"DUAL" Button in A/C
full_jingbang
It's function is to combine or separate the left and right temperature settings. If Dual is off, the driver's side setting will control both sides. If Dual is on, the temperatures can be set independently. If you use the passenger temperature adjustment, it will automatically turn Dual on.
Its backwards because in the other cars, enabling "DUAL" made the temperature consistent with the driver. In the Edge, enabling "DUAL" lets the passenger select their temperature, independent of the driver.
Doesn't that make the other cars backwards? Enabling DUAL enables dual control. How is that confusing?
Thanks for the reply guys,
actually I thought the same.
BUT......
a] How do I know it is enable of disable ?
b] When we switch on the AC, is it default (Enable or Disable) ?
c] When I enable it (I guess) it should move both side temp. together, that what I understand, but it is not doing it. is there something wrong ?
d] If YES, then how to fix it ????
The ONLY thing I get by pressing the DUAL button is that it shows both sides temp. on the display....
appreciate your assistance....
thanks
Edited by full_jingbang
BUT......
thanks
a - There is a small indicator light directly above the Dual button
b - It should default to the last setting
c - No, when you enable it the two sides (dual) adjust temperature independently. Turn it off to adjust both together (single).
d - N/A
Edited by TheWizard
