TheWizard Posted August 15, 2014 Report Share Posted August 15, 2014 (edited) Holy smokes! I think you should sell it or trade it in before someone notices it's defective - the courtesy lights can't be independently turned off like "most" other cars. Strange... of the seven cars I've owned (or still own) over the last ten years, only one - a BMW - had a switch for the courtesy lights so I guess the BMW is the 1 in 7 that represents "most" cars. BTW, for tailgating purposes, the interior lights will go off automatically with a door left open after about 10-15 minutes as part of the battery saver circuitry. Edited August 15, 2014 by TheWizard Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 15, 2014 Report Share Posted August 15, 2014 Japanese makes have had off switches from at least the 80's. The Chevy Cruze I owned also had one. For some reason American brands started embracing the idea only lately. Even the Ford Expedition had an off switch for the rear cargo light & the 2013 Fusion can have all the courtesy lights stay off when a door is open. Won't be surprised if the 2015 Edge came with one too. Quote Link to comment Share on other sites More sharing options...
omar302 Posted August 15, 2014 Report Share Posted August 15, 2014 On my 2011 Edge, I pulled down the front dome light assembly (very easy), there's a 3 wire connector to the lights. -Ground -Dome/Door light -Push Button Map lights I cut the dome/door wire and put a switch on it. I mounted it through the headliner, in front of the light, near the windshield. You can mount a switch anywhere if you want to rn the wires.. The same can be done with the rear dome light. the push button map lights still work normally. the rear cargo lights still go on with the doors. Can you share pictures? Or even a how to that would be a great addition to the mod section. Quote Link to comment Share on other sites More sharing options...
fredro Posted August 16, 2014 Author Report Share Posted August 16, 2014 Holy smokes! I think you should sell it or trade it in before someone notices it's defective - the courtesy lights can't be independently turned off like "most" other cars. Strange... of the seven cars I've owned (or still own) over the last ten years, only one - a BMW - had a switch for the courtesy lights so I guess the BMW is the 1 in 7 that represents "most" cars. BTW, for tailgating purposes, the interior lights will go off automatically with a door left open after about 10-15 minutes as part of the battery saver circuitry. no one said anything about being defective, i was simply stating things i didn't care for about the car. no need to get ur wizard robe all wrinkled and all. "most" of the cars I've owned in the past 20 years have pretty much had the option for the dome light switch, so this is new to me and a bit of an inconvenience. no big deal tho. cheers! 1 Quote Link to comment Share on other sites More sharing options...
Anthony Derrick Anderson Posted November 28, 2014 Report Share Posted November 28, 2014 I asked the service guy at my dealership about it. He looked it out with his computer attached to the vehicle (2013 Edge Sport). He found a feature call "Black Out" (I think). Anyways, He turned the feature on and now my lights stay off when the doors are open. And if I want them on at anytime, I just hit the button, then again to turn them back off. The only thing I noticed is that the puddle lights don't come on, unless I hit the dome light button. 2 Quote Link to comment Share on other sites More sharing options...
Koska3446 Posted June 14, 2016 Report Share Posted June 14, 2016 Has anyone solved this issue? I was thinking of locating the wiring and installing a rocker switch that I can mount into the dash? Sounds good!, but will it work? Has anyone tried? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 14, 2016 Report Share Posted June 14, 2016 Has anyone solved this issue? Did you not like the solution in the above post. Set the bit and you have full control as to when the dome lights are on or not. Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 14, 2016 Report Share Posted June 14, 2016 On my 2011 Edge, I pulled down the front dome light assembly (very easy), there's a 3 wire connector to the lights. -Ground -Dome/Door light -Push Button Map lights I cut the dome/door wire and put a switch on it. I mounted it through the headliner, in front of the light, near the windshield. You can mount a switch anywhere if you want to rn the wires.. The same can be done with the rear dome light. the push button map lights still work normally. the rear cargo lights still go on with the doors. Thanks, I did the same as you did, used this switch & used 3m double sided tape to stick the switch to the windshield at the top, just below the headliner. Does 90% of what I need as the rear dome light & cargo lights don't bother me at all. Quote Link to comment Share on other sites More sharing options...
DRbillZ Posted June 14, 2016 Report Share Posted June 14, 2016 Get a '15/'16 Quote Link to comment Share on other sites More sharing options...
Koska3446 Posted June 15, 2016 Report Share Posted June 15, 2016 Has anyone solved this issue? I was thinking of locating the wiring and installing a rocker switch that I can mount into the dash? Sounds good!, but will it work? Has anyone tried? Quote Link to comment Share on other sites More sharing options...
First Ford Last Ford Posted June 26, 2017 Report Share Posted June 26, 2017 Just discovered this "feature" while trying to camp and leaving the back hatch open to access the cooler...had to look up the various solutions and decided to pull Fuse #12. Solved the problem however getting the fuse back in was a bit of a problem, dropping it twice. I couldn't retrieve it the second time so now I have to run out and buy a few spares. After spending $600 for the "door Ajar" fix, now experiencing the "Shift into Park" nuisance prompt and having Ford Canada email me to tell me that someone would call within three days (a month ago), I highly doubt that we would EVER entertain buying another Ford product. As my wife so eloquently put it, "I just can't trust it since its something new every time" It's only 4 years old with 52000 km on it for Pete's sake. Quote Link to comment Share on other sites More sharing options...
Scarrz Posted January 19, 2022 Report Share Posted January 19, 2022 (edited) Yeah, tis an old thread... but in case someone has an old Edge like mine and is interested in a Interior Light Switch Mod that turns off the puddle lights, interior lights, and trunk/hatch... this is what I did ---> HERE Edited January 19, 2022 by Scarrz 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted January 21, 2022 Report Share Posted January 21, 2022 There's a simpler way to keep the lights off with the cargo hatch open. Open the hatch, trip the latch with a ball pen or whatever. Car will think the hatch is closed a day turn off the lights. (Remember to trip it back on before closing). 1 Quote Link to comment Share on other sites More sharing options...
