flymore Posted July 18, 2025 Report Share Posted July 18, 2025 While driving in the rain today my front wipers stopped working, and then started again after turning a corner. Wasn't a heavy rain so I was turning them off and on again. They stopped for a long time. figured I'd blown a fuse but then abruptly started again after a sharp left turn. Some months ago I did replaced the wiper blades with Motorcraft blades. Is there something that needs lubrication? New wiper motor? Thanks Quote Link to comment Share on other sites More sharing options...
omar302 Posted July 19, 2025 Report Share Posted July 19, 2025 8 hours ago, flymore said: Is there something that needs lubrication? New wiper motor? No lubrication as far as I know. Could also be the wiper switch. Best to check with ForScan for any codes to better diagnose the issue. Quote Link to comment Share on other sites More sharing options...
flymore Posted July 19, 2025 Author Report Share Posted July 19, 2025 Ok, I'll look for codes. Quote Link to comment Share on other sites More sharing options...
flymore Posted July 20, 2025 Author Report Share Posted July 20, 2025 No codes. Quote Link to comment Share on other sites More sharing options...
1004ron Posted July 20, 2025 Report Share Posted July 20, 2025 What you using to read codes? Quote Link to comment Share on other sites More sharing options...
flymore Posted July 20, 2025 Author Report Share Posted July 20, 2025 (edited) Was just out driving today. Pulled the washer/wiper it sprayed the windshield, wiped it and worked fine. I used forscan to read for codes. Edited July 20, 2025 by flymore Quote Link to comment Share on other sites More sharing options...
flymore Posted July 21, 2025 Author Report Share Posted July 21, 2025 Checked again for codes, no codes. Had wife spay windshield with hose while I ran wipers, all went fine. I put new motorcraft wipers on five months ago. Is there any re calibration I need to do when changing wiper blades? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted July 29, 2025 Report Share Posted July 29, 2025 As it responded to turning the steering wheel, thats the area I'd suspect. The wiper switch is attached there, its possible that the movment of the steering wheel could be the culprit. If it happens again, try tilting the wheel or juggling your stalk. 🙄 Quote Link to comment Share on other sites More sharing options...
