drove it, they had a scan tool hooked to it monitoring everything, which returned nothing to go off of.  They found an issue with the C clutch for third gear so now they have to tear down the transmission to find the failure.  This is Ford’s stance to warranty a powertrain part.
More to come.  Service advisor has acknowledged that this will be covered under the power train warranty so enjoy the new F150 while they get this fixed.
Posted (edited)
1 hour ago, Samurai Edge said:
. . .   and then you decided to buy the 2026 F150?   🤔
No… they are going to have my car for a few days.  Service advisor was only working a couple of hours today and is off on Monday, so I probably won’t hear anything until Tuesday at best.  I get to ride around in this brand new loaner pick up truck while my car is in the shop.
Would I buy this pick up or a pick up truck?  No, not living so far from work.  The payment and gas would not be fun, even though this one has been getting 24ish on the highway.  It is a base model F150 super cab with the 2.7 twin turbo motor.  It’s ok, but not for me, not now anyhow.
Edited by 22CarbGrayElite
And just like that, the dealership sold the F150 today.  They brought me a 2026 Bronco Big Bend edition to replace it.  Just as well, as I went to wash the pick up and fuel it, it was $65 for what I used and it was just under a half tank.  I’m guessing $100+ fill ups would be the norm for this thing so, not for my budget right now.
Called today for an update.  My transmission is apart in pieces on a work bench at the dealership.  They are going to replace that clutch and a bunch of one time use parts that need replaced once removed from the transmission.  If for some reason this does not fix it, they will either rebuild it completely or order a reman from Ford.
I didn't have a warranty, and my 2019 8F35 died. They said they could pull it and diagnose it and fix it, with a cost of $4k-10k. I wimped out and just said replace it. I was not doing well with a household of 3 with 3 jobs and school and one vehicle. I sorta wish I had them diagnose it and fix it versus replace it, as that erased all gains of buying a used vehicle, but I think it is my last Ford, which would be weird with a 40 year Ford/Lincoln/Mercury only history.
Everyone has to base their decisions on their particular situation at that particular time.
For all you know, your car could have been at the dealership for a month or more while they " diagnosed it " and you still may have wound up paying the same price as the one you decided to purchase.
Got the call this afternoon that the Edge is done and ready to be picked up.  Both the transmission tech and service advisor drove it and confirmed it is fixed.  I will pick it up tomorrow morning on the way home from work.  Fingers crossed everything is good now.  I have some projects to finish on it now.
Just now, Samurai Edge said:
After 6 weeks or so, bet you are glad to finally have your car back.  Hopefully it's fixed and runs as normal
So far, so good… 30 mile ride home from the dealership and it ran smooth.  Pretty sure the thump was gone.  I am glad to have it back.  That Bronco Sport wasn’t cutting it anymore, although the 34 mpg at times and the wide screen were nice.  The dealership basically rebuilt the transmission in house, kept the OE converter and got fresh fluid.  Would have been approximately $6500 out of pocket if not for the powertrain warranty.  Time will tell.  Now to get to finishing the stuff I started on it, along with my buddy’s recently acquired ‘98 C5 convertible and its “punch list” of stuff to do.
Been driving it all week, put over 500 miles on it.  It is doing it again, at 15 mph when slowing down, it jolts when downshifting.  Called the dealership and am taking it in Tuesday morning after work to have them test drive it and confirm.  I don’t know what the next steps will be yet.
Most dealerships I know don't have transmission experts employed.
My guess is that this dealership wanted to make a buck or two off the Ford warranty or 3rd party insurance.
It would be better to get a rebuilt unit from a transmission specialist company.
One would think, that, if the dealership is going to have people open up a transmission, then, hopefully, that person is a Transmission Tech.  But, just because they opened it up and put it back together again only means they know the basics and are not a real Transmission Tech.
Dealerships I have dealt with in the past do not have Transmission Techs.  They farm out the work to a transmission shop.
