Brake fluid. Replacement. What volume?
WWWPerfA_ZN0W replied to EDST777's topic in Brakes, Chassis & Suspension
1L should be plenty, unless the brake fluid is heavily contaminated, in which case you might want to run extra fluid through the system while bleeding. -
At least you survived the self-surgery Even when the car's not running, it can exact a price when DIY'ing. Due to the tight spaces, have to be ready to have your hand slip and still not move it more than a mm, tough to do! -
Not very encouraging, hopefully just surface rust though!
Nice rides! Are those HRE wheels on the Mustang? How often do you do the Tail of the Dragon? We have a couple of SHO guys (one of whom rides a bike also) regularly visiting that "trail".
Replacement Front Brake.Original or not?
If you can do it, do everything at the same time, front & rear. I think it would be worth it. -
At that mileage, you should replace both rotors and pads. OEM is fine, as mac said, rears are more important to do, as they carry more of the load in an AWD vehicle. Be sure to clean the grooves in the caliper brackets where the pad "ears" sit, and also grease the slide pins. If the brake fluid has never been replaced, have it flushed. -
Welcome to the forum, congrats on your '08 SEL! AWD? Color? What are you looking to do to it? Pics?
That's it! Yer outta heah! J/K LOL. Welcome, glad to have you here, hope you get the HVAC up & running soon
Nice documentation! Def plan some downtime Good time to check/switch out BDA if they were acting up. Watching for continued progress, and good luck!
Welcome to the forum, and congrats on the '08 SEL! Color? Mods in addition to wheels planned? Pics would be awesome
Think we are getting icing on the vehicles, maybe black ice on the asphalt, but not much else so far.
Try PM'ing him, might work better ...
Sport dual exhaust system on the 3.5L
WWWPerfA_ZN0W replied to Manco-Capac's topic in Accessories & Modifications
omar302 once made a post on this, I believe. Some 2011's may have already come with a true dual exhaust, I have seen a couple of videos on YT with true duals. No idea on effects on power/torque, though by themselves, wouldn't gain much. Would need better downpipes to complete the path. Stock downpipes tend be relatively "twisted". -
Alignment checked/done any time recently?
08 - Blower fan not working w/climate control
WWWPerfA_ZN0W replied to rgigowski's topic in 2008 Edge & MKX
Points for awesome airflow We've all dillydallied on various maintenance items on our cars ...- 24 replies
- a/c
- blower fan
(and 2 more)
Maybe a spray from the transmission cooler line while being disconnected that then had to be cleaned up? If the engine was warm/hot when the repair was done, the reaction would have been more likely to happen. Interesting, haven't heard of a valve body gasket replacement (at least on an Edge this young) before. Was a transmission TSB (11-12-10 I think) being performed? I see a "Auto Trans Valve Body ECU Gasket 6 Speed Auto Transmission 6F50" 7T4Z-7H200-A listed in that area. "Auto Trans Valve Body Access Cover Seal 6 Speed Auto Transmission 6F50" 7T4Z-7B329-B, and "Auto Trans Valve Body Oil Passage Seal6 Speed Auto Transmission 6F50" 7T4Z-7N266-A.
Turbos have come a LONG way since then, they have much better lubrication & cooling built in. However, there IS still the occasional occurrence of an oil line seal or turbo seal failure. TSBs out for those issues already. Like akirby said, more in common with the diesel engines esp. when direct injected.
Remote start = gooooood Good luck with the parts replacement and hope you don't find any issues with the fuel tank. -
Feel for ya, hope Ford steps up soon!
Something to divulge there, mac, or will you have to kill us first?
I have been told that shipping blocks are no longer used in the springs while transporting modern vehicles, so that is probably not the issue. Since you have 18" wheels, that's not really a factor either. No reason why the springs/shocks would be locked in place either, except during transport. When you test-drove it, was it stiff back then? How much of a load have you tried in the cargo area?
You can't renew the coverage/restart the coverage every 45 days? Technology wise, I am sure the insurance co could do it, not sure policy wise.
Taking tint to the other extreme, like it
