Just cleaned it up? Looks niiiiice!
http://www.motorcraftservice.com/pubs/content/~WOBMKX/~MUS~LEN/41/11mkxog2e.pdf Owner Guide for 2011 MKX Pg 292 shows you dipstick location, Pg 319 shows you procedure for checking. Basically run the engine until warmed up, then check the dipstick reading. Could also be in need of a PCM programming update/flash.
Do you have an AWD or FWD? Any leaks? Low on transmission fluid? Those'd be the first things to check. I have heard the fuel pump whine, and that is a headache-inducing frequency. Doesn't seem to be the case here. Don't think it is a wheel bearing going bad, though the noise level does vary with speed.
:hyper:
2012 Edge Sport, My impressions not very good so far.
WWWPerfA_ZN0W replied to Diesel350's topic in Owner Impressions
Probably a faulty door latch mechanism/switch. Should be under warranty. All I can say, you ARE getting them fixed, and I hope your luck holds true No more fixups, darn it -
I was able to access the links just now, they should work.
- 12 replies
- tunes tuner
- 0-60 1/4 mile
- (and 8 more)
Welcome, Surfer68! Quite a changeover from Beemers to Blue Ovals. Hope the Edge continues to impress
http://www.fordboltpattern.com/Ford_Mustang_Bolt_Patterns.html To quote them: YEAR STOCK WHEEL SIZES OFFERED MAX WHEEL SIZE BOLT PATTERN(millimeters& inches) STUD SIZE HUB / CENTER BORE OFFSET 2010-UP 17"-19" 22" 5x114.3mm 5x4.50" 1/2"x20mm 70.3mm 35-50mm (H) Should fit the 2007-10 Edge with a little boring out of the wheels, as Edge hub is slightly larger; watch the offset: FORD EDGE BOLT PATTERNS YEAR STOCK WHEEL SIZES OFFERED MAX WHEEL SIZE BOLT PATTERN(millimeters& inches) STUD SIZE HUB / CENTER BORE OFFSET 2007-2010 17"-22" 24" 5x114.3"mm 5x4.50" 1/2"x20mm 70.6mm 35-45mm(H) http://www.originalwheels.com/ford-wheels/edge2011rims.php Not so sure about 2011+. I think there was a post or two on this forum re: this info. You WOULD need adapters to fit the smaller bore on the Edge to fit the larger bore on the Mustang wheels, at the very least. http://www.fordedgeforum.com/topic/8718-hub-size-difference-2009-to-2012/
Nice pic, candurin! Is the garage floor protected? It is soooooooo clean! The Edge may be dirty, but now it has "character"
Congrats & welcome! We have the same year and submodel Tell us more about your Edge!
http://www.vhtpaint.com/products/niteshades/ http://www.amazon.com/dp/B001THRG9Q
How to install Ecoboost Side Skirts/Rocker Panels
WWWPerfA_ZN0W replied to vt4278's topic in Exterior & Body
Cool! So now all we need is pix to drool over :hyper: -
2013 Edge Limited AWD on the driveway today
WWWPerfA_ZN0W replied to Hockeyref's topic in Welcome Forum!
You had some nice (and fast) rides! The Edge is no slouch in that department, though I do wish there were more aftermarket choices, or even an SVT version. No question there is untapped potential in this beast. Funny that the tech was the tops on your list, considering how much of a beating MFT has received over the years I have an AWD I got (used) primarily for its' utility. Little to no tech in it, but the only things I really miss factory are a backup camera and GPS. There are a few riders on this forum. They have posted pix on this thread http://www.fordedgeforum.com/topic/1730-post-pics-of-your-other-rides/ So there is some scope for that type of discussion on here too! Hope your computer can be brought online quickly, swear these things have a mind of their own :punched: -
Looks really sharp, Cellbine! How are the rims holding up for ya?
Welcome & congrats, both great vehicles! Glad 2 have u here.
Definitely need a rear blade for my 07. Silblade will be it! http://www.amazon.com/Silblade-RB114-D-Black-Silicone-Fitment/dp/B00464GP3W/ Fronts: http://www.amazon.com/Silblade-UB126-Hybrid-Silicone-Wiper/dp/B00464IBMK/ http://www.amazon.com/Silblade-UB120-Hybrid-Silicone-Wiper/dp/B00464IBFM/
- 28 replies
- wipers
- windshield
(and 2 more)
That ALMOST invites comment In our house, I am the dinosaur, haven't upgraded in 6 years or so!
A lower temp thermostat does help some in warmer climates, allowing the system to keep its' average temps lower. Don't know if the computer is programmed to accommodate lower temp thermostats, but I have not seen any significant impact on emissions mentioned on other forums (for other cars). What is the cooling system service history? Maybe it's time to get a flush, or at least change out the coolant and see if that helps. Are you sure the fan is working properly? Maybe the sensor is acting up? Probably too early to have set a code, but ...
Welcome to the forum and community! Color? Did you get FWD or AWD? How did you select the Edge? What kinda sports cars did you drive? please! -
Little sneak peak of whats to come!
WWWPerfA_ZN0W replied to Friegorgeous's topic in Accessories & Modifications
Nice! Details, please -
Hello & welcome.
I was rather hoping for wheelies! -
Thought it was some kind of fuel thing, either conversion or nitrous, or ... Always hoping for SOME progress on that front, that more can be extracted from the powertrain
