Everything posted by tpm419419
A Pillar Trim Removal (2020)
tpm419419 replied to ik0n's topic in Interior, A.C., Heat, Interior Trim
Just seeing this now. The upper piece cannot be removed without removing the lower 2 pieces?. Just trying to run wire at the base of the upper trim piece where it meets the dash. 2019 Edge Thanks -
Access Passenger Compartment Fuse Panel
tpm419419 replied to msawdust's topic in Interior, A.C., Heat, Interior Trim
You need To go under the dash. Taking the access panel off is only good if having someone shine a flashlight through. Basically you need to contort yourself and get on your back to look up under the dash. I hooked up a dash cam power wire so it can be done. good luck -
What year is it? If 15 or newer it’s to left of steering wheel by knee height. It’s almost useless except for shining a flashlight. You will need to go under the dash as the fuse panel is tucked up way inside i used the top left fuse I think number 23 -
Heated Seats (Remote start)
tpm419419 replied to Burtman's topic in Alarms, Keyless Entry, Locks & Remote Start
Guessing it’s a 2011 or newer. The settings screen to left of speedometer will give you the option to adjust the remote start settings -
Sync 3 2016 upgrade to CarPlay
tpm419419 replied to tpm419419's topic in Audio, Backup, Navigation & SYNC
Agree. I myself am going to wait to see if it’s updated via WiFi -
Sync 3 3.0 is out -
On my 16 I'm pretty sure #37 is on the bottom, left side ( pretty hard to see but it appears that way ) 23 is at the top -
That cubby drawer even has an electrical lightning symbol ( at least on my 16 ) -
Someone on Facebook said they were auto updated via wifi in February to 2.2. Anyone else get the update via wifi? -
tpm419419 replied to jmr061's topic in Audio, Backup, Navigation & SYNC
I have the update, this is what I can't understand with Ford. It works fine so what are they waiting for? We are only maybe 1% of people on this thread and the other 99% are still waiting. I know I was promised by my salesman back in April of 2016 I would get CarPlay by summer ( 2016 ). With no mention of any cost -
Amazing that Ford hasn't released Apple CarPlay software update. What are they waiting for? -
What is Ford waiting on? Almost mid March and no public release. I haven't heard of a single issue with those that downloaded and installed it. Only thing I would suggest is a button to exit or enter CarPlay. Right now you need to disconnect the lightning cable from phone -
I use a small 6" USB extension to plug my phone in -
Yes. Hopefully a future update will resolve this -
Talking about Sync 3. Sorry -
I found a short right angle USB extension cord to make connecting a USB cable easier. Comes two to a package but only one is angled to fit
Not positive but I think an added feature to Sync 3 2.2 is Valet mode. You can set a 4 digit pin. Maybe someone can check if it's on Sync 1.0 -
Solved! I was going to just delete it but I will own up to it. In " Display " mode I was going with the side to side arrows NOT the up and down arrows. All is good, I did a quick read of the owners manual to see what I was doing wrong. 4 Edges and 3 with these 4" screens. By my 5th Edge I'll have it down pat -
Not sure if it's Sync or CarPlay related but... Picked up my Edge after having the brake booster and USB hub replaced. I now have an issue with the left of speedo 4" screen. Under display options there was a choice of 3 or 4 different screens with one being an actual rpm gauge plus fuel and temp. That's gone and only have one option, digital speedo with fuel and vertical tach which was in a separate menu. Any ideas why it's gone? There was an AWD option as well to see where power to wheels were going but that is gone as well -
I should be getting the public beta today or tomorrow. Usually a day after the developers get it
