Everything posted by c_bova
they are chrome clad which is a fancy for a plastic chrome hub glued to an aluminum wheel. Unfortunately it isn't as easy as taking that glued portion off. If I were you I'd just say you hit something on the road that scratched it.
Motorcraft oil 5W20 Synthetic Blend for cheap at Advance Auto?
c_bova replied to WWWPerfA_ZN0W's topic in Lounge
I found another advance near by that had 4 more so I bought those. Think 8 is enough, good for about 6.5 oil changes, haha. -
I think maybe that's all my advance had. Cause I tried another and 3 was the max. I guess the deal is only available in certain zip codes. -
I got 4 and they didn't even question it. 4 was the max they let me order online though. -
curious as to why you picked this thread to post your question? i'll answer but it should go somewhere else. any kind of all purpose cleaner should work, simple green usually will do a good job diluted some. I like meguiars apc+.
not really lug size you are looking for, it's bolt pattern, which I believe is 5x114.3mm. Other things that come into play are the width of the wheel and the offset.
fouled spark plugs or dirty injectors
I had to revert back to stock cause they wanted it back first. Then it took forever for the new one to come from china. If say it was almost a month turn around. Both my bulbs would light before manually on and off but even when warm sometimes the one wouldn't fire on auto. So far so good with the new ballast.
- 38 replies
- Hid
- remore start
the only difference I see is the new one has a sticker with specs and what not on it and the old ones were just all black, so we'll see if the old one keeps up with it.
- 38 replies
- Hid
- remore start
so far so good with the new ballast. Auto headlights have kicked on about 3 times now and both headlights have fired up. Fingers crossed.
- 38 replies
- Hid
- remore start
mine never flashed, that seems like a whole different issue.
- 38 replies
- Hid
- remore start
it's not very quick when the ship everything from china. I've been waiting well over 2 weeks now.
- 38 replies
- Hid
- remore start
see that's what I thought, since if I manually turned them off and on they were fine, but DDM said they tested it and said it was bad.
- 38 replies
- Hid
- remore start
they might have even set your tire pressure incorrectly, I've known plenty of places that have done that.
since it has gotten cold it could be that the gas stations switched to their winter grade fuel which is known to cause mpg to drop as well as the fact it is colder and takes longer for engine to warm up to optimal running temps. that combination will definitely drop your mpgs.
yeah if you want them to replace it you have to try and swap the ballast to make sure that is the issue. i'll know if that was it once I get the new ballast which should be any day now.
- 38 replies
- Hid
- remore start
Help with TRS HID wire harness
c_bova replied to c_bova's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
I'm waiting for my new ballast to show up, its on the slow boat from china -
that and it takes longer for engines to warm up which uses more fuel and if you are warming your car up before you get in you are wasting more.
I had that issue with my DDM kit, got the wire harness and still had an issue. I sent the ballast back and they tested it and said it was a faulty ballast so they are sending me a replacement. I swapped bulbs to make sure it wasn't that and it still happened so that's how I figured it was the ballast. I even have the good TRS wire harness and it did it with or without it.
- 38 replies
- Hid
- remore start
HIDS Help - DDM Tuning.
c_bova replied to RobbN's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
you'll want that shadow from the bulb wire to either to either be on the top or on the outside so you won't see it. I don't have my HID kit installed right now because they had to send me a new ballast so I'm waiting for that to reinstall. -
correct -
it's tricky cause you can't really line the tabs up in size the way they match in the headlight. just gotta position it and get 1 tab in first then turn a bit and get the other 2 in and turn it into final spot. easier said then done right, lol.
