Edgar Edgeworthy Posted April 4, 2011 Report Share Posted April 4, 2011 Just started hearing an intermittent squeaking noise when I turn right in full motion (and it's not my tires). Anybody got any idea about this one? Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted April 4, 2011 Report Share Posted April 4, 2011 Just started hearing an intermittent squeaking noise when I turn right in full motion (and it's not my tires). Anybody got any idea about this one? I haven't heard of any common issues regarding this. Any way you can get a video? Quote Link to comment Share on other sites More sharing options...
Edgar Edgeworthy Posted April 4, 2011 Author Report Share Posted April 4, 2011 Taking it to dealership this afternoon... Quote Link to comment Share on other sites More sharing options...
railroad Posted April 4, 2011 Report Share Posted April 4, 2011 Most of the steering stops are metal to metal. If you are holding the wheels turned until they are against the stops and you are moving, the stops are moving against each other, normal. If you intend to do this often and it bothers you, you can put a finger of grease on the stops. It will last until it rains or you wear it off. Quote Link to comment Share on other sites More sharing options...
Edgar Edgeworthy Posted April 4, 2011 Author Report Share Posted April 4, 2011 Most of the steering stops are metal to metal. If you are holding the wheels turned until they are against the stops and you are moving, the stops are moving against each other, normal. If you intend to do this often and it bothers you, you can put a finger of grease on the stops. It will last until it rains or you wear it off. The noise happens before I get to the stop. Quote Link to comment Share on other sites More sharing options...
ThinLine Posted April 6, 2011 Report Share Posted April 6, 2011 Change the power steering fluid. It is merconV trans fluid. I used a "turkey baster" to remove as much as I could, filled to full and drove the car for a week and them did the same thing again. I had no squeaks but this damn steering wheel really vibrates when turning at slow speeds. Apparently all of the Edges do this....or so I was told. Quote Link to comment Share on other sites More sharing options...
chetlet Posted April 6, 2011 Report Share Posted April 6, 2011 Just started hearing an intermittent squeaking noise when I turn right in full motion (and it's not my tires). Anybody got any idea about this one? I have this same issue, but i wouldnt call mine a squeak, more of a whistle, and it's there at nearly all speeds, only when turning right. I have an appt. Friday and will update with what I find out. If this was normal or expected, then I would assume it would also happen when turning left, and would have happened day 1. Quote Link to comment Share on other sites More sharing options...
Edgar Edgeworthy Posted April 6, 2011 Author Report Share Posted April 6, 2011 I have this same issue, but i wouldnt call mine a squeak, more of a whistle, and it's there at nearly all speeds, only when turning right. I have an appt. Friday and will update with what I find out. If this was normal or expected, then I would assume it would also happen when turning left, and would have happened day 1. Just back from the dealership. They said they test drove it and it was "a normal sound of the power steering fluid pump" and that was that. They said they heard the sound when turning right or left but it only happens for me turning right. And the "normal sound" didn't start until I got to about 2000 miles odometer... Quote Link to comment Share on other sites More sharing options...
RCM Posted May 6, 2011 Report Share Posted May 6, 2011 Anyone find a resolution to this? My 2011 Edge Limited started doing this recently (I'm at 2,000 miles). It only "squeaks" when I turn the wheel to the right. I have a hard time accepting "thats just the way it is" when I paid that kind of money to get a loaded Limited edition. Quote Link to comment Share on other sites More sharing options...
AXM Posted May 13, 2011 Report Share Posted May 13, 2011 I have a 2011 Edge Limited and bought it with 42 miles and it now has 1100+ miles in 2.5 weeks. Just starting hearing this noise when turning right ONLY and had it into the dealership today. The noise is a whistling/hallow sound like when you swing a rope around in the air but more high pitch and also intermittent. They and I were both able to recreate the noise with ease and they even went out on the lot and drove a newer edge and did not hear the same sound. They tried everything they could to figure it out but found it safe to drive. They even switched the tires around thinking it was the tire. They have a ticket into Ford which means they will have to do their own research and if they can't figure it out they will send somebody out. I do not know where it goes from there. I will keep you posted. Have your dealership put a ticket in with Ford so it gets documented, fixed and a TSB is issued. Quote Link to comment Share on other sites More sharing options...
