Haz Posted June 11, 2025 Report Share Posted June 11, 2025 *** The following Dealer Bulletin has been edited to provide the information most relevant to Forum members. *** The complete Safety Recall 24S55 Technical Instructions document, which provides Testing and Service procedures for professional technicians, is attached at the bottom as a PDF document... Safety Recall 24S55 - Engine Valve Inspection Test - Technical Instructions.pdf 2 Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 11, 2025 Report Share Posted June 11, 2025 How come the Edge's labor time is significantly less than other models? Typo? 1 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 11, 2025 Author Report Share Posted June 11, 2025 @omar302: Per Ford's Service Labor Times Standards, you are correct... A half-hour contingency is apparently being added to the SLTS allowance for Safety Recall 24S55. Good luck! 3 Quote Link to comment Share on other sites More sharing options...
Davidoo Posted June 12, 2025 Report Share Posted June 12, 2025 Thanks Haz. Is something new about this? I thought this same issue came up a couple of years ago. I have a 22 ST and was concerned about this and found my engine was made in March of 22, so it didn't apply. Quote Link to comment Share on other sites More sharing options...
Haz Posted June 13, 2025 Author Report Share Posted June 13, 2025 (edited) @Davidoo: You are recalling correctly! In October 2023, the National Highway Transportation Safety Administration (NHTSA) upgrading their investigation into this topic was posted to the Forum here... NHTSA Investigation Upgraded To Engineering Analysis Phase, Applies To 2.7L & 3.0L EcoBoost Engines, Vehicle Population Includes 2021-2022 Edge (6,889), and 2021-2022 Lincoln Nautilus (8,596) + Other Models The NHTSA website now offers this Chronology Report that details the 'anatomy' of Safety Recall 24S55... CERTAIN 2021 and 2022 MY FORD/LINCOLN VEHICLES – NANO INTAKE VALVE Date of Submission: August 23, 2024 Chronology of Defect / Noncompliance Determination Provide the chronology of events leading up to the defect decision or test data for the noncompliance decision. On January 25, 2022, Global CCRG opened an investigation into 2021 Model Year (MY) Lincoln Aviator and Nautilus vehicles equipped with 2.7L and 3.0L Nano EcoBoost gasoline engines after an international investigation discovered twenty-two (22) instances of engine failure at three (3) months in service or less. A review of failed engines revealed that the engine intake valves fractured and fell into the combustion chamber of the engine causing catastrophic engine damage leading to a Loss of Motive Power (LOMP). Based on an analysis of returned fractured valves from failed engines, Ford identified that the potential root cause of the failures was engine intake valve failure due to valves that exceeded the designed specification for hardness, were brittle, and more likely to fracture. Ford determined that this was due to the supplier’s grinding processes and the sensitivity of the intake valve material to grinding processes that were not within control specifications. The intake valve material was changed for vehicles produced after October 31, 2021. The new material increased the valve’s robustness to keeper groove grinding processes outside of control specifications. On May 05, 2022, Ford’s North America (NA) CCRG opened an investigation regarding early time in-service left-hand engine intake valve fractures on 2021MY Ford and Lincoln vehicles equipped with 2.7L and 3.0L Nano EcoBoost gasoline engines. Teardown analysis of returned failed engines confirmed intake valve fracture on two-hundred fifty-one (251) engines from warranty repairs. On May 27, 2022, the National Highway Traffic Safety Administration (NHTSA) opened Defect Petition 22-001 in response to an increasing trend of Vehicle Owner Questionnaires (VOQs) submitted by 2021MY Ford Bronco customers alleging LOMP as a result of catastrophic engine damage. On July 22, 2022, NHTSA opened Preliminary Evaluation (PE) 22-007 to continue their investigation into 2021MY Ford Bronco customer allegations of LOMP. Ford’s response was provided to NHTSA on September 28, 2022. On September 29, 2023, NHTSA opened Engineering Analysis (EA) 23-002 and expanded the scope of their investigation to include all 2021 and 2022MY Ford/Lincoln