I took it back to the dealership Tuesday morning and the service advisor went for a drive with me driving. He heard and felt it so that was part one of this.  We got back to the shop and the service advisor had a conversation with the service manager and the transmission tech.  They decided they want to replace the valve body since it was only cleaned with the “overhaul” they did previously.  I agreed, trying to trust the process.  He ordered a new valve body from Ford and it goes in tomorrow morning to get it swapped out.  I should be able to pick it up the following morning, provided they determine that noise and jolt is gone.
If it doesn’t fix the problem, I believe they are going to order a transmission from Ford and replace it.  This dealership, for what it is worth, has factory master certified engine and transmission techs.  This is all being done under the Ford powertrain warranty.  The invoice/receipt they gave me was the Warranty copy and it documents all of the parts that were replaced the first repair.  They did quite a bit but it wasn’t a full on rebuild.  Some of the parts were one time use so that explains some of those.
I look at it this way… this new valve body fixes the issue or I am getting a reman’d or new transmission from Ford if it doesn’t.  There isn’t much more they can do at this point.  I’ll give them credit for being diligent in dealing with Ford warranty guidelines and keeping me informed and in a loaner vehicle throughout this deal.  I put 3600 miles on a brand new Bronco Sport, so there is that! 😁
I will update the thread once this is done.  Thanks for listening.
18 hours ago, 1004ron said:
@22CarbGrayElite how soon after collecting the car was the fault evident? - if soon after you've goto question why they didn't identify it.
I stick with my opinion that dealerships service shops don't have the expertise to re-manufacture transmissions, but at least they're remaining committed to the warranty.
Extend Warranty
I thought I noticed it the day I picked it up, but I put about 400 miles on it and had a friend confirm I wasn’t hearing things before I called the dealership.  So it was within the week I picked it up that I was calling them back and telling them it was making the noise and jolt again.  I don’t know how good their dedicated transmission and engine guys are, but they are taking care of the car and honoring the warranty so I can’t complain.
3 hours ago, Samurai Edge said:
@22CarbGrayElite  It does sound like they are making every effort to repair your transmission.  If failure continues, and they replace the transmission as they are indicating, then you have a really good dealership.
Oh so far and few between, they are.
Yep, they are doing their due diligence and they aren’t doing me wrong at all.  It is a shame the Ford dealership two miles from my house couldn’t do better.  Another story for another thread.
Called the dealership today.  Service Advisor was hoping I had good news.  I told him what was happening and he said, “well, we’ve done all we can do besides replace the transmission outright.  Bring it in one morning so we can drive it and verify it and go from there.”  I am bringing it in next Tuesday morning and hopefully the car does it and this transmission can be replaced once and for all.
It does the thump inconsistently now, meaning it could be a very light almost nonexistent bump or it could be a full on hit like it was consistently doing before.  One more thing, when they “overhauled” it and replaced the clutch pack, it was silky smooth.  After this valve body, it has felt rough and clunky with shifts.  Fuel mileage has taken a crap but seems to be coming back up.  I’ve hit over 29 mpg regularly keeping my right foot in check.  It was struggling to hit 24ish earlier in the week.  Don’t know if any of this matters to what is happening but I am noticing these things after each repair.
More to come after this coming Tuesday…
When I bought my 2021 ST, around 10K it developed the thump you speak of. Mine would happen during acceleration from a dead stop. It was very random and felt like the whole transmission was going to explode. Back and forth with the dealer numerous times. They would tell me they couldn't find anything wrong. After numerous trips back and forth, they finally replaced the valve body assembly. I never had the thump come back but had a weird delay shifting into reverse.
I ended up trading in for a 2024 at 12K, just because I never felt comfortable after the experience. Also knew it was the last year for the Edge. I love the vehicle!
I just lost a lot of trust with Ford.
I would push them until they replace the transmission. Once the transmission has a curse, it never fully goes away.
