Adding Adaptive suspension to my ST
I love most everything about my 2019 ST.  The bumpy ride at low speeds does get to be a pain.
I am pretty sure that the shocks from a Lincoln Nautilus will fit my car.  While adding the full Nautilus active suspension is theoretically possible, the cost and degree of difficulty are high.
I am wondering if I could add just the adjustable shocks?  What I don't know is how they are controlled.  Most likely by adjusting the shock dampers using variable voltage.  If I could get the voltage range, I could create the control system to vary the shock ratio.
Does anyone know which system they use on the shocks?  I am sure that the service manual would include this information.
Thanks in advance.  John
The Vehicle Dynamics Control Module (VDM) processes an impressive array of inputs to do its job...
Document download links>
Vehicle Dynamic Suspension - System Operation and Component Description - 2019 Nautilus Workshop Manual.pdf
Vehicle Dynamic Suspension - Component Location - 2019 Nautilus Workshop Manual.pdf
Vehicle Dynamic Suspension - Wiring Diagram, Cell 041 Page 1 - 2019 Nautilus Workshop Manual.pdf
Vehicle Dynamic Suspension - Wiring Diagram, Cell 041 Page 2 - 2019 Nautilus Workshop Manual.pdf
Vehicle Dynamic Suspension - Wiring Diagram, Cell 041 Page 3 - 2019 Nautilus Workshop Manual.pdf
Vehicle Dynamics Control Module (VDM) - Connector C4396C Details - 2019 Nautilus Workshop Manual.pdf
Vehicle Dynamics Control Module (VDM) - Connector C4396D Details - 2019 Nautilus Workshop Manual.pdf
Vehicle Dynamics Control Module (VDM) - Connectors C4396C & C4396D Location - 2019 Nautilus Workshop Manual.pdf
Vehicle Dynamics Control Module (VDM) - Removal and Installation - 2019 Nautilus Workshop Manual.pdf
Vehicle Dynamic Suspension - Diagnosis and Testing - 2019 Nautilus Workshop Manual.pdf
Front Suspension Height Sensor - Removal and Installation - 2019 Nautilus Workshop Manual.pdf
Front Strut and Spring Assembly - Removal and Installation - 2019 Nautilus Workshop Manual.pdf
Rear Suspension Height Sensor - Removal and Installation - 2019 Nautilus Workshop Manual.pdf
Rear Shock Absorber - Removal and Installation - 2019 Nautilus Workshop Manual.pdf
Good luck!
Edited by Haz
Haz,
Thanks.  Getting the full system to work would take a lot of work.  Not sure if it can even be turned on in software on an Edge.
I could still do a dumb system that only changes the shock damping if I can figure out the voltage used and the PWM range.
Probably 12 volts.  Maybe some brave forum member has this on their Lincoln and can measure the voltage with an oscilloscope.I am not holding my breath.
I will try and find a shock somewhere to play with.  I can use an Arduino to create the PWM signal.
John
I have done some research in this and I think it can be done.  This would be for the adjustable shocks only, not the full adaptive setup.  I did confirm that they use a 12 volt PWM system.  Most likely this can be replicated with an Arduino and the their motor shield.
I am trying to find a shock at a junk yard to use as a test bed.  I would take it apart and work on moving the solenoid.  New ones are over $200.  I am not sure how to non-destructively test it.  Maybe a long lever to see how difference frequencies and PWM affect the damping.  This is not an ideal way to do the testing.  Anyone have a better idea how to test this?
  • 11 months later...
I finally bought a new shock from China for a reasonable price.  I am hopeful that it functions properly.  I have not found anyone who will let me hook up an oscilloscope to their adaptive suspension equipped vehicle.
Still I think I can make some headway.  I plan on making a jig to hold the shock which allows me to compress it and then time how long it takes to bully extend.  Once that is done I will just start testing values.  From what I have read they are probably using a fairly low frequency for the PWM.  I will start with 200 Hz and 50% duty cycle and see what happens.  It could take many tests to determine values that work.  Luckily I am retired, so time it not the issue.
I will report back on my progress.
I got the shock.  It looks like the quality is OK.  But who can tell from the outside.  I measured the resistance of the actuator and it is within spec.  The 4.2 ohms measured would yield ~3 amps at full load.  So 50% will yield ~ 1.5 amps.  From what I read I think that 2 amps is the max it should draw.
 @Wubster100
You ever replaced the shocks or struts on your 07? I've replaced to shocks around 120k, but not the struts. Didn't really notice much difference. 140k miles. Wonder if replacing the struts would improve Ride quality? Ride is still smooth and Ford told me the struts are still good.
Ride is comfy, but no where as good as my 2004 Sable. Now that, was a smooth, comfortable ride. Best car I ever owned.
Edited by enigma-2
I don’t own a 2007 MKX, but I borrowed it for a while. It has somewhere around 200k miles and is about 17 years old, so I would assume that the shocks and struts were probably replaced at least once?
For my 2021?
I feel like my 2021 SEL is more stiff, and the 2007 MKX is more soft and smooth like floating in a boat. I enjoyed the MKX suspension better.
To estimate the average parts cost for OEM adaptive suspension:
4x Ride Height Sensors - $120 OBO
*The front height sensor LH is already equipped on vehicles with curve adaptive headlamps.
Vehicle Dynamics Module - $40
Adaptive struts + shocks - $500-1,000?
Miscellaneous, nuts, bolts and wiring - $150?
Am I missing any other main parts that could be needed?
AsBuilt Changes Needed: IPC, ABS?,
IPC Control of Adaptive Steering and Continuously Controlled Damping (CCD)  Suspension | Ford Fusion V6 Sport Forum
Edited by Wubster100
My first idea was to only make the shock rates adjustable without being adaptive while driving.  The cost and the risk of the system not being recognized by the Edge being the main reason behind my thinking.  I might just buy the control module above and see if the car will find it.  Then I could play around with Forscan and see if I could get it to work.  I would use simple fixed resistors for the ride height and shocks.  The service manual gives the proper ranges for the resistance.
I have not given up.
Edited by johnmarkp
I have the VDM and one height sensor on order.  I got a the height sensor because I want to confirm how it communicates the back to the VDM.  I thought it was a simple voltage divider, but after looking at the service manual again, I think it might be a Hall sensor.  I'll know for sure soon.
