Vanrebl Posted January 10, 2021 Report Share Posted January 10, 2021 I am tryin to install my crankshaft pully (harmonic balancer) there is no keyway on these pulleys and i want to make sure to install it in the correct position i dont see any marks on the pulley to align it up correctly.... looked online and don't see a alignment tool either...am i missing something? Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 10, 2021 Report Share Posted January 10, 2021 (edited) Not sure if you tried the forum search feature. Note the comment about not hammering the balancer back on - it will damage the crank thrust bearings. Edited January 10, 2021 by 1004ron Quote Link to comment Share on other sites More sharing options...
handfiler Posted January 10, 2021 Report Share Posted January 10, 2021 Maybe this will be of help: 3.5, 3.7 Crank Pulley Install 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 10, 2021 Report Share Posted January 10, 2021 5 minutes ago, handfiler said: Maybe this will be of help: 3.5, 3.7 Crank Pulley Install I've seen that one - it doesn't cover the install, but it does show that the harmonic balancer on this model isn't keyed. Quote Link to comment Share on other sites More sharing options...
Vanrebl Posted January 10, 2021 Author Report Share Posted January 10, 2021 yes it only shows how to take it off....i am looking for installation procedures thanks in advance for the help Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 10, 2021 Report Share Posted January 10, 2021 17 minutes ago, Vanrebl said: yes it only shows how to take it off....i am looking for installation procedures thanks in advance for the help Its not keyed, so no orientation/alignment, but it cant be heated to make it easier to go on the crank (rubber), and cant be beaten on, so you'll need a special installation "puller" or if the main bolt is long enough you could pull it up with that. 1 Quote Link to comment Share on other sites More sharing options...
Vanrebl Posted January 10, 2021 Author Report Share Posted January 10, 2021 (edited) 1004ron, thanks for your reply i will rent a tool to install it from the auto parts store so i wont need to heat it up or anything it will press it on .... just wasn't sure if the timing would be off if it wasn't in the exact right position, because of timing sensor ......it does matter doesnt it? Edited January 10, 2021 by Vanrebl Quote Link to comment Share on other sites More sharing options...
1004ron Posted January 10, 2021 Report Share Posted January 10, 2021 4 minutes ago, Vanrebl said: 1004ron, thanks for your reply i will rent a tool to install it from the auto parts store so i wont need to heat it up or anything it will press it on .... just wasn't sure if the timing would be off if it wasn't in the exact right position, because of timing sensor With it off you'll see the timing sprocket behind it, and it is keyed. This model, unlike some Fords, the crank position tone wheel isn't part of the harmonic balancer. 2 Quote Link to comment Share on other sites More sharing options...
Vanrebl Posted January 10, 2021 Author Report Share Posted January 10, 2021 ok ....thank you for your help....i was worried i was going to put it on in the wrong position and throw it out of time and trash my motor ? Quote Link to comment Share on other sites More sharing options...
EDST777 Posted June 13, 2021 Report Share Posted June 13, 2021 thus, the pulley is installed in any position relative to the crankshaft, as far as it will go to the seat? Quote Link to comment Share on other sites More sharing options...
