DNBush Posted April 9 Report Share Posted April 9 2020 Edge Titanium. Two weird things have begun to happen. Intermittently the ability to lock and unlock the doors via the touch points on each door handle will stop working save for the driver door. The proximity sensors will alert when there's nothing even close to the car. This, interestingly, happens mostly in the morning when the car is first driven and then it happens only at the first or second stop. Has anyone else experienced this and if so, has a fix been found? Thanks! Quote Link to comment Share on other sites More sharing options...
dabangsta Posted April 9 Report Share Posted April 9 Someone else posted this recently, so I went and checked mine, and a couple of times I have had the same issue, only drivers door proximity works (I can only lock/unlock using the drivers door touch points). I went through the settings, thinking that it was related to the "Switch Inhibit" but I think that is only interior buttons. I went to the settings, and then tried, and all doors worked. It has happened a couple of times, because I more commonly unlock from the drivers rear door because I put stuff in there before getting in the drivers door. What alerts do you get from the proximity sensors? What does this mean? The Perimeter alarm is door sensors (a door, lift gate, hood) opened without the vehicle being unlocked. I don't think any Edge gets a sensor alarm (movement, glass breaking) like the MKX/Nautilus. Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 9 Author Report Share Posted April 9 10 minutes ago, dabangsta said: What alerts do you get from the proximity sensors? What does this mean? The Perimeter alarm is door sensors (a door, lift gate, hood) opened without the vehicle being unlocked. I don't think any Edge gets a sensor alarm (movement, glass breaking) like the MKX/Nautilus. What I'm talking about is the vehicle perimeter proximity sensors, the ones that alert you if you're too close to an object. On the center screen they'll light up red briefly even when nothing is near me. Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted April 9 Report Share Posted April 9 6 hours ago, DNBush said: Intermittently the ability to lock and unlock the doors via the touch points on each door handle will stop working save for the driver door. This is due to load shedding. If the battery is weak, the vehicle will slowly disable features to save power. The keyless entry touch points, except for the driver's door, may get disabled to save power. 6 hours ago, DNBush said: The proximity sensors will alert when there's nothing even close to the car. This, interestingly, happens mostly in the morning when the car is first driven and then it happens only at the first or second stop. One of the parking sensors could be dirty or faulty. Do you have the side sensing system? Sometimes the side parking sensors may get close to objects and beep. Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 10 Author Report Share Posted April 10 1 hour ago, Wubster100 said: This is due to load shedding. If the battery is weak, the vehicle will slowly disable features to save power. The keyless entry touch points, except for the driver's door, may get disabled to save power. One of the parking sensors could be dirty or faulty. Do you have the side sensing system? Sometimes the side parking sensors may get close to objects and beep. Interesting on the battery issue. I'll try to pay attention but I do believe that the issue with the keyless entry touch pads/points seems to happen mostly in the morning when first starting the car (remote start). Though I know it has happened during the day after parking the car and then returning to it shortly thereafter. So does this imply my battery is losing its ability to hold a charge? Regarding the parking sensors, yes the car has side and front/rear sensors. Car is clean so maybe faulty. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted April 10 Report Share Posted April 10 1 hour ago, DNBush said: So does this imply my battery is losing its ability to hold a charge? Yes 1 hour ago, DNBush said: Regarding the parking sensors, yes the car has side and front/rear sensors. Car is clean so maybe faulty. When you mention that they will light up red on screen, is it always the same sensor? Possible causes: Could there be any object nearby, such as a stop sign pole or plant? Could the sensor be pushed in or not mounted correctly? Is the road surface uneven that could cause the parking sensors to point down at the road? The side parking sensors can be sensitive to anything nearby. Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 10 Author Report Share Posted April 10 6 minutes ago, Wubster100 said: Yes When you mention that they will light up red on screen, is it always the same sensor? Possible causes: Could there be any object nearby, such as a stop sign pole or plant? Could the sensor be pushed in or not mounted correctly? Is the road surface uneven that could cause the parking sensors to point down at the road? The side parking sensors can be sensitive to anything nearby. It's the front and sides (both) but mostly the sides and they light up red along most of the length of the image of the car. It happens, mostly, when I'm at the first stop sign leaving my development. Nothing within at least 25 feet of the car, smooth pavement. