DNBush Posted September 6, 2025 Report Share Posted September 6, 2025 Car is over five years old so I'm thinking it's probably good to replace the original factory battery. Question is, what does every one think is the best replacement? I understand that it should be an H6 or Group 48 AGM (Absorbed Glass Mat) battery but beyond that I'm not sure what the best choice would be. I know I could go right to my local Ford dealer but I suspect that might be the most expensive option. What should I do? 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 6, 2025 Report Share Posted September 6, 2025 I would go with the H6 AGM Everstart Platinum from Walmart. Be sure to reset your battery monitoring and select a new battery code if you change size and type. 3 Quote Link to comment Share on other sites More sharing options...
DNBush Posted September 6, 2025 Author Report Share Posted September 6, 2025 1 hour ago, 1004ron said: I would go with the H6 AGM Everstart Platinum from Walmart. Be sure to reset your battery monitoring and select a new battery code if you change size and type. Regarding the reset of the battery monitor, the second step says "Turn ignition switch to on (don't start car). Wait 10 seconds." In a car like my 2020 where it's a push button, does that correspond to pushing the button once with the foot off the break? Quote Link to comment Share on other sites More sharing options...
boostededge Posted October 1, 2025 Report Share Posted October 1, 2025 Costco - easy to return Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 1, 2025 Report Share Posted October 1, 2025 1 hour ago, boostededge said: Costco - easy to return Not when it fails just outside the warranty. Quote Link to comment Share on other sites More sharing options...
edgeidiot Posted October 2, 2025 Report Share Posted October 2, 2025 Not sure about what you are referring to about the Costco warranty. Costco warranty is 36-month prorated. Walmart is a three-year free replacement. Quote Link to comment Share on other sites More sharing options...
Blk22Edge Posted December 9, 2025 Report Share Posted December 9, 2025 Wondering how the OP worked out with the new battery and which one they went with. My 22 Edge keeps going into "battery saver mode" and it was a sluggish start for it today. (-5 degrees Fahrenheit) But whenever it gets below freezing I get the battery saver mode message. I'm not a fan of Big box store batteries. Thinking of going OEM but not sure. Mine uses the AGM battery. 1 Quote Link to comment Share on other sites More sharing options...
garycrist Posted December 9, 2025 Report Share Posted December 9, 2025 I have had mine (2022 ST) replaced already (AGM) in less than 1 year. From reading all over, it appears that there were a bunch of bad ones for that model. My date of production was 11/22 and replacement 8/23! 1 Quote Link to comment Share on other sites More sharing options...
edgeidiot Posted December 10, 2025 Report Share Posted December 10, 2025 Does the Edge have an undersized alternator? I do drive many short distances, but it only takes a couple of trips for the start-stop (yes, I know everyone hates that) to stop working and in about ten days, I get the battery saver message and all but the driver's door cannot be locked/unlocked from the outside. I have had the battery checked and replaced, but the problem did not go away. I bought an AC battery charger (Battery Tender) that plugs into my cigarette plug. I keep it on the charger when I am at home. It is a pain since I have to roll down a window to plug it in, but I do not want to get stuck somewhere. I have the first electric Edge! 2 Quote Link to comment Share on other sites More sharing options...
Wubster100 Posted December 10, 2025 Report Share Posted December 10, 2025 This problem seems to happen with many Fords. My battery is almost 6 years old now. I have had the symptoms for about a year now. No start stop, radio powers off, no Fordpass, no keyless entry, etc. However, AGM batteries do a better job at hiding symptoms of a bad battery than lead acid. An old AGM battery will still start the car, but the battery will be very slow to accept charge. Some battery testers can be fooled by AGM batteries. Conductance testers estimate battery health by sending a tiny AC signal into the battery. AGM batteries will often show normal voltage, okay conductance, and acceptable internal resistance even when the battery is old and nearly worn out. Battery testers that actually put a real load on the battery will reveal the true battery health. The Edge is equipped with a slightly smaller H6 battery, while the Lincoln Nautilus is equipped with a slightly larger H7 battery. 2 Quote Link to comment Share on other sites More sharing options...
