Gas smell in cabin
my 2012 edge
How many miles, and have you ever changed the PTU fluid?  The smell is more like natural gas, but thought I would ask anyway.  Might be a vent leak, axle seal leak, or output shaft seal leak.
It could be a cracked flex pipe also, a common problem with gen 1.5 vehicles.
If the exhaust relief flaps in the rear bumper are staying open, that can be a source of fuel smell also.
Hello folks:
I have a somehow similar issue: very sporadic gas smell inside my 2011 FWD getting to the 200K (125K miles) mark.
Now, "my 2012 edge" if you don't mind to clarify, please: in your very first (original) post you said that you "...already changed the ... front valve cover..." but you were still smelling gasoline in your cabin.  But in your very last post you said that the smell went away since you "changed the valve cover" (the same thing?).
I just want to know if you changed something else other than the valve cover when the smell went finally away, please.
Thanks.
Edited by Edgingage