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted April 10 Report Share Posted April 10 It seems like the side sensors are just detecting the stop sign pole then. Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 10 Author Report Share Posted April 10 3 hours ago, Wubster100 said: It seems like the side sensors are just detecting the stop sign pole then. Hmm... well, there's only one pole and it's happening on both sides of the vehicle. Either way it seems somethings gone wrong. This only started a few months ago. You don't think it might be connected to the battery issue do you? 1 Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 10 Author Report Share Posted April 10 18 hours ago, Wubster100 said: This is due to load shedding. If the battery is weak, the vehicle will slowly disable features to save power. The keyless entry touch points, except for the driver's door, may get disabled to save power. Well, I just had the battery checked. It's fine. I may have to go to Ford and see if they can diagnose this (and the sensor issue). 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted April 10 Report Share Posted April 10 Any problems with active park assist? Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 10 Author Report Share Posted April 10 (edited) 39 minutes ago, Wubster100 said: Any problems with active park assist? Active park assist? Is that the push the button and it'll park the car (parallel or into a slot) by itself? If so, yeah, the problem is I don't trust it. I tried the parallel one and it whipped the car into the spot so fast that if someone had stepped off the curb at that very moment they would have been killed. Nope, not for me. Edited April 10 by DNBush 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted April 11 Report Share Posted April 11 Yes. Active park assist uses the front side sensors to detect the parking spot. The system only controls the steering. It is the driver’s responsibility to control the speed of the vehicle by using the gas and brake. Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 11 Author Report Share Posted April 11 59 minutes ago, Wubster100 said: Yes. Active park assist uses the front side sensors to detect the parking spot. The system only controls the steering. It is the driver’s responsibility to control the speed of the vehicle by using the gas and brake. Well, when I activated the active park assist for a parallel park, it told me, essentially, hands off the wheel and feet off the pedals. It did it all and damn fast. But accurately. 1 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted April 11 Report Share Posted April 11 Yes, you remove your hands from the steering wheel. However, the vehicle cannot brake for you or control the speed. The driver must use the brake and gas to maintain speed and stop the vehicle when it gets close to obstacles. Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 11 Author Report Share Posted April 11 1 hour ago, Wubster100 said: Yes, you remove your hands from the steering wheel. However, the vehicle cannot brake for you or control the speed. The driver must use the brake and gas to maintain speed and stop the vehicle when it gets close to obstacles. Well, that would certainly be my preference but as I said, the car did everything. 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted April 11 Report Share Posted April 11 @DNBush: From the 2020 Edge Workshop Manual, with emphasis added... Active Park Assist The active park assist system is a supplementary parking system that assists the operator with the task of parking in three ways: Parallel Park Assist - Detects an available parking space and automatically steers the vehicle into the space while the operator controls the accelerator, gearshift and brakes. Perpendicular Park Assist - Detects an available parking space and automatically steers the vehicle into the space while the operator controls the accelerator, gearshift and brakes. Park Out Assist (only for exiting parallel spots) - Analyzes the parking space currently occupied by the vehicle and automatically steers the vehicle out of the space while the operator controls the accelerator, gearshift and brakes. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 11 Author Report Share Posted April 11 1 hour ago, Haz said: @DNBush: From the 2020 Edge Workshop Manual, with emphasis added... Active Park Assist The active park assist system is a supplementary parking system that assists the operator with the task of parking in three ways: Parallel Park Assist - Detects an available parking space and automatically steers the vehicle into the space while the operator controls the accelerator, gearshift and brakes. Perpendicular Park Assist - Detects an available parking space and automatically steers the vehicle into the space while the operator controls the accelerator, gearshift and brakes. Park Out Assist (only for exiting parallel spots) - Analyzes the parking space currently occupied by the vehicle and automatically steers the vehicle out of the space while the operator controls the accelerator, gearshift and brakes. Good luck! Well, I can't explain it but, I have only attempted the Parallel and for the third time now, I'll say it, the car did all the work. 