products that are equipped with the 2.7L and 3.0L Nano EcoBoost engines. Ford’s response was provided to NHTSA on January 02, 2024. Ford noted that there was a higher than ambient level of repairs observed for vehicles produced between May 1 and October 31, 2021. On December 4, 2023, NHTSA personnel visited Ford facilities to observe Ford’s engine teardown and laboratory analysis processes for evaluating fractured intake valves. Between February and August 2024, Ford has participated in several discussions related to fractured intake valves on Nano EcoBoost engines with NHTSA. As of August 09, 2024, Ford is aware of 811 global warranty claims confirmed or suspected to be related to fractured intake valves with report dates ranging from February 13, 2021 to June 03, 2024. Ford is aware of 267 field reports with report dates of October 06, 2020 to October 18, 2023. Ford is aware of 223 customer reports with report dates of March 31, 2021 to August 29, 2023. On August 16, 2024, Ford’s Field Review Committee reviewed the concern and approved a field action. Ford is not aware of any reports of accident or injury related to this condition. Affected owners received an initial notification letter in October 2024... An earlier NHTSA letter on Safety Recall 24S55 was posted to the Forum here. Good luck! Edited June 13, 2025 by Haz 2 Quote Link to comment Share on other sites More sharing options...
MLTEdge Posted June 16, 2025 Report Share Posted June 16, 2025 My car was manufactured in March. So far I've escaped almost all significant recalls. Most seem to be earlier or May or after. What in the heck changed in under 2 months? Quote Link to comment Share on other sites More sharing options...
Haz Posted June 16, 2025 Author Report Share Posted June 16, 2025 From the above-quoted NHTSA Chronology Report, with emphasis added... On January 25, 2022, Global CCRG opened an investigation into 2021 Model Year (MY) Lincoln Aviator and Nautilus vehicles equipped with 2.7L and 3.0L Nano EcoBoost gasoline engines after an international investigation discovered twenty-two (22) instances of engine failure at three (3) months in service or less. A review of failed engines revealed that the engine intake valves fractured and fell into the combustion chamber of the engine causing catastrophic engine damage leading to a Loss of Motive Power (LOMP). Based on an analysis of returned fractured valves from failed engines, Ford identified that the potential root cause of the failures was engine intake valve failure due to valves that exceeded the designed specification for hardness, were brittle, and more likely to fracture. Ford determined that this was due to the supplier’s grinding processes and the sensitivity of the intake valve material to grinding processes that were not within control specifications. The intake valve material was changed for vehicles produced after October 31, 2021. The new material increased the valve’s robustness to keeper groove grinding processes outside of control specifications. Good luck! 3 Quote Link to comment Share on other sites More sharing options...
STBEAST Posted June 17, 2025 Report Share Posted June 17, 2025 I bought a 2021 ST and it was delivered to me in September of 2021, which means it was probably one of those timebombs. It had some weird transmission issues which scared me and they could never resolve, so I traded it in for a 2024 last year. Looks like I may have dodged a bullet. 2 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 20, 2025 Author Report Share Posted June 20, 2025 For affected vehicles that pass the engine valve inspection provided by Safety Recall 24S55, Ford is providing coverage for a long block engine replacement should the vehicle require engine replacement due to a cracked engine intake valve at a subsequent date, within 10 years/150,000 miles from vehicle's Warranty Start Date, or, if a vehicle has already exceeded either the time or mileage limits, this no-cost, one-time repair will last through June 30, 2026. For more information, see... Customer Satisfaction Program 24N12 - 2021-2022 Edge ST/Nautilus - 2.7L EcoBoost - 05-10-2021 through 10-29-2021 Build Dates - Passed Safety Recall 24S55 Engine Valve Inspection - 10 Yr/150k Mile One-Time Engine Long Block Replacement If Valve Breaks 2 Quote Link to comment Share on other sites More sharing options...