specialk4523 Posted May 15, 2011 Report Share Posted May 15, 2011 I have a 2011 Edge Limited and bought it with 42 miles and it now has 1100+ miles in 2.5 weeks. Just starting hearing this noise when turning right ONLY and had it into the dealership today. The noise is a whistling/hallow sound like when you swing a rope around in the air but more high pitch and also intermittent. They and I were both able to recreate the noise with ease and they even went out on the lot and drove a newer edge and did not hear the same sound. They tried everything they could to figure it out but found it safe to drive. They even switched the tires around thinking it was the tire. They have a ticket into Ford which means they will have to do their own research and if they can't figure it out they will send somebody out. I do not know where it goes from there. I will keep you posted. Have your dealership put a ticket in with Ford so it gets documented, fixed and a TSB is issued. I have the same issue and i thought it was because i change the lug nuts to the gorrilla locks but obviously thats not the case, i thought i put too much torque when tighting the locks!!! Quote Link to comment Share on other sites More sharing options...
specialk4523 Posted May 15, 2011 Report Share Posted May 15, 2011 I have the same issue and i thought it was because i change the lug nuts to the gorrilla locks but obviously thats not the case, i thought i put too much torque when tighting the locks!!! And i am only at 900 miles Quote Link to comment Share on other sites More sharing options...
AXM Posted May 26, 2011 Report Share Posted May 26, 2011 ****RESOLVED**** My car was in the shop for another 5 days because Ford's hotline instructed the dealership to try a few things which turned out to be greasing the steering components, machine the rotors, replace the hub assembly, and adjust the breaks. All of which did not solve the problem. Finally a Ford Engineer was sent out and figured out the issue. The heat shield between the exhaust and engine backing plate was flexing while turning right and caused the sound. They re-adjusted the heat shield so it was not touching or leaning up against anything and the noise went away. Had the car back for 2 days now and the noise is still gone. The dealership described the noise as a whistling hooting sound. I also asked if a TSB will be issued and was told they were not sure. Hope this solves your problem too. 1 Quote Link to comment Share on other sites More sharing options...
cal3thousand Posted May 26, 2011 Report Share Posted May 26, 2011 ****RESOLVED**** My car was in the shop for another 5 days because Ford's hotline instructed the dealership to try a few things which turned out to be greasing the steering components, machine the rotors, replace the hub assembly, and adjust the breaks. All of which did not solve the problem. Finally a Ford Engineer was sent out and figured out the issue. The heat shield between the exhaust and engine backing plate was flexing while turning right and caused the sound. They re-adjusted the heat shield so it was not touching or leaning up against anything and the noise went away. Had the car back for 2 days now and the noise is still gone. The dealership described the noise as a whistling hooting sound. I also asked if a TSB will be issued and was told they were not sure. Hope this solves your problem too. Thanks for posting resolution! Quote Link to comment Share on other sites More sharing options...
Jamie Stross Posted May 28, 2011 Report Share Posted May 28, 2011 I have this exact problem. It's extremely annoying and just when I turn right. My car is going in Monday for a sync update I think I'll Mention it Quote Link to comment Share on other sites More sharing options...
Jamie Stross Posted June 2, 2011 Report Share Posted June 2, 2011 So I took my vehicle in to update the sync and mentioned this problem. Neither were fixed. They couldn't update my sync and the mechanic made notes saying 'abs wiring harness was loose, rubbing against front cv boot. Harness put back in place, test drove, noise gone' so I'm like okay. Then i pull out of the parking lot and take a RIGHT and guess what, still there. Like honestly what do I have to do, fix it myself? I told the girl in service that it was the heat shield was flexing and she's like 'well that wouldn't be it at all' nothing but problems. Quote Link to comment Share on other sites More sharing options...
l33 Posted June 2, 2011 Report Share Posted June 2, 2011 Me too guys! Thanks for the solution, I'll take it back to the dealer next week! Quote Link to comment Share on other sites More sharing options...
l33 Posted June 2, 2011 Report Share Posted June 2, 2011 So I took my vehicle in to update the sync and mentioned this problem. Neither were fixed. They couldn't update my sync and the mechanic made notes saying 'abs wiring harness was loose, rubbing against front cv boot. Harness put back in place, test drove, noise gone' so I'm like okay. Then i pull out of the parking lot and take a RIGHT and guess what, still there. Like honestly what do I have to do, fix it myself? I told the girl in service that it was the heat shield was flexing and she's like 'well that wouldn't be it at all' nothing but problems. Get to another dealer buddy. I have to say the heat shield resolution is certainly strange because I could have sworn that it sounded like something to do with the wheel (sounds like it comes from left front... anyone else agree on that?). Just the way the noise is, that intermittant, squeeking/chirping whatever you want to call it... sounds like its related to wheel speed. Curious, when was everyones Edges built or when did you take delivery? I took delivery of my 2011 Limited AWD in October/November 2010 and I think I started hearing the noise in January. Quote Link to comment Share on other sites More sharing options...
