Everything posted by tk2fast
So Red Line is rated highest because it costs the most and has the highest levels of anti wear and cleansing additives.
Really don't understand "Bill's Ranking" in his oils comparison spreadsheet. He says he uses the data from Blackstone Labs that contain specifics around additives, flashpoints, viscosity ect. But his actual methodology is not clear at all to me. Especially when one oil gets an A+ and another a D based only on the additives in the product. Where is the "real world" application and analysis? Am I missing something? Any thoughts?
Quite interesting. Also would have liked to see mactgarage.com include Amsoil in his analysis. Surprising is the top oil in mactgarage.com, Red Line Synthetic which has a high amount of calcium. We know that calcium is one of the most effective additives for cleanliness and wear protection but also contribute to low speed pre-ignition events (LSPI). I understand that there are quite a few factors that influence LSPI, but again, Red Line receiving top dog rating especially with a $12 price tag per qt is surprising.
I checked out the price of the Mobile 1 Annual Protection and the price was about $6 less for 5 quarts than the top Amsoil Signature Series.
Nice video 1004ron, very interesting. Amsoil is rated at 25K miles and in testing, proven to be a better overall product than Mobil 1. Now with that said I'm not trying to get anyone "worked up" here. Mobil 1 is a fine product, more readily available and costs less. With either oil I do not recommend going 20K miles between an oil change, unless you have a bypass filter setup. I feel more comfortable changing my oil at around 10K so either oil would be fine IMO. Everyone has their own opinion on what is best, so go with what you believe is working. Overall Mobil 1 is a great choice.
Interesting test using Amsoil synthetic... The GM Turbo Coking Test The Turbo Coking Test was designed to simulate the extreme operating conditions of a turbocharged engine. It evaluates a motor oil’s ability to resist deposit buildup in the oil passages and bushings of a turbocharger. Temperature increases within the turbo and the weight of any deposits are recorded. Test Parameters Engine 2012 GM 1.4L Duration 2,000 cycles of extreme heat soaks – approximately 537 hours Measures A motor oil’s ability to resist deposits in a turbocharger’s oil passages and bushings Simulates High-heat operation of a turbocharged engine Requirement Temperature change within the turbocharger limited to 13 percent Signature Series protects turbochargers 72% better than required by GM dexos1® Gen 21 The GM Turbo Coking Test requires an oil to limit the temperature change within the turbocharger to 13 percent or less to pass the test. Amsoil Signature Series limited the temperature increase to only 3.6 percent, controlling heat and proving it protects against deposits common to high-temperature engine environments. 1Based on independent testing of AMSOIL Signature Series 5W-30 in the GM Turbo Coking Test as required for the GM dexos1 Gen 2 specification. *All trademarked names and images are the property of their respective owners and may be registered marks in some countries. No affiliation or endorsement claim, express or implied, is made by their use. All products advertised here are developed by AMSOIL for use in the applications shown.
Curious... how would you check the VIN's of the new 2019 Edge production?
Premium gas vs. regular: what's really better
tk2fast replied to enigma-2's topic in Articles, News & Reviews
I thought this to be "funny" as Ford still does not recommend fluid changes in the PTU, yet recommends using premium fuel. -
From the 2019 Edge owners manual. 2.0LEB For best overall vehicle and engine performance, premium fuel with an octane rating of 91 or higher is recommended. The performance gained by using premium fuel is most noticeable in hot weather as well as other conditions, for example when towing a trailer. -
NO paddle shifters on the 2019 Edge FWD... WHAT??
tk2fast replied to tk2fast's topic in Transaxle (FWD)
Some time back I tried contacting Ford via email about this to no avail. -
The updated order guide as on 9/1 states that the only 2019 Edge to have paddle shifters is the AWD. The FWD will not even have a Select Shift transmission. So strange. -
Nice review Jim... thanks
This is in the new 2019 Edge owners manual. Rear Axle and PTU Maintenance The Power Transfer Unit (PTU) and rear axle (All-wheel Drive only) in your vehicle does not require any normal scheduled maintenance, unless the vehicle has experienced extended periods of extreme or severe duty cycle driving or both PTU and the axle has been submerged in water. Checking the PTU and rear axle fluid is not necessary unless the unit shows signs of leakage. Contact an authorized dealer for service.
