Davidoo
Everything posted by Davidoo
Ambient lighting won't stay on
Davidoo replied to Davidoo's topic in Audio, Backup, Navigation & SYNC
They eliminated the ability to change the color starting in 22 or maybe 21. I had a 17 Fusion that I could pick about 8 different colors. For me though, they did recently fix the original problem for which I started this thread, and the Ambient Lighting setting seems to be staying on. -
Ford Power Up (sync 4 update)
Davidoo replied to hanoudi's topic in Audio, Backup, Navigation & SYNC
My 22ST has Sync Power Up version 4.2.4. My car is in the garage at the house most of the time and I know it connects to my wifi when I get in my driveway. I remember the last update was at least a couple of months ago. If you connect to your home wifi, you can go to the settings, I think software updates, and when I do that it manually checks for updates each time. -
I think you are right and it is normal to not look as new in the overflow tank as what comes out of the bottle. Every vehicle I've had evaporated a bit after a year or two and I had to add some. I haven't even added a total of one cup to my 22 ST in 2 years. I was more concerned about the color not being as bright as new.
I'm not sure I really needed to add any. Now today, driving it a while, I checked it and it is about an inch OVER the max line. I know that won't hurt anything as if it ever does get too high the car will spit it out of the overflow if needed. So, I probably didn't need to add any....I just noticed the color after 2 years wasn't as vibrant of yellow as it is coming out of the bottle.
I've had my ST for 2 years now and zero issue. I check all the fluids regularly and I think about once a year I've noticed the coolant gets toward the MIN line on the overflow canister. I added a little pre-diluted Motorcraft Yellow coolant about a year ago, and now again this year. I don't find this out of the ordinary to top it off on any other vehicle I've owned about once a year. What I did notice that the coolant that came out of the new container was a much brighter neon yellow than the coolant in my overflow tank. It has a little darker, dull look to it, albeit still yellow. I'm assuming this is normal due to wear that the coolant won't maintain the bright color right out of the bottle, but concerned about oil intrusion I've read about other engines. I don't think the 22 ST with the 2.7L Turbo has this issue. Just wanted to check with anyone else with an ST a couple of years old and see if the bright yellow coolant has lost some of its luster. I don't have any evidence of coolant in the oil, and I don't think it unusual to add not even a half-inch to the overflow canister once a year. Thanks!
Thanks again Haz. The walk test for my 22ST with the B&O goes through them in no particular order that I can detect, and has them numbered from 1 through 12. I get speaker 1 is the front center and 7 is the subwoofer. I'm assuming since 2 is the right front door speaker that the one that pops up for 8 is the left door? It doesn't really matter as they all work.
It worked! Thanks! I did notice they changed the speaker walk test from when I had my 17 Fusion. Back then, the speakers went in order, from front left tweeter, center, right tweeter, etc.... Now, it just says speaker 7, speaker 12, speaker 11, and I have no idea which ones they are. Some speakers emitted a high and low pitched sound while others just one sound. Still, you can tell if all of them work, so I guess that's ok.
I agree. The only reason I didn't get it on my 22 ST was the lack of a spare tire. I have read that you possibly can get one and it will fit, but that was not the case with the 2017 Fusion plug in hybrid. Even if you could find one that worked, it wouldn't fit in the trunk.
Thanks Haz, I'll try this one. Will be a few days before I am able to see my car again.
Hope you get an answer. I've tried every suggestion and can't get my 22 ST into that mode or the speaker walk test.
I have a 22 ST and love it. It is the quietest riding car, but definitely has the power to pass or go up steep mountain passes when you need it.
I don't think they have put a paper copy in the cars for a few years. My 22 Edge ST didn't have one. I can login to my Ford website or see it on the car's display, but I still think it is a cheap move. There may be times when you need to look up something and may not have access to the electronics.
I thought this was normal behavior. I've had the Sync 3 and 4 systems in my last 3 Fords, two Fusions and now the Edge (a 22 ST). When you connect your phone to Sync Bluetooth, all you are connecting is the phone call side, such as making calls and receiving texts. The sound input is an entirely different setting if you want to hear music from your phone. For all the vehicles I've ever owned to get music from my phone I've had to select the phone as the source. Otherwise the sound output stays on AM, FM, or SiriusXM.
I have a 22 ST, and I believe it was the first year they cut out the hood insulation. I ordered one and installed myself in less than 2 minutes. I didn't try to get the engine cover as I agree with others that it is not worth it and not a big deal.