Edgar Edgeworthy Posted June 2, 2011 Author Report Share Posted June 2, 2011 Get to another dealer buddy. I have to say the heat shield resolution is certainly strange because I could have sworn that it sounded like something to do with the wheel (sounds like it comes from left front... anyone else agree on that?). Just the way the noise is, that intermittant, squeeking/chirping whatever you want to call it... sounds like its related to wheel speed. Curious, when was everyones Edges built or when did you take delivery? I took delivery of my 2011 Limited AWD in October/November 2010 and I think I started hearing the noise in January. I took delivery of my custom-ordered 2011 LTD in December and started hearing the noise in March (I started this topic.) I cut-and-pasted AXM's posting below in which he/she believed that his/her dealership and finally discovered the heat shield solution and e-mailed it to my dealership and they said they would look into it but it's now been a week and have received nothing back. Maybe AXM could tell us the name of his/her dealership so we can direct ours to it? Quote Link to comment Share on other sites More sharing options...
Jamie Stross Posted June 3, 2011 Report Share Posted June 3, 2011 I'm going back this Monday, they're going to give me a car instead of wasting my time waiting for a shuttle. I'll insist they look at the heat shield. If they don't then I'll go somewhere else. Thanks guys. Quote Link to comment Share on other sites More sharing options...
l33 Posted June 3, 2011 Report Share Posted June 3, 2011 I'm going back this Monday, they're going to give me a car instead of wasting my time waiting for a shuttle. I'll insist they look at the heat shield. If they don't then I'll go somewhere else. Thanks guys. My dealer said that Ford engineering got back to them today - specifically in reference to me telling them about this thread. Engineering confirmed they have feedback from a Field Engineer detailing this. When they described it to me, it didn't sound exactly the same as above but close enough for me to believe it was the same issue. There is also a report of the brake hose rubbing something so they are going to check that too. Quote Link to comment Share on other sites More sharing options...
Jamie Stross Posted June 3, 2011 Report Share Posted June 3, 2011 You guys have amazing service down there. Quote Link to comment Share on other sites More sharing options...
GhostStrykre Posted July 20, 2011 Report Share Posted July 20, 2011 I had this problem with my 2011 Ford Edge SEL and it got really bad around 1,200 miles. Like even rounding exit or entrance ramps could cause the noise. Now my vehicle is above 4,000 miles and the sound is nearly gone. I REALLY have to take a right turn HARD to get the noise to emit, but otherwise the vehicle is quite silent. I don't know if the parts settled in the engine or something, I just know that the sound has seemed to go away. I'd love a TSB to be issued on this because I took the vehicle in to the Ford Dealership to have it looked at. They were able to get the vehicle to make the noise, but they couldn't figure out what was causing it. I told them about this thread, but they were still unsure. It'd just be nice to have the dealership tell me its fixed and won't happen again under any circumstances... Oh well, I think I'll just consider myself lucky that the vehicle's parts are settling in and the noise is fading. Hopefully this happens for the rest of you. Quote Link to comment Share on other sites More sharing options...
slypx Posted September 24, 2011 Report Share Posted September 24, 2011 *** Solution ?? *** Hi guys Since August 31st, I have a brand new 2011 Edge AWD Limited that just showed this noise a couple of days ago.. I went to my dealer this week and they had a lot of "bla bla" over a possible noisy power stering pump but after a lot of insisting from my part, they search in their "bible" and they found a TSB on this thing. It is going back next Wednesday ... The number here in Canada is TSB 11-9-4 I'll let you know next weekend about it ... Quote Link to comment Share on other sites More sharing options...
slypx Posted September 29, 2011 Report Share Posted September 29, 2011 *** Solution ?? *** Hi guys Since August 31st, I have a brand new 2011 Edge AWD Limited that just showed this noise a couple of days ago.. I went to my dealer this week and they had a lot of "bla bla" over a possible noisy power stering pump but after a lot of insisting from my part, they search in their "bible" and they found a TSB on this thing. It is going back next Wednesday ... The number here in Canada is TSB 11-9-4 I'll let you know next weekend about it ... OK Guys The TSB was done today and guess what ... No change !! I ended up with two mechanics that came out to hear ...they think again that it is the power streeing pump that is anormally noisy. They're ordering a new one ... another trip to the dealer to come ... Quote Link to comment Share on other sites More sharing options...