Thanks enigma-2. Great info. These new vehicles are quite complex and with that the greater the chance for more to go wrong, so I was thinking that it might be prudent to have an extended warranty.
All good points for sure. More Ford dealers need to be up to date on this as it would help prevent a lot of heartaches. I posted Amsoil Severe Gear Lube earlier just a help as it's new packaging might make it easier to fill. I do think that Amsoil has a little higher heat tolerance than the Ford lube though. But really the most important issue is just changing the fluid, period. There are a lot of good synthetic gear lubes out there and I'm sure Ford's is very good. May I ask if you think the extended warranty is good to have. I've looked into it and for less than 2K one can get the best premium care warranty, with zero deductible. Would like to know what others think about this also.
I had to to make assumptions to make some sense out of it, but I think there is some validity to my points. As you said there are just too many factors to quantify as to prove it. I really don't dislike Ford, just any manufacturer that does not do the "right" thing and there are many that don't. And seems most people have a different interpretation of the "right" thing as is evident here. I just feel Ford should have been more forthcoming on this issue as it has gone on for a long time. Not good PR for Ford. And yes, I would still rate Ford well above many others out there. Thanks for the reply.
I would think Ford sells a hell of a lot more AWD vehicles over a longer period of time versus Mazda. Now considering both Mazda and Ford use the same PTU, and assuming both PTU's had similar failure rates, then one would think that Ford would have had more PTU problems. Even IF Mazda had a higher failure rate, I doubt they would have had more total failed units than Ford, especially when you look at how many different Ford vehicles have used that same PTU configuration, combined with the total years (over a decade). Since Ford most likely had more total failed units, the cost of extending the PTU warranty probably would have been much greater than Mazda. This is my logic when I said, Ford also should have extended the PTU warranty here in the US.
So Mazda does the right thing and extends the warranty on the PTU, but Ford doesn't, except for the ME. Hmmm. Looks like the continuing failures are the lack of fluid drains every 15 to 25K, depending on varying factors, with high ambient temperatures being highest on the list. Too bad the majority of Edge AWD owners don't realize this. And too bad again that Ford still does not make it clear or would do the right thing and extend the warranty!
tk2fast replied to ben senise's topic in Accessories & Modifications
Is there any way to permanently turn off start/stop? -
The Jeep PTU uses the the first Gen unit made by American Axle, though the second Gen is going on the new Edge.
Good call. I think this is what might be on the 2019 Edge. A disconnecting AWD system. Maybe this will alleviate the PTU problem? https://www.aam.com/media/story/aam-s-next-generation-ecotrac-increases-
Thanks for you input omar302. It would have been nice if Ford did the same here in the US and specifically in Arizona where temps can easily reach 115. And I applaud the incremental improvements (albeit too little too late here) which is why earlier in the posts I asked if someone from Ford or a Ford mechanic would chime in and enlighten the issue.
I agree. From everything I've read 20K change intervals make sense. You are right to choose a high temp lube too, as that's the problem plaguing the PTU.
I know I've been a little harsh but It's non productive to keep debating you on these issues and yes I do "know the answers" to those questions. My "questions" were rhetorical. Look at the big picture here; Ford did not resolve the PTU issue with over a decade of small inconsequential "fixes" and yes there have been failures on Gen 2. Read other Ford owner forums and internet sources and it becomes clear. I understand you trying to diminish my viewpoint of this problem, but nevertheless the fact remains that Ford has a dismal record of successfully taking care of this problem, and continues into the Gen 2 vehicles. Ford had a perfect opportunity when re-designing to the Gen 2 to permanently take care of the problem, but failed to do so. Been a pleasure talking with you. You never said what lubes you use.