Thanks Haz! Well, the photo I attached to my last message shows the label that is on the left hand side of the valve cover (standing in front of the vehicle). Could that be the label for the engine even though it doesn't look to be the same color as the example label in your post? It appears that is from a 2014, and possibly the label is black with white letters now. If that isn't the label, I have no idea where in the heck the vaccuum pump is located. If this is the correct label, then I'm in luck because that engine was built on March 17, 2022, well after the October 2021 date when they changed the type of metal in the valve. Thanks! One odd thing is my label also shows FWD as the "drive type" even though all the STs were AWD in 2022. I suppose that engine works in either type of drive, so maybe they simply specify it as compatible for FWD.
So the big question for me is how can I find the engine build date for my 2022 ST with this engine? The assembly date was in early April of 22 and I didn't get the car until late April 22, and it says they changed the way the parts were made to eliminate the problem in engines during October 21. Would be nice to see if mine was made before or after that date. Don't know if the engines are made just shortly before assembly, or if they're stored for months prior to going in a vehicle. I can't find anything on the engine except this large sticker near the oil filler. Could 229 mean 2022 February 9th?
They are probably correct, yet it is odd that both Ford (via the fact you can't order an ST with upgraded brakes with a spare) and the dealer telling me they won't work. I had a similar situation with my prior vehicle, a 2017 plug in hybrid fusion. It did not come with a spare, I thought due to not enough storage space in the trunk due to the batteries, but it turned out the spares would not fit over the regenerative braking on the hybrid and plug-in hybrid models. I tried several spares that said they would fit, but they didn't. I do a lot of road trips, so what I did is got another rim and put one of my old tires on it when I bought new tires. Wrapped it up and put it in the back seat when we drove it to nowhere Wyoming one year. I just won't drive a car with no spare anymore. When I ordered my Edge to replace the Fusion I was very careful to get one that had a spare come with it. Good luck to Gunner in finding one that works.
I have a 22 ST (not Line). I purposely did NOT order the performance brake package because they don't come with a spare. Just not doing that. My 22 ST comes with a T155/70R18 as well. As luck would have it, I was on a road trip in May and hit an object on the interstate and blew out the sidewall on the Hankooks that came on the car. It was in a fairly isolated area, and so happy I had the spare. If your ST LINE didn't come with a spare, I assume you have the performance brake package? If so, most spares won't fit on it because of the size of the brakes. You might have to get some specialty rim for the spare. I've seen posts from others that have eventually found one that worked.
Questions about brakes on a 2020 ST
Davidoo replied to gwbmcse's topic in Brakes, Chassis & Suspension
Yes, they should go well beyond 65k miles. My son drives pretty easy on his car. He has a 2007 Ford Focus with 130,000 miles and the original brakes. -
Looking Beyond Edge being discontinued
Davidoo replied to enigma-2's topic in Buying, Leasing & Ordering
I get it, but probably most of the parts on cars assembled in the USA are initially made in China. Doesn't really make much difference. -
I agree Ford is making a huge mistake. I bought several Fusions, then they stopped making cars. Seemed like a mistake. I moved to a 22 Edge ST this time, and would buy another one as well, now no more Edge. Don't want an Escape or Explorer. My dad and other family members retired from Ford, and I worked in the plant briefly as well. Would hate to switch brands, but if they have no cars but the Mach-E and no midsize SUV what else is there? -
When you say you have a glass roof, I assume you mean the electronic panoramic roof? If so, there is a thread on this that pinpoints the cause of the rattle that many of us have. I just fixed mine a week or so ago. Here's the thread..... Rattle/Ticking Sound in Back of Panoramic Moonroof - Glass, Lenses, Lighting, Mirrors, Sunroof (BAMR), Wipers - Ford Edge Forum
Backup camera picture wobbles when hot
Davidoo replied to LVEdge's topic in Audio, Backup, Navigation & SYNC
I live in Phoenix, so we know about heat. I've had my 22 ST for about 14 months and haven't seen that behavior yet. -
After further troubleshooting, my rattle/ticking was coming from the same place mentioned by EdgeST2020. I was able to cut off a very small about half inch by half inch piece of an old bath towel, and push it under the shiny metal clip that goes over the black bar with a long small screwdriver. The rattle is gone! I barely have it stuck in there, so I think it is possible it could work its way out, but for now it is gone. At least I know where it was coming from.
I'm resurrecting this thread as I have a 22 ST that makes this click/tapping noise. I've had the car 14 months, and it didn't start until a couple of months ago. I got in the back seat area and tapped on the headliner in that area and "think" I have reproduced the sound. Mine could certainly be coming from that metal rail, but I noticed it the most when I tapped on the ANC grille as kruzr1 said above. Glad I found this thread and I'll probably try something on the metal bar first to see if that does anything because I don't want to break it.