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted April 11 Report Share Posted April 11 It is impossible for active park assist on the Ford Edge to control the vehicle's speed. The operator must control the accelerator, gearshift and brakes. The vehicle will control the steering. However, vehicles equipped with Active Park Assist 2.0, such as the 2024+ Lincoln Nautilus, will prompt you to shift into neutral. Then, you must hold down the park button. Active Park Assist 2.0 is not available on the Ford Edge. The driver must use the accelerator and brake to control the vehicle's speed. 1 1 Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 11 Author Report Share Posted April 11 1 hour ago, Wubster100 said: It is impossible for active park assist on the Ford Edge to control the vehicle's speed. The operator must control the accelerator, gearshift and brakes. The vehicle will control the steering. However, vehicles equipped with Active Park Assist 2.0, such as the 2024+ Lincoln Nautilus, will prompt you to shift into neutral. Then, you must hold down the park button. Active Park Assist 2.0 is not available on the Ford Edge. The driver must use the accelerator and brake to control the vehicle's speed. I'm not going to argue with you. I and the two other people that were in the car with me know what happened. 1 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted April 12 Report Share Posted April 12 On 4/10/2025 at 2:40 PM, DNBush said: Well, I just had the battery checked. It's fine. I may have to go to Ford and see if they can diagnose this (and the sensor issue). If it’s the original battery I guarantee it’s bad. They rarely last more than 3.5 years. They seem ok u til they die completely. Either replace it or have the CCAs measured. 1 Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 13 Author Report Share Posted April 13 17 hours ago, akirby said: If it’s the original battery I guarantee it’s bad. They rarely last more than 3.5 years. They seem ok u til they die completely. Either replace it or have the CCAs measured. CCAs. ?? 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 13 Report Share Posted April 13 On 4/10/2025 at 2:40 PM, DNBush said: Well, I just had the battery checked. It's fine. I may have to go to Ford and see if they can diagnose this (and the sensor issue). 20 hours ago, akirby said: If it’s the original battery I guarantee it’s bad. They rarely last more than 3.5 years. They seem ok u til they die completely. Either replace it or have the CCAs measured. 2 hours ago, DNBush said: CCAs. ?? If you're asking what CCA means, then I doubt that you had the battery properly tested. If you take it to a place like AutoZone they'll do a battery health check and report the Cold Crank Amps and how it compares to the new battery rating. So tell us, how did you check the battery? 1 Quote Link to comment Share on other sites More sharing options...
DNBush Posted April 14 Author Report Share Posted April 14 On 4/13/2025 at 1:17 PM, 1004ron said: If you're asking what CCA means, then I doubt that you had the battery properly tested. If you take it to a place like AutoZone they'll do a battery health check and report the Cold Crank Amps and how it compares to the new battery rating. So tell us, how did you check the battery? AutoZone. They didn't use the acronym CCA and I am not a car guy so I'm too stupid to know what CCA means. But that's what you're implying any way so I hope I've satisfied you. 1 Quote Link to comment Share on other sites More sharing options...
dabangsta Posted April 14 Report Share Posted April 14 Generally when you take in a battery to be tested, they: usually charge it (you only gives a full good result starting as charged as it can get) use a tester that tests and prints out: SoH (State of Health) (??generally CCA compared to rated CCA??) CCA (how many amps it can provide for 30 seconds at 0 degrees without dipping below 7v) Rated CCA (how many CCA is should be brand new) SoC (State of Charge) (current voltage vs rated voltage percentage, can be low if not charged, but only real handy if charged fully before test) Internal Resistance (can show an internal issue, like a dead or shorted cell) voltage (not as handy as other numbers) Often times shortcuts are taken, or the test isn't good enough to show the actual issue. Most places will give you the results (instead of just saying "it good"). They are more likely to do a full correct test if you are attempting to warranty the battery at the place it was bought from. 1 Quote Link to comment Share on other sites More sharing options...
