Everything posted by tpm419419
tpm419419 replied to jmr061's topic in Audio, Backup, Navigation & SYNC
The time and temp are to the right of the speedo under the small info screenBut it is definitely more useful for someone without factory Nav. I got it to see if it improves over time -
So I dropped off my Edge to have the brake booster replaced. While I was there I asked if they could install my USB hub for a half hour labor. He said he would check. I just picked it up and they charged me .4 hours to swap the hub. ( 50.00 ) No headaches, guess I chickened out. Happy it's done -
Great explanation. Thank you! -
How did you go about swapping out the hub? -
Great info. Thanks The wire connectors are disconnected from the topside? Just pull out the cable or are there clips to press? Thanks again. Will attempt once the temp warms up -
Ok. Thanks for the quick reply Just a FYI. After the update I turned off car. Hour later restarted and the Nav wouldn't connect. A simple restart solved that issue, all is good -
Hello again I just updated to 2.2 ( with Nav ). I see Android but I do not see Apple CarPlay. Do I need to swap out the hub before it shows up? Sorry if this has been posted before -
Sorry. Meant the website notifications -
Somewhat off topic but no matter what I do I can't seem to enable notifications . I checked the boxes, hit save -
USPS small priority box. Maybe ran over by a hand truck. Who knows -
Well received my new hub today. Pretty sure the Post Office ran over it. New one being shipped out right away and Walt Sweeney has both blue and white in stock -
I wonder how many months before it becomes available. And cost -
I called my dealer and explained the situation. They are ordering the brake booster and will let me know when it's in. Also getting a loaner Always happy with the service department
That isn't my car, I DO have Sync 3 -
This piece correct? And no need to remove the chrome piece? -
Sorry for the delay. For some reason I don't get post notifications even though I have it turned on. I updated to Sync 1.1 and all is working fine now. WiFi keeps the connection Thanks again
I remember someone mentioning to remove the right side trim piece on center console and the piece that goes through the pass through under it to access the underside of the USB hub. Anyone have a how to or video? -
tpm419419 replied to omar302's topic in Recalls, TSBs & Warranty
I have a 2016 with a bad booster. You would think this would be straightened out by now -
Really doesn't do much unless you have the 2017 year model. Than you can remote start and unlock doors via its 4G connectivity Pretty much like GM OnStar -
Sync 3 doesn't have health report -
Thanks everyone
Smartlink OBD Appears to be worth looking at for total connectivity https://techcrunch.com/2017/01/26/fords-new-smartlink-odb-accessory-adds-connected-features-to-older-cars/?sr_share=facebook -
This a simple repair or will they need to keep it for a day?
Hello My brakes are very sensitive when pulling out of the driveway. I googled and think I found out why. Anyone else experience this? BRAKES (PWS) Date Reported JUNE 01, 2016 NHTSA Reference #10081005 TSB Reference #SSM-45857 Description: 2015-2016 EDGE AND 2016 LINCOLN MKX - OVERLY SENSITIVE BRAKE APPLICATION AT LOWSPEED AND/OR IN COLD/WET CONDITIONS - BUILT ON OR BEFORE 3/23/2016 My build date was January I believe
