Everything posted by snmjim
Yes, but what & how does it contribute to this topic string? It appears to be more of a notice not to change Turbos due 2 this issue.
Seriously not trying to be a Richard Cranium but what does this have to do with this topic string???
Per Randj's post... It appears this is for the 2nd Gen 3.5 ecoboost and does "NOT" apply to the Edge Sport 2.7 ecoboost...
Per the engineering field terms and qualifiers the following applies... It wouldn't qualify as a flaw but more of a design characteristic that manufactures accepted after enough historical data came available deeming it preferable to mitigate the issue since it deteriorates performance & fuel economy over the long term life (40-50k) of the engine. So since then manufactures have come up with various designs to resolve this issue i.e. adding an additional injector behind the intake valve to wash it at every intake stroke. However, for those of us with this design and who want to mitigate it they should install a catch can, that's if longevity of performance and fuel economy are concerns for you. Recommend referencing my post on page #5 of this topic string for incremental measurements of catch can drainage...
On a 93 Octane Tune (Unleashed), with the Ultimate Perf IC & Rambo Outlet/Cold pipe at 70-75 mph in 65-85 degree weather we're seeing 28-31 mpg during highway cruising Note: all of our MODs are listed under SpecialK's thread: The Ultimate 2.7 TT Aftermarket Parts Thread! http://www.fordedgeforum.com/topic/24317-the-ultimate-27tt-aftermarket-parts-thread/
Intercooler Outlet/Cold Pipe Upgrade (2015-2018 Edge Sport)
snmjim replied to snmjim's topic in Accessories & Modifications
Yes, several of us have installed this pipe. How did the install go or ??? Exactly what is it U R asking? I'm aware of 2 that have installed this pipe using the factory IC and neither have tailored their tune to take advantage of the additional air nor have either of them done any hard data testing i.e. track, Dyno, onboard computer screen shots, etc. This installation will require removal of the front clip for access along with replacement of a stock vacuum hose with a larger diameter hose and clamps. If your not looking to increase performance...value added for effort expended probably isn't worth the effort but that is a personal call. Performance recommendation: Replace the IC outlet (cold) pipe and IC... -
From the album: SNMJim
275/45 20 Range Rover Evoque wheels powder coated matt black wrapped in Toyo Proxes -
Blackedout exhaust tip (left) -
Blackedout exhaust tip (right) -
Blackedout exhaust tips -
Xtra still doesn't have his ride back and SpecialK and I haven't been in a position to install our Turbos due to manufacture data obligations before Turbos...:-(
2016 Edge Sport (G2) Front & Rear Sway Bars
snmjim replied to snmjim's topic in Brakes, Chassis & Suspension
It's official...ADDCO has achieved the Min Qty required 2 start production however...their waiting on raw material so it's going to be 2-4 Wks till start of production. Note: ADDCO's raw material supply was exhausted by an unexpected large order from Summit Racing, they use about 15 thousand pounds of 1.125 a month! At least we're past the major hurtle... IF IT ISN'T ONE THING IT'S ANOTHER!!! -
Deleted -
WE'RE AT 14!!! If you haven't placed your order do so per the direction in my post on pg 3 of this topic string!... GO FORD EDGE FORUMS MEMBERS... NOTE: For those who missed it before let there be no doubt...WE DO NOT GET ANY KICK BACKS DOING THIS FOR YOU, ok maybe a headache or 2... -
Absolutely Incorrect... FACT: SpecialK & I were the ones who worked directly with CPe on site to R&D the RMM of which the final Duro choice was 60. Update (05/31/2018): Just spoke with our Engineer POC at CPe and identified it to be a Web page authoring error, cut & paste from the Fusion page, however they are going to rectify the Info and I verified that it hasn't changed from the 60 Duro we finalized it at...
Not so, this post is for SpecialK's use to update the master list of which I'm fairly sure he already captured the LMS T-Stat.
Deleted -
K, find attached our most recently updated build list with links... Edge Sport Parts Resources.pdf
My apologies, didn't realize that. Its cleaned out now, thnx! -
NOTICE... Ref my post on page 3 of this topic thread for ADDCO Stabilizer bar purchase Info... Those who committed to a buy please PM me once you have done so. I'll follow-up with the ADDCO POC towards end of Wk for a production status... -
Buyers be ware: Great find Xtra!
CNC IC Grill for full air flow with Perf IC and removed IC AGS Sys -
Lowered, blacked out and 275/45 20 Range Rover Evoque wheels wrapped in Toyo Proxes -
Blackout process complete -
Blackout process complete with the addition of 275/45 20 Range Rover Evoque wheels powder coated matt black wrapped in Toyo Proxes
