    343
  1. It would have to be a blown fuse if both visors are not powered. If it was only one it could be a loose connection.
  2. You may have a bad microphone if your phone is noisy and you have trouble with voice commands.
  3. You tune to the normal analog station and if you have the HD option turned on it will switch to the HD version if it's available at that time. I think.
  4. Not to nit pick, but since you repeatedly point out that you're using the recommendation of tire mfrs websites................ From the 2 links you posted above: If you're running 45 and max on the tire is 55 then that's probably not unsafe but it's certainly higher than recommended by Ford. And it's not necessarily the best pressure, either, regardless of what your tire ninjas say. And yes - attitude is everything when you're looking for advice.
  5. I think your dealer is hosing you. They're telling Ford the coils are at fault rather than the PCM. Did they even check the TSB? Get the dealer to check the TSB and if they won't tell Ford the PCM is at fault find another dealer. Ford has replaced PCMs, plugs and coils all under the emissions warranty on numerous vehicles with no questions asked.
  6. I understand what you're saying, but any amount of tint is at least a tiny bit less safe than no tint. And Dingo is right - if you get rear ended and they see the tint it will probably be your fault. Is it really worth the risk?
  7. No, I don't know how to remove it. Tail lights enable other people to see your car at night and to let people know when you're applying the brakes at all times. Anything that makes that less visible is simply a bad idea. Tinted front windows are only a safety issue if you're stopped by an officer. You're going to do it anyway so just do it if that's what you want to do, but don't try to convince anyone that it's safe.
  8. It's the same software - I think they just give you a warning that if you have Nav and do the download your Nav won't work until you get the SD card in the mail or go to the dealer.
  9. Well, you can also drive at night with no lights but that doesn't mean it's safe. If you don't want lectures about tinted lights then don't post about them. They're illegal and for good reason. If you don't care then that's your prerogative.
  10. There is no way they are as bright as they would be without the tint. You asked for advice so you have to take the lectures along with it. Tinting taillights or headlights is a bad idea - period. If you don't want to listen to lectures then don't post about it.
  11. Sync has had text message support since day one back in 07. It's up to the cell phone provider to support the proper bluetooth protocol. So far Apple doesn't support it and neither do many of the other mfrs. NOT a sync or MFT problem.
  12. Since this thread was specific to the 2011 model and in order to keep all of the MFT upgrade reports in one place I'm closing this thread. Please post your MFT upgrade status here: http://www.fordedgeforum.com/index.php?/topic/9226-mft-report-your-successful-installations-or-problems
  13. It's impossible for us to say whether you got a good deal or not because it depends on the local car market in your area and it varies. Besides - if you've already bought it do you really want people telling you that you got ripped off? Just enjoy it and be happy.
  14. Didn't know that. I thought they were always made in SC.
  15. My daughter's 4S seems to work fine in her Focus with the MFT update.
  16. No. The headunit doesn't have the usb port - that's in the sync controller which you don't have. You're stuck with the headphone out cable connection unless you buy an adapter. Edit - if you only want usb for power then you can get a powered usb port but not for audio without some type of ipod adapter.
  17. I think you should un-pair the phone, reboot the phone, do a master reset and re-pair the phone just to be safe.
  18. What do you mean 'sometimes'? :cheerleader: :poke:
  19. http://www.youtube.com/watch?v=lVPsBmhgjTk
