Iroga Posted February 23, 2025 Report Share Posted February 23, 2025 (edited) I wasn't happy with the light in the trunk at all. If the light isn't blocked, then everything is fine. But when it's blocked, it's hard to find anything. The lampshade is inserted into a frame made of textolite. I disassembled the right side of the interior to lower the ceiling. We connect to the rear right light. We place the lantern in the middle, carefully cut it out and insert it. We get the final result. Edited May 27 by 1004ron 4 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted February 23, 2025 Report Share Posted February 23, 2025 Amazing! Thanks for sharing the details. Quote Link to comment Share on other sites More sharing options...
Amedaius Posted October 18, 2025 Report Share Posted October 18, 2025 I was very surprised to learn theres no light in the cargo area on the Edge, I actually searched for awhile assuming I just wasn't seeing it, surely it couldn't be there was no lighting at all? Great solution though, I may look into something similar, but I will likely just put in a battery powered light for closets. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted October 18, 2025 Report Share Posted October 18, 2025 2 hours ago, Amedaius said: was very surprised to learn theres no light in the cargo area on the Edge, I actually searched for awhile assuming I just wasn't seeing it, surely it couldn't be there was no lighting at all? If is on the lower right side. Quote Link to comment Share on other sites More sharing options...
Amedaius Posted October 19, 2025 Report Share Posted October 19, 2025 On 10/18/2025 at 10:03 AM, Wubster100 said: If is on the lower right side. Hmmm maybe mine is out or something, I had it open and the cabin lights were on but there was no light in the rear. What in the world were they thinking putting it down there though? Thanks for the info! 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted January 4 Author Report Share Posted January 4 (edited) There is a solution that is easier to implement. https://trusttosell.com/shop/car-high-brightness-trunk-lighting-ambient-light-interior-decoration-led-wiring-free-automatic-sensing-tailgate-light-strip/ Edited January 4 by Iroga 2 Quote Link to comment Share on other sites More sharing options...
edgeidiot Posted January 4 Report Share Posted January 4 Please check the link. I cannot get it to work. Quote Link to comment Share on other sites More sharing options...
Iroga Posted January 5 Author Report Share Posted January 5 Car High Brightness Trunk Lighting Ambient Light Interior Decoration LED Wiring Free Automatic Sensing Tailgate Light Strip https://trusttosell.com/ . Quote Link to comment Share on other sites More sharing options...
edgeidiot Posted January 5 Report Share Posted January 5 Not sure why the link does not work for me. Maybe it is being blocked by Ghostery? I found it on Amazon: Amazon.com: Dynamic Flowing Car Trunk Light Strip, Trunk Led Light Strip,Led Strip Lights for Car Trunk Cargo Area or Interior Illumination Decoration (White,Full Circle 4 m/157 in) : Automotive. It is available for the top half or whole circumference. It is hard wired in through the rear lamp. This one is available in blue, purple, and warm or cool white. 2 Quote Link to comment Share on other sites More sharing options...
Tom Maiello Posted May 27 Report Share Posted May 27 Hi. Did you move the right side or put in a new light? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 5 Report Share Posted June 5 This should be an easy, quick fix to your problem. FSTURIOS Car Interior Ceiling Roof Light, Magnetic Wireless Dome Map Lamp 10 LEDs Bright Reading Lights, Universal USB Rechargeable Dome Light Fixture for RV Camper Trailer Boat (Gray) https://a.co/d/0clltpsH Quote Link to comment Share on other sites More sharing options...
Summers22 Posted September 20 Report Share Posted September 20 @Iroga did you buy an OEM harness and plug as well as the light? I have a light with backing plate on the way, but need to find a plug or wiring diagram for the 3 pins on the light itself. Thanks Quote Link to comment Share on other sites More sharing options...
Iroga Posted September 22 Author Report Share Posted September 22 On 9/20/2026 at 10:32 PM, Summers22 said: @Iroga did you buy an OEM harness and plug as well as the light? I have a light with backing plate on the way, but need to find a plug or wiring diagram for the 3 pins on the light itself. Thanks I found a connector that had already been used. I connected the wires based on their visual similarity and placement. Quote Link to comment Share on other sites More sharing options...
Summers22 Posted September 22 Report Share Posted September 22 @Iroga Great, thank you. I also see you have the pano roof. The light fit fine without any interference? Quote Link to comment Share on other sites More sharing options...
fishx65 Posted September 22 Report Share Posted September 22 Quote Link to comment Share on other sites More sharing options...
Summers22 Posted September 22 Report Share Posted September 22 You guys that add the ebay/amazon light around the weather seal, show some daytime pics. I have OCD and prefer OEM installs and can't see how a white tube looks good around that seal..... Quote Link to comment Share on other sites More sharing options...
Iroga Posted September 22 Author Report Share Posted September 22 2 hours ago, Summers22 said: @Iroga Great, thank you. I also see you have the pano roof. The light fit fine without any interference? Yes. It’s the same type of light as the one for the rear passengers. Power is drawn from the rear right one. 1 Quote Link to comment Share on other sites More sharing options...
Iroga Posted September 22 Author Report Share Posted September 22 1 hour ago, fishx65 said: Which model is the mat from? 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted September 22 Report Share Posted September 22 3 hours ago, Iroga said: Which model is the mat from? Looks like the Weathertech generic trim to fit mat (that hasn't been trimmed). I trimmed mine for my 2017 Escape, and just use it as is, too small, in my Edge 1 Quote Link to comment Share on other sites More sharing options...
Summers22 Posted September 24 Report Share Posted September 24 I bought an OEDRO from Amazon on sale for $35.99 perfect fit in my 22 Quote Link to comment Share on other sites More sharing options...
