Sage
    6
Everything posted by Sage
  1. Ok, for my 2019 ST, are the Bilstein shocks really that much of an improvement over the stock setup? Looking for something that will help out with seems to be a top heavy Edge without getting into a big cost change. Thanks
  2. Ok, the tech could not duplicate the issue, but he worked on it for about 1 1/2 hours. The tech and advisor stated if it happened again, to bring it back and he will check all the scanners/sensors(?) in all the doors to see if he could find the issue. That will take a good part of the day, so they will get me home and back when they are done. I know it will happen again, just a matter of time. If any of you figure out out is going on, please post what was found. If I find out anything, I will post that info. As normal, would not do it when at the dealer.
  3. I am having the same issues, it is intermittent for me. I am thinking 2018/19 are the same setup. My ST is still under warranty and I have an appointment tomorrow to have it looked at. I will let you know what they say.
  4. Sage
    Hello
    Welcome to the forum
  5. Sage
    New Member
  6. Has anyone else had this issue and if so, what was the fix. I do have an appointment with the dealer in two weeks, but hope I can pass on some more info of this happening to others. On my 2019 ST, for the last 2 months I have had the following issues with the door handle lock/unlock function on my door handles. First a bit of info I change my key fob batteries every October, in both key fobs. Changed just two months ago, twice to make sure all was good there. Issue follows both key fobs. I doubled checked to make sure the setting was correct in the vehicle settings options. When using the drivers door handle sensor to lock my vehicle, all doors lock just fine. Than when using the front passenger or either rear door handle sensor to unlock the doors, sometimes it works, and sometime the doors will not unlock. When this happens, only the drivers door will unlock/lock the doors. The other doors will not respond on the given door handless to anything other than to open the door. I will cycle the drivers door lock a few times on the drivers door handle, than all the other door handles will work properly. Other times I just cycled the setting on the option list than all doors handles will work normally. I do not feel it is any kind of location interference, as this just started happening two months ago in areas that I am at normally, in totally different locations and in my garage. Thanks
  7. Sage
    Nooby!
  8. ^^^^ thanks for the info ^^^^
  9. I have read that the orange(ish) coolant should be changed due to long term issues on internal parts. Everything I have found shows this applies to the 2.0 engines. Has anyone seen or know if this applies to the 2.7 as well? Tanks
  10. Sage
    Aloha
