Everything posted by mvan231
2015 Edge Sport 2.7 Ecoboost - Code P1450 - Purge valve
mvan231 replied to druegeme's topic in 2.7L EcoBoost
I had this same issue on my fusion when I had it. The self sealing fuel door was sounding like it was farting or vibrating because of the bad valve. Glad to know it's a similar issue here. The one for my fusion came with the tubes attached. This was the part I replaced on my fusion https://www.rockauto.com/en/catalog/ford,2013,fusion,2.0l+l4+turbocharged,2002842,exhaust+&+emission,vapor+canister+purge+valve+/+solenoid,4936 looks like they have a different listing for the different engine types of the 2015 Edge. Not sure why but the 2.7L looks most similar to what i had to replace on my 2013 Fusion 2.0. https://www.rockauto.com/en/catalog/ford,2015,edge,2.7l+v6+turbocharged,3310415,exhaust+&+emission,vapor+canister+purge+valve+/+solenoid,4936 -
I am having a similar issue on my 2016. It seems to be the worst when it has sat overnight or for at least 8 to 10 hours. I am going to get a battery test done and see what happens with the results
Installing Sunvisor 2018 Edge
mvan231 replied to crazywater's topic in Interior, A.C., Heat, Interior Trim
I believe there are just plastic clips that hold those in place. I'ts not the best solution though -
2010 ford edge - intermittent starting - throwing no codes
mvan231 replied to Steve Meade's topic in 2010 Edge & MKX
You could have a pending code that hasn't met all the criteria to set the DTC to present. If it was something like a starter or alternator, you may not see a code at all -
Further, you may need a special harness to keep the battery charged in the Edge from the vehicle towing it
Definitely agree that it's probably over the limit of a safe towing capacity with that configuration. Even if the 4 cylinder engines of today make similar power to previous generations of 6 cylinder
I'm also curious about this. My setup doesn't have factory tow package
hopefully you find the leak path. Maybe there is a spot to seal it off. Those controls shouldnt touch the outside though. Maybe there is somewhere else it is leaking into the roof then it's coming through there to get into the passenger compartment?
I'm also curious about this. The info I find is a max of 3,500 lbs for towing capacity if properly equipped
Front license plate bracket removal
mvan231 replied to Rob0381's topic in Accessories & Modifications
When I drilled out the rivets that were holding on the bracket on mine, I just left the two holes as is. My Edge is black so it looks fine with two small holes there -
I have heard of others having antenna leaks, but not sure how they found it. The sunroof/moonroof control area is a different location though. Is the sunroof/moonroof itself the part that is leaking?
Great find!
I haven't experienced this yet, how did you determine it was a leak coming from there? What symptoms were you having to lead you looking there?
This is good to keep in mind. Thanks a bunch!
That would certainly look great! Looks like they have some on ebay as Gadgetjq mentioned.
2011 Headlights Suck
mvan231 replied to whiteedge's topic in Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers
Furthermore, do you have any film or scratching on the headlight lens? That can sometimes divert the light beams and cause issues or just plain block the light from getting out -
Black center caps? I have a 2016 that has black caps but they are more of an entire wheel cover rather than a center cap. Further, I have never really seen the ones I have on any other vehicle or in the brochure for the 2016 Edge. Not really sure where they came from since I bought it used.
Could be that the fan control module burned up. It's been heard of before.
Ford has rolled it out in UK from what I saw on the Sync forum. I received a download link for the official release if you're interested in having it early. I previously installed an unofficial update "Sync3_3.0_19119" and I can confirm that it does fix the speed issue in Waze. Much nicer being able to have alerts turned on. Let me know if you want that download link.
There was just a recent update released for the Sync 3 software. I haven't seen the link on my owner site just yet, but I've been told it's available. There are download links to the unofficial release of v3.0.19119 if you want to try that. I did it and it works much better than the previous version. I wasn't having the radio issues you are but it could very well be that there is a glitch in the file they flashed. You can perform these updates yourself without having to go to the dealer. I had to update the USB module on my 2016 Edge SEL but I have an iPhone and it requires a specific module that wasn't included in 2016 to have CarPlay work. Sounds like Android Auto doesn't require a special module, which is a nice part for you. These recent Sync system updates are addressing issues with GPS location information. My concern previously was specifically for speed data
Yes there is on-going discussion about this on the Waze forums as well. I believe this is an issue with the CarPlay integration of the vehicle. One thing I know for sure, prior to installing the CarPlay USB module in my 2016, I was using the AppLink to display Waze on the in-dash display and the speeds were properly displayed. After CarPlay addition, now the speed is off by 4-5 MPH at lower speeds and 8-10 MPH at higher speeds similar to what you've all noticed
I've had my 2016 Edge SEL for about a month and a half or so and I've had this issue since I got it. The speedometer needle is always showing faster speeds than I am actually traveling. The digital speedometer display shows the correct value (based on my trial looking at separate GPS speed). Is this due to some incorrect setting programming in the computer or is the speedometer gauge / needle controlled some other way? I wasn't sure if the wheel/tire size is separately programmed for the digital speedometer vs the gauge. It seems strange, but I know that sometimes there are different programming parameters for certain functions in the vehicle.
