Edge SE Owners, You can have LED DAYTIME Running Lights on your SE
kc300c
Ford Edge SE Owners
Get rid of those uninteresting black plastic covers in your bumper
Replace them with our HEAD-TURNING super bright and fully functional
EDGE-2 Vertical LED DAYTIME Running Lights (DRL).
Don’t worry that your SE doesn't have the factory wiring. You don't need it!
Our EDGE-2 kits come with everything you need to install and power the incredibly bright LED DRL lamps.
FEATURES:
- Simple drop-in replacement
- Included wire harness & controller feeds power to the DRLs
- True automatic DRL function (Turn the ignition key on, DRLs come on / Key off, DRLs off)
- Exclusive hi power amber LED turn signal with crystal clear light bar.
- Clean & true OEM look.
- Simple installation. Included installation kit comes with everything you need.
(All you supply is a screwdriver, pair of pliers and about an hour of time)
- Easy to follow written instructions, with lots of photos, makes the install a breeze.
- Watch our detailed installation video below to see just how easy it is.
Add SAFETY & STYLE to your Edge SE
ORDER your set of EDGE-2's TODAY!
www.DAYTIMEBrightLites.com
Edited by 1004ron
Off topic videos removed
  • 3 months later...
- Automatic operation (Turn engine on, DRLs turn on. Turn engine off, DRLs turn off)
- Perfect for Edge models that did not come with factory accent lights.
- Unique built-in amber turn signal light bar
- Easy & Simple plug & play installation (no wire cutting or splicing)
- Make your Edge stand out (added safety, added style)
from the website
  • 2 months later